[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Dann mach halt DLSS3 an dann klappts auch mit den 100 %
Klar beeindruckend aber halt nicht wie verkündet! Ist leider so. Die Leistung kommt nur wegen DLSS 3 zustande also das Marketing von NVIDIA aber nicht nativ
Das sind non dlss benchmarks
Bei farcry ist wohl was schief gelaufen
Manche Games reagieren auch unterschiedlich, teilweise bis an die 80 Prozent + ggü der 3090TI
Also ich bin komplett überzeugt, das Ding kommt morgen "hoffentlich" in den Sack!!
Leistung ist geil aber mir fehlt aufgrund mangelnder neuer Spiele dieses "ich brauch es unbedingt" Gefühl.
Was mich am meisten beeindruckt sind die 350Watt Tests von Computerbase.
der8auer EN
der8auer
Leider geil, mit 350W 80% schneller als meine 3080Ti bei 350W in 4k.
Brutal wie viele CPU Limits man in 1440p mit der 4090 findet.
Werde trotzdem auf RDNA3 warten und dann das beste Gesamtpaket aus Leistung, Verbrauch und Preis kaufen.
Mein backlog ist voll. 120fps in uwqhd überall wäre schon saftig nice.😆 aber ich kann keine 2k ausgeben 🤪
Jo, Guru3d am Ende. Fiept wie bei der 3090 TI, für sie nicht störend.
Hmm, schade. Hatte gehofft Nvidia hätte evtl. was verbessert diesbezüglich. Bleibt abzuwarten wie die Suprim X sich hier schlägt, da MSI ja damit wirbt spezielle Komponenten zu verbauen um Spulenfiepen zu reduzieren.
Edit: PCGH schreibt diesbezüglich:
Spulenrasseln respektive -fiepen ist bei modernen Gaming-Grafikkarten immer, aber in deutlich unterschiedlicher Ausprägung zu hören. Wenig überraschend stimmt die mit hohen Strömen arbeitende Geforce RTX 4090 Founders Edition in diesen Chor mit ein. Was die uns vorliegenden Muster angeht, ist das Störgeräusch (im Englischen "Coil Whine" genannt) etwas auffälliger als bei der RTX 3090 Ti, aber leiser als bei der diesbezüglich besonders markanten ersten Revision der RTX 3090 und RTX 3080. Bei üblichen, zweistelligen Bildraten ist ein leises Zischen wahrnehmbar, bei vierstelligen Bildraten (welche man mittels Framelimit vermeiden sollte) schließlich ein Fiepen. Wir haben uns dazu entschlossen, das bisher nur im textlich erwähnte Fiepen künftig immer in die Lautheitstabelle mitaufzunehmen, wie oben geschehen.
Besser als 3080 und 3090 FE ist ja schon mal etwas.
Das was am besten ist das er mit 350Watt kaum Leistung verliert.
Find ich super! Aufgrund der aktuellen Strompreise
Keine Reviews von Boardpartnern heute, Preis der FE deutlich unter Customs, nur Abzocke. 2-4 fache Leistung, is klar.
Das ist ja nur der base Clock. Boost ist dann wahrscheinlich bei ca. 2800. Mit OC dann 3000. Kann mir gut vorstellen, dass 3000mhz mit 1v der neue golden sweetspot wird :)
War ich gar nicht so schlecht am 19.9 mit meiner Einschätzung :)
350W und 3000 mhz. Karte wird nicht kälter als 58-60 Grad unter Air. Was ein Traum :)
Brutal gut! Weitaus besser als ich erwartet habe. Für mich wird ne 4080 16GB locker ausreichen und das sogar mit meinem 650W Netzteil voraussichtlich.
Ich bin leicht gedämpft. Viel Leistung je nach Titel ist da. Aber ich glaub mehr als die 1950€ will ich echt nicht ausgeben. 2500€ für ne Strix wird mir da doch zu viel.
FarCry und Metro sind hoffentlich einfach noch nicht optimiert. FC6 wollte ich spielen^^.
Wer ca. auf 10% Leistung verzichten kann, kann die 4090 mit etwa 285W laufen lassen. Und wenn ihr das ganze gut testet mit Undervolting + OC, dann habt ihr am Ende wahrscheinlich nur 5% weniger Leistung, aber 140W weniger Vebrauch :)
Danke an @der8auer für diesen tollen Extratest.
Na wo sind die armen Seelen die glaubt haben die 4090 hätte die vierfache Leistung der 3090 TI :ROFLMAO:
Ich wurde noch belächelt als ich sagte das es nur 30 - 40 % wie immer ist, sehe nichts von vierfach. DLSS3 auch noch nicht ausgereift zumal ich sowieso davon nichts halte. Viel Spaß als Beta-Tester für 2500 € ich steige in 2 Jahren auf die beste 4090 für 1000 € um.
Ach Mano kann noch nicht Morgen sein, ich will endlich meine 4090 bestellen.:giggle::coffee3:
Ich dachte das "vierfach" bezog sich immer auf Cyberpunk mit DLSS3 aktiviert? Es hat doch nicht wirklich jemand an "vierfach" ohne DLSS geglaubt, wo hätten die denn herkommen sollen?
Ohne DLSS hätte ich irgendwas zwischen 50% und 100% erwartet aber keinesfalls mehr.
Du hast wohl noch immer nicht verstanden das die vierfache Leistung nur mit DLSS 3 Kommuniziert wurde. Machst deinem Namen hier wohl alle Ehre. Niemand hat vierfache Rohleistung erwartet. Die Rohleistung wurde im Schnitt sogar noch übertroffen. Teilweise weit über 60% vor der 3090 Ti. Das hätte ich nicht erwartet. Morgen wird das Teil sofort gekauft. In 2 Jahren bin ich dann schon bei der 5090.
Ich find das auch alles voll Abzocke und blöd und so, morgen bloß keiner um 15 Uhr versuchen eine zu bekommen. :d
Ähnliche Themen
