[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ich würde Asus nicht gleich die Kompetenz absprechen, so eine Karte zu bauen und leise zu halten. Meine 3080 TUF hat zwar "nur" bis zu 370W aufgenommen, aber ihr Kühler, und der war nochmal etwas kleiner, blieb selbst im Hochsommer stets sehr leise und meistens auch nicht hörbar.
Anfangs gingen mir die großen Kühler der 4090 auch auf den Sack, aber nachdem ich das Case gewechselt habe, überwiesen für mich auf jedenfall die Vorteile.
Es wird aber einen Markt für die Karte geben. Die FE ist ja nochmal ne Ecke kleiner, Ventus und XL8R ungefähr so groß wie die kleine TUF hier. Und die sind auch alle schön leise. Also das wird ne gute Karte.
Wie gesagt, wenn das Spulenfiepen nicht wäre, dann wär die 4090 die beste Karte aller Zeiten. Bzw. wer so eine bekommen hat und keinen Ghettomod für die Lüfter braucht, hat ein Sahneprodukt. Punkt.
Ist halt die Frage ob man das bei der nächsten Gen wieder so Klasse macht oder man plötzlich abspeckt.
Ist in meinen Augen keine Frage, wird nicht mehr so grosszügig sein, denn die Karte war ja wohl im alten Verfahren geplant und hätte 600 Watt @Stock gezogen.....
Genau DARAUF sind die bisherigen Kühler ausgelegt, man kann die doch glaube ich auf Performance / 600W hochschraueben, vom Kühler her gehts.
Nur die Änderung des Herstellungesverfahrens und des Herstellers hat den Ausschlag gegeben, das die ca. 450 Watt @Stock benötigt, und somit war der Kühler also überdiemendioniert, und eigentlich natürlich zu teuer, aber eben schon geplant / gekauft.
Wundert mich sogar das die das erst korrigieren....... Wird sicher so nicht wieder kommen, mach dir da mal keine falschen Hoffnungen. NVIDIA und Konsorten sind nicht gerade dafür bekannt, das die gern "Geld zum Fenster raus schmeissen".
Bin auch mega tempted mein Setup von Wasser auf MiniITX mit Luft umzubauen, vor allem da die 4090 Kühler ja absolute monster sind und daher auch fast lautlos...
Moin!
Habe seit gestern eine PNY 4090 und habe ständige Probleme mit Frametime-Spikes.
Machen sich auch in kurzen Rucklern bemerkbar.
Dies habe ich bei meiner 4070ti nicht wahrgenommen.
Habe schon mehrfach per Abgesicherter Modus und DDU den Treiber deinstalliert und neu installiert.
wo springen denn die fps hin und her?`ich würde die fps unterhalb des hardware limits cappen.
Was meinst du mit HW Limit? FPS lagen zwischen 110 und 150FPS
Die Spikes fühlen sich an wie kleine Ruckler
hmm schwierig von hier das optimal zu erkennen.
ich spiele niemals uncapped und setze das fps cap immer unterhalb dem CPU und dem GPU limit damit ich keine solche sprünge habe
Moin!
Sowas hatte ich bei der 40 Generation häufiger nach einem Wechsel der Graka.
Lösung: Treiber mit der Option Neuinstallation drüber installiert. War dann immer weg.
Jup, wäre das sinnvollste. Luftkühler sind bei mir immer Ressourcenverschwendung.
...dazu wahlweise CPUs mit und ohne IHS :d
Minimum 12GB VRAM:
Wenn man diese Quali noch in VR hätte, wäre das ziemlich geil...
Der Spaß und Gruselfaktor mit der PSVR2 wäre sicher genauso hoch
Derweil bin ich darauf schon sehr gespannt - da brauchste keinen Herzschrittmacher mehr... :oops:
Und dank Eyetracking muss die HW nicht so extrem performant sein, da nur Teile des gesamten Sichtfeldes scharf dargestellt werden, die im Focus der Pupillen liegen (klasse Feature)
Ich bin kurz davor die 10% shoop zu nutzen um mir ne 4090 einzutüten. Vernünftig ist es aber trotzdem eher nicht...
Wie läuft denn Star Wars inzwischen, kann man das jetzt spielen auf PC?
der patch hat das das cpu limit massiv angehoben.
ja
90 fps vorher, selbe szene 135fps
Noch 1-3 Patches und dann dürfte es langsam aber sicher laufen, Beta Tester sind was feines 👍
(Anderseits sind diese Beta Tester/Day one Käufer/Vorbesteller natürlich massiv Mit-Schuld an den ganzen kaputten Games, sollte nicht unerwähnt bleiben 😏)
es zuckelt aber trotzdem noch hier und da. shader dies das
ich habe heute eine 4090 TUF eingebaut. Dazu habe ich zunächst den bestehenden Wasserkreislauf für die Grafikkarte mit einem Bybass versehen, da der Watercool-Block erst Mitte Mai verfügbar ist.
Netzteil ist ein Seasonic TX Prime 850W mit Seasonic 12VHPWR-Adapterkabel. Board ist ein Asrock X570 Taichi mit 5950x CPU.
Der Rechner startet aber mit der TUF nicht. Das Board ist die Revision mit dem idiotisch im Überhang des Grafikkkartenslots platzierten USB-3.2-Anschluss.
Da die Karte so riesig ist, fällt es schwer zu beurteilen, ob die Karte richtig im Slot sitzt oder hinten an dem USB-Anschluss aufliegt. Slotblech passt und die Arretierung des Slots ist auch eingerastet.
Oder doch ein Netzteil-Problem? 850W zu wenig? Habe leider kein stärkeres Netzteil zum Testen da.
Jedenfalls habe zunächst wieder auf Wasser umgebaut und die alte 3080 Strix wieder im Einsatz. Da kommt Freude auf. :rolleyes:
Hier ein Update: Habe jetzt eine 4090 FE. Die Karte läuft problemlos mit dem Seasonic 12VHPWR-Adapterkabel. Macht keine Spulengeräusche und ist auch schon unter Wasser (Watercool). Alles bestens.
@Digitalsurfer : Wie sind die Temps unter Wasser? Wie groß ist der Radiator?
Ähnliche Themen
