[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Frage deines UV, theoretisch könnten auch 2 reichen ja. 3x 8Pins sind halt 450W und 4x 8Pins sind 600W.
Mit 3 Steckern ist bei 450 Watt Schluss, daher wird es mit 2x nicht funktionieren.
Hat der PCIe Steckplatz nicht auch 75W? Das wäre also 150W+150W+75W = 375W. Das ist etwas mehr als die Karte mit UV im Spielebetrieb braucht. Nicht das ich das mit 2x vor hätte, aber nur so theoretisch.
Meine Frage kommt daher, dass ich gerade eine 4090 FE gebraucht gekauft habe, wo aber der Adapter fehlt. Und im Netz scheint es immer nur 12vhpwr auf 3x PCIe zu geben, obwohl bei der FE offiziell wohl ein 12vhpwr auf 4x PCIe bei liegt. Aber denke, dass ich da auch problemlos ein 12vhpwr auf 3x PCIe nachkaufen kann und dann ist gut.
Hat er, die 4er Karten ziehen aber nur 5-10W darüber. Ob die im Zweifel sich da dann den Rest raus saugen... Try it :fresse:
Mit einem 3er Adapter wird über die sense pins des Kabels das PL dann halt auf 450W gelocked. Aber wenn du eh UV willst passt das ja.
Ach echt ja? Bin da nicht so drin im Thema. Wusste nur von damals, dass da auch 75W kommen sollten.
Das wollte ich hören. Bestätigt meine Theorie. Danke
Das ist schon krass, was es hier bei den Kabeln und Steckern für Qualitätsmängel gibt. Der Übergangswiderstand des Corsair Kabel wandelt den Spannungsfall direkt in Wärme um.
Die Corsair-Kabel sind schon voll in Ordnung, aber eben nur für 600W ausgelegt. Ich hatte ja mehrere hundert Watt mehr drauf :d
Und nicht nur der Stecker wurde warm (nicht heiß), sondern das gesamte Kabel!!! Sind ja nur 2 statt 3 oder 4 Strippen
Bei regulärem Betrieb reichen die Corsair dicke aus... ;)
Nahe unter 0 oder über 0 ?
Wenn über 0, wie können sich da Eiskristalle in einer Flüssigkeit bilden die extrem verwirbelt wird und in Bewegung ist Oo? Ich habe schon häufig bei 0Grad Wassertemp gebenched, aber Eiskristalle sind da nie entstanden, was meiner Meinung nach bei fliesendem Wasser in einem so kleine Kreislauf auch unmöglich ist, es sei denn du gehst unter 0.
Das Thermometer zeigte auch unter 0°C an... :fresse:
1-2 Minuten unter 0°C gingen noch. Bei den zwei anderen Fällen waren es gefühlt ~5 Minuten unter 0°C und zack, war der komplette AB und der Schlauch zu den Blöcken mit Einkristallen zu
Das Eis im AB sah aus, wie ein großer Block, war aber recht weich. Durchfluss war aber komplett bei null :oops:
Lüfter für eine Weile ausgemacht, bis sich das Eis im Schlauch zur 4090 im Schneckentempo weiter drückte. Solange bis alles wieder flüssig war. Hätte ein Video machen sollen - sah lustig aus :fresse:
Wenn das Kabel, wie das Corsair verschaltet ist und das NT pro Buchse 300W leisten kann, geht das
Bin nun auch Deadspace Remake am zocken . Läuft eigentlich recht rund bis auf paar Ruckler am Anfang . Mit Ultra und SSAO und 4K dlss Qualität bin ich dauernd bei 144 Fps . Dachte würde schlechter laufen , aber rennt echt gut .
Ist es normal das die Karte im Ruhemodus 80 Watt zieht?
Nein gar nichts. Habe auch den neusten Treiber drauf.
Eine 4090er passt ohnehin nicht zu Dir. Du solltest Dir lieber ein Schlagzeug kaufen, und jetzt troll woanders rum. ;)
Weil ich kein so Nerd bin, um zu wissen, dass eine 4090 nur 7,6W aus dem PCIe Slot zieht?
Ich habe mich hier lediglich erkundigt, weil das mitunter Dinge sind, die man leider so i.d.R. in keinen Testberichten & Co findet. Wo ist dein Problem?
Habe jetzt im NVCP auf Normal gestellt. Bin jetzt bei 40 Watt. Wie kann ich das denn noch weiter senken?
Habe ja neu gestartet. Ist nicht der Fall.
Hm…
Org. BIOS drauf? (1.000W-BIOS geht nicht unter 40W)
Hast du einen BIOS-Switch an der Karte? Dann mal den anderen Modus probieren. Aber normalerweise gehen beide Modis unter 10W bei Energie @Normal
Bios ist Original. Switch steht auf OC.
Was ist alles an Monitoren angesteckt und mit wieviel Hz werden die unter Windows angesteuert?
Switch auf Silent bringt nichts. Monitor ist ein Gigabyte F32U, 144Hz, HDR an.
Also ich habe jetzt mal auf 60Hz gestellt und HDR aus gemacht. Dann war ich bei 25W. HDR wieder an und wieder auf 144Hz gestellt 30 Watt. Damit kann ich leben.
Also bei 60Hz ohne HDR hatte meine FE unter 10W, alle anderen 4090 16 bis 20W.
Ja, die 4090er ziehen selbst im IDLE viel Strom.
20W wäre so der Standard. Bei 144Hz eher bis 30W. 60Hz also um die 20W
Sobald im Browser nen Video guckst usw. geht sie auch schnell mal auf 50W, 70W, 90W, usw.
Mein Rechner verbraucht nur zum Browsen (z.B. Youtube) ca. 150W (inkl. 4k IPS HDR 144hz Bildschirm)
Bildschirm ca. 40W, der Rest ca. 110W (Im Stromsparmodus). CPU ist nen 13900K
FHD oder WQHD Monitor?
Ähnliche Themen
Antworten
6K
Aufrufe
392K
