[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Hab im Treiber jetzt auf 100HZ gestellt und 97 FPS sowie V Sync bei Hogwarts an .
Das läuft richtig Top 4K Ultra DLSS Qualität+ RT+Framegeneration.
Sollte man das Game mit Controller zocken oder spielt sich gut mit Maus und Tastatur ?
Bei Guardians of the Galaxy zb. hatte ich damals gemerkt das man mit tasta und Maus im Nachteil war und es wesentlich besser mit dem Series X Controller war .
@ralle_h hat seinen Job gut gemacht. Der Luxx-Bot war 14 Minuten schneller mit seiner Meldung als die eben erst bei mir eintrudelnde Verfügbarkeits-E-Mail vom ASUS Shop (y)
BTW:
Hier der Link: https://www.paypal.com/pools/c/8H0ptvUqGL
Wir sammeln für den Busfahrer... ;)
Weckt mich bei der White. :)
Meine Tochter zockt es mit Controller von der Couch .
Hab es eben mit Tastatur von der Couch gespielt geht auch Super.
Wie man mag halt!
uiuiui wie die 4090 hier verdroschen wird.
was ist denn auf einmal mit der xtx los? vor tagen noch der krüppel und jetzt der king.
Maus und Tastatur brauchst Du eigentlich nur bei Shootern. Weiß jetzt nicht wie man bei Harry Potter zielen muss, aber W3 spiele ich auch mit dem Controller, während Division oder Ghost Recon nur mit Maus und Tastatur gut funktionieren.
GTA und RDR2 zwei sind dann genau dazwischen. Zu Fuss mit Maus, Tastatur, zu Pferd bzw. Auto mit dem Controller. Ja, ist schon kompliziert. :fresse:
Keine Ahnung was die da gemacht haben, lt. HU sind die NVidia Karten CPU bottlenecked gewesen, was auch immer das bedeutet, müsste ja für die AMD auch gelten.
Allerdings haste Dir da den einzigen Screen rausgesucht, wo das so aussieht. Willst Du trollen? Sonst setz mal ganz schnell den 4K Screenshot daneben oder irgend einen RT Graphen. ;)
wenn die cpu aufgrund der verbauten nvidia gpu nicht durchdrückt, kann ich auch nix für
aw3423dw.
ich hab alles
vsync ist bei FG ausgegraut.
ich müsste auf 175hz stellen und dann ingame auf 144. ich würde aber gerne eine custom res mit 150 aber das nimmt der monitor gerade noch nicht an :d
joa der fps cap dann wohl nur über NVCP
Vsync kann man auch global im Treiber an machen
Schnelllllllllllllllllll
Grmpf ... gestern die non OC für 2299 bei NBB bestellt. Gerade eingebaut das Teil, fiept wie sonst was, noch mehr als die Suprim X, die ich hier hatte. Sehr schön verarbeitet und die Lüfter sind super! Haben sie die extra leise gemacht, damit man das Gejaule und Gebrutzel noch besser raushören kann? :d Sag' mal bitte Bescheid, ob deine auch so fiept :).
und das kommt FG dann nicht in die quere?^^
Hab auf 100HZ gestellt weil ich die 120 nicht halten kann mit RT und FG .
Spiel direkt im Treiber auf 97FPS max gestellt und Vsync an.
Das läuft super.
Bei dir kucken welche FPS du nicht unterschreiten Hertz anpassen im Treiber Spiel auswählen FPS Limit Max Limit setzen und Vsync setzen das sollte laufen.
Wird sie wahrscheinlich auch...
Ich zocke aber seit Jahren mit Kopfhörer @ANC von daher egal :fresse:
Kann man denn mit einem DE-Acc in UA was kaufen?
Ein Game aus UA als Geschenk zu einem DE-Acc geht nämlich nicht (wegen Preisdifferenzen)
Da denke ich, dass man mit Gift-Cards auch nicht weit kommt
Was aber geht, wäre ein neuer Acc
Stammt aus einem Forum... :cautious:
Stimmt das auch für UA? Dann käme man nicht um einen neuen Acc herum, oder?
Und weiter (KK ist tot)...
Das geht schon mindestens seit Mitte 2021 nicht mehr (Argentinien zumindest). Sehr merkwürdig, dass du meinst, es wäre bei dir bis vor einige Wochen noch gegangen. Kann ich nicht so recht glauben. Türkei vielleicht, da hab ich keinen Account.
Erst ging es noch, sich selbst vom deutschen Account Guthaben in Euro zu giften, und das kam dann auf dem zweiten Account in Landeswährung an. Wurde auch dicht gemacht.
Habs dann immer mit Guthabenkarten gemacht, das war damals nur mit sehr wenig Aufpreis verbunden (5-10%). Aber auch das ist inzwischen extrem viel teurer geworden (grad bei eneba geguckt, 400-500% Aufschlag), so dass sich das überhaupt nicht mehr lohnt, im ausländischen Store einzukaufen.
Ja und zu deinem Vorhaben mit der lokalen Kreditkarte - viel Erfolg dabei. Bin mal gespannt, wie du das machen willst, so ganz ohne Wohnsitz. Kanns dir auch gleich vorwegnehmen: Revolut geht nicht.
Ich nehm alles mit Revolut zurück...
Hab eben Hogwarts für 20,55€ über UA kaufen können :d
Ähnliche Themen
