[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Mein Nachbar hat sich eine MSI Suprim X von Amazon geholt, nachdem er meine FPS mit der neu erworbenen Zotac gesehen hatte ;) Leider pfeift und knistert seine sehr. Getriggert z.B. durch Mausbewegung auf dem Desktop. Vielleicht wird es noch besser wenn sie mal von Benchmarks richtig durchgebacken ist. Optik, Anschluss und Lautstärker der Kühler: einwandfrei!
Gibt mir kein gutes Gefühl, das Corsair-Kabel.
Das übrigens genau so lange in Betrieb ist wie die Karte. Also gute 8 Monate. Ich hab die Karte nie mit dem Dreizack angeklemmt gehabt. Das Corsair-Kabel war vor der Karte hier.
Bisher noch nichts negatives beim Corsair Kabel beobachtet .
Inzwischen habe ich aber auch ein weißes das kommt mir noch ein wenig flexibler vor.
Aber gut zu wissen was einen für Probleme Heim suchen können.
Bin Mega zufrieden mit der 4090 FE die läuft mit 2760GPU bei 0.975V und +1000 auf dem RAM vor sich hin .
Das ist doch super. Wie viel schafft sie denn bei 0.875V und was bringen die +1000 in Benchmarks oder in FPS?
Hab das Mal ausprobiert hab es aber nicht mehr in Erinnerung wollte lieber einen Mix aus OC und Undervolting so das die Karte nicht so gestresst wird @Air aber ein wenig Mehrleistung als Stock hat.
So bin ich deutlich Sparsamer aber ohne Leistungsverlust unterwegs.
Gibt jetzt auch ein Hand On von Roman. Sieht schon geil aus :d
Kann den AIO nix abgewinnen irgendwie .
Meistens Problem behaftet laute Pumpen schlechte Lüfter usw. bin Mal gespannt wann die 4090 TI kommt.
Ich suche das Galax 666W Bios, kann es aber hier nicht finden:
Kann da einer helfen?
Meinst du das?
und wenn die pumpe stirbt, have fun
umbau auf custom nicht möglich. anschlüsse passen nicht und das PCB ist kein strix pcb.
Genau das habe ich mir beim Schauen des Videos auch gedacht. ...und dann hat das Ding auch noch nen Alu-Radiator. Bei dem kosmischen Preis, der zu 100% aufgerufen wird, könnte man wenigstens bessere Komponenten verbauen.
Warum sollte es kein Wasserblock für die Matrix geben?
weil ich kaum glaube dass die wakü hersteller für eine karte, die noch weit weniger verkauft wird als ne 4090 einen kühler basteln werden. vor allem blechst du bei dem ding ja gerade für die aio unmengen geld.
wäre das ein strix pcb kann man bei einem defekt der aio später eventuell noch mit einem erhältlichen günstigen kühler die karte retten. luftkühler gibts ja auch keinen den man von einer defekten strix/tuf nehmen könnte
Ok also hier keine Begeisterung für die Karte, dann mal sehen ....
Dass Asus den Stromanschluss aufs MB verlegt, finde ich eine super Idee. Allerdings dass sich die ganzen Anschlüsse (also USB/24-Pin/CPU etc) auf der Rückseite des MB befinden, wird sicherlich schwierig sein, das in den Markt zu platzieren, da es ggf. spezielle Gehäuse/Durchgänge benötigt. Aber vielleicht wird ja der erste Teil umgesetzt - was aber auch zur Folge hat, dass eventuell nur ASUS GPUs das unterstützen...
Dass Asus den Stromanschluss aufs MB verlegt, finde ich eine super Idee. Allerdings...
zumal die Anschlüsse so um das Board herum verbaut sind dass man sich fragen sollte wie danach der MoBo Tray noch hält :confused:
Wenn die alle in einer Ecke wären könnte man das auch bei aktuellen Gehäusen mit dem Dremel "nachrüsten" :fresse:
ich hatte mich tierisch auf die Karte gefreut, da die ja später auch mal in die Matrix Sammlung sollte, aber das Ding ist für mich eher eine Poseidon.
Die hat mit bisherigen Matrix Karten ja nicht wirklich etwas gemeinsam (n)
IMG_3857.JPG IMG_3973.JPG (dass das mit dem Dual-Kühler nix mehr wird ist klar, aber...)
Die Begeisterung wird bestimmt in Gelächter umschwenken wenn dann der Preis bekanntgegeben wird :p.
Dann gehen alle eine HOF kaufen :lol:
Ja, weil AIO. Und hier steht Asus nicht alleine da, wobei ich vermute, die anderen Hersteller werden ihre Standard-Layouts für ihre AIO-Karten benutzt haben.
Ich finde den Trend überhaupt nicht gut. Wenn ne AIO auf ne Karte, dann die Alphacool-AIOs.
Anstatt den Fokus auf AIOs zu setzen, sollten die lieber mal Karten mit Wasserblöcken auf den Markt bringen. Gigabyte hat nur die 4080 mit Block und bis auf Inno gibts da nicht.
Ich finde es mittlerweile etwas heuchlerisch von den Hersteller wenn ich mir "mal wieder" die Bilder und Videos der Computex anschaue und drölfmillionen Builds mit Wasserblöcken sehe, aber keine Karten seitens der Hersteller und dann die Geschichte mit der Garantie bei Kühlerwechsel. Also schön einen auf Wasserkühlung machen und dann aber mit so blöden AIOs um die Ecke kommen.
Wenn die Dinger wenigstens irgendwie wartbar und erweiterbar wären, nee die sind so produziert, dass man die Dinger dann einschicken darf, weil sonst Müll.
Mir würde schon ein Stromanschluss reichen, der stabil und sicher ist und so an der Karte, dass er nicht am Case anstößt.
Wir haben ein echtes Meisterwerk von Chip mit fast 80 Milliarden Transistoren und der Stromanschluss dafür war scheinbar nicht vernünftig zu lösen?!
Die 4090 ist ja nun auch schon über ein halbes Jahr alt. Mit so einem Sondermodell ohne Mehrleistung lockt man jetzt kaum noch Leute hinter dem Ofen hervor. Selbst eine 4090 Ti müsste schon zeitnah kommen, um noch ein bisschen Interesse bei mir zu wecken. Ansonsten kümmert mich eigentlich nur noch die nächste Generation.
Na dann hättest du deinem Nachbarn den Rechner vorher richtig zusammenbauen sollen :) Störgeräusche bei Mausbewegung haben in der Regel eine andere Ursache.
Hatte das schon in Verbindung mit VRM vom Board . Das kann vorkommen und ist lästig .Allerdings noch nie im Idle spulenfiepen bei der Graka .
Darf ich fragen welche? Ich bekomme zwar die Rechner vernünftig zum laufen, aber so tief bin ich nicht in der Materie. Mit seiner "Alten", also einer 2080 TI war nichts am zwitschern. Auch nicht mit dem neuen Netzteil, ein 1000W Pure Power beQueit.
@fred8a
Bin sehr zufrieden mit meiner Gigabyte Gaming OC ansonsten soll die PNY extrem leise sein in Betracht auf Spulenfiepen und die Lüfter sollen die leisesten überhaupt sein.
Die Spulen machen vor allem bei stärkerer Last mehr Geräusche, gehen die Frames hoch oder die Stromaufnahme steigt, dann schwingen die Spulen stärker und können eben Geräusche erzeugen die störend sein können.
Wenn bei der Mausbewegung da vermehrt was zu hören ist(Ggf. ist das ja nur eine falsche Schlussfolgerung), dann tippe ich eher auf ein Masseproblem. Mainboard nicht richtig eingebaut, Gehäuse Marke Billigheimer, lackiert, so das kein Massekontakt von Mainboard zum Gehäuse besteht oder auch irgendwas externes spielt da rein was nicht richtig geerdet ist, Steckdosenleiste, Steckdose, Lautsprecher oder sonstiges.
Wird die Last eben auf mehr Spannungswandler aufgeteilt, dann bleiben sie Kühler, frag mal mein Z790 Master. Bei der Suprim wird es schwer da mehr unterzubringen.
Bei der 4090 Founder edition werden 10 Phasen auf 20 Spannungswandler aufgeteilt, die SuprimX legt da noch einen drauf mit 26.
Die Geräusche die ihr hört sind ja Schwingungen, wie Schall eben so übertragen wird, und da hat man mit mehr Krachmachern auch eine höhere Chance das man was hört. Hat ja absolut nichts mit der Qualität zu tun, was viele hier verwechseln. Ist manchmal auch einfach Glückssache da der Schall ja übertragen wird, Karte X hört sich auf 2 Systemen ggf. ganz anders an.
Trotzdem in vielen Fällen absolut inakzeptabel, da sehr nervig und ohne geräuschunterdrückende Kopfhörer während des Spielens nicht aushaltbar. Meine Suprim X damals bei Release war eine Katastrophe und egal bei welcher Last durch die Spulen super laut + klackernde Lüfter!
Oh man, ich habs schon wieder getan :stupid:
Eigentlich war ich auf der Suche nach einer 4080 für mein WQHD System, aber bei 1589€ für die GameRock OC im Mindstar konnt ich gar nicht so schnell lesen, wie ich geklickt habe ^^
Also wieder das CableMod Vertical Mounting Bracket für 3 IO-Slot Karten zurecht flexen und dann rein damit plus Nvidia Krake.
Sieht gar nicht mal so übel aus. Dazu hab ich sogar ein gerades Exemplar erwischt, also keine :banana:
Lüfter sind ganz gut, leichtes niederfrequentes Brummen der Motoren wahrnehmbar, aber nicht wirklich sackgängerisch.
Spulenfiepen vorhanden, aber sehr dezent bei 200+ FPS (kein Vergleich mit meiner Suprim X vom Anfang).
Kann mir jemand verraten, wo bei der Karte der BIOS Switch sein soll???
Palit schreibt was von Dual Bios oder ist das nur softwareseitig erreichbar? Hab nur den 3 Pin ARGB Anschluss neben dem 12VHPWR Anschluss entdecken können.
Was mich auch etwas erstaunt zurücklässt, ist die GPU Punktzahl im normalen TimeSpy mit dieser Karte @Stock
Normaler Timespy (GSYNC und VSNYC aus):
FE@Stock: 35,9K GPU Punkte (@UHD)
Suprim X@Stock: 36,9k GPU Punkte (@UHD)
GameRock@Stock: 38,0k GPU Punkte (@WQHD)
:unsure:
Kann das an der Auflösung liegen?? CPUs sind identisch und RAM auch so gut wie...
Ähnliche Themen
