[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Gibts bei Gigabyte und Nvidia auch nicht, und trotzdem machen sie keine Probleme. Kommt halt immer drauf an wie Du arbeitest denke ich.
Sieht man das der Lüfter runter war, oder sieht man es nicht.
Die TUF scheint ein mieses Produkt zu sein, bist ja hier nicht der erste mit einer kaputten TUF. Gut das ich mit eine Inno und keine Asus geholt habe.
wie viele TUFs sind denn hier kaputt gegangen ? Habe jetzt zwei gehört die auf Wasser umgebaut wurden . Luft Karten auch dabei ? Meine bei Inno habe ich hier und da auch von Defekten gelesen . Auch bei Zotac oder PNY habe ich schon hier was gelesen . Also wenn ich jetzt von zwei höre bekomme ich noch keine Panik ^^
Eventuell gibts ja als Austausch eine ohne das hässliche Spulengerassel^^
Nachher kühlt der Phantek-Kühler ein wichtiges Bauteil nicht, und das zerbrät über die Zeit. :-)
Hatte eigentlich richtig Bock auf die RTX 4090 extreme waterforce aber leider hat sie im Gegensatz zur 4080 extreme waterforce kein RGB 🤬💩
Richtig schade!
Meinst mit dem Hochdrehen der Lüfter? Hatte zwar eine Master aber da gab es auch 2 einfache Lösungen.
1. RGB der Lüfter abschalten
2. Eigene Fan Curve erstellen.
Schau mal hier:
Leider sind Russische Webseiten gesperrt und da kriegt man auch keine verläßlichen Info's. Daher muss es was in englisch tun.
Eine Zensur findet nicht statt und so 8-) Gerade meinen Opa auf dem Friedhof besucht, der liegt verkehrtrum im Sarg. Z
так тебе и надо :sneaky:
Hast ja gesehen was dabei rauskam ))
On-topic: hat jemand kürzlich eine Gigabyte 4090 Gaming OC gekauft und ein neueres BIOS as die auf Techpowerup? Würde gerne wissen, ob es auch mit neueren Chargen noch Probleme mit der Lüftersteuerung gibt.
Wähhz .. meine Tuf gibt auf.
Geht nach 10 Sekunden Last aus. Manchmal auch nach längerer Zeit am Desktop. Mit dem Disconnet Geräusch von Windows.
Rote Lampe am Stromanschluss geht Flackernd an.
Rechner läuft weiter, kann ich mit Blind Alt F4 Return runterfahren.
Ausbauen, Wakü runter, RMA. Hab ich ja gar keinen Bock drauf. Und das nach gerade mal 8 Monaten Betrieb.
Hmmm....
Scheinbar gibt sie doch nicht auf,
ich hab heute den Rechner geöffnet und mal alle Kabel und die Karte nachgedrückt (war bombenfest im Slot, und das Stromkabel hat sich keinen mm in der Buchse bewegt) und dann ...
am Kabel gewackelt
Und jetzt geht wieder alles?
Willst Du mich verarschen?
Gibt mir kein gutes Gefühl, das Corsair-Kabel.
Das übrigens genau so lange in Betrieb ist wie die Karte. Also gute 8 Monate. Ich hab die Karte nie mit dem Dreizack angeklemmt gehabt. Das Corsair-Kabel war vor der Karte hier.
Naja. Wenigstens spare ich mir jetzt erst mal die RMA^^
@HisN
Stecker und NT hätte ich als Erstes gecheckt… :d
Den Block hast du anscheinend noch nicht runter gemacht
BTW hatte ich schon viel seltsamere „HW-Probleme“, die sich ohne mein Zutun gelöst haben (zuletzt nach dem Delid, des 13900K mit error 55)
Hmmm....
am Kabel gewackelt
Es gab schon so einige YouTube-Videos von 4090en, die wegen Wackelkontakten am 12VHPWR-Kabel solche Probleme hatten. Eine kleine Berührung an den Strängen und es läuft wieder. Scheinbar eine Problematik mit der Verbindung der Sense-Pins. Vielleicht bist du da nicht alleine.
Hatte noch keine Probleme mit dem Corsair Kabel. Hatte auch bisher noch nicht , dass die rote LED an meiner TUF leuchtete auch wenn der Rechner aus war.
Das Kabel scheint ja generell eher mangelhaft designed zu sein - bin echt mal gespannt was Sie dann mit der 50X0 Serie machen und welches neue Kabel wir uns dann kaufen dürfen... :d
Hab aber seit meinem Umstieg von Cablemod-Kabel auf das Corsair (gesleeved) gar keine Probleme mehr. Freu mich auch nicht darauf, wenn die wieder kommen sollten.
Bin aktuell aber am überlegen meinen Wasserkühlriesen zu verkaufen um mir nen Build mit Dan C4 SFX Case zu basteln... so n kleines Case mit brachialer Leistung hat doch schon seinen Reiz.
nutze ein cablemod kabel vom seasonic nt direkt zur 4090. einwandfrei (auch ne tuf)
Gibt es aktuell eine "eindeutge" Empfehlung hinsichtlich einer ruhigen 4090?
Meine Tendenz ist die MSI 4090 Suprim X. Gibt es Meinungen von Euch.
Welches Corsair Kabel hast du denn? Sleeved oder standard? Ich hatte Probleme mit dem standard Kabel. Das funktionierte an Tag 1 schon direkt nicht. Das sleeved hingegen lief ohne Probleme.
Ist das standard-Kabel. Ich meine, ich war da seit längerer Zeit nicht dranne, und dann plötzlich ein Wackler? Weil es draußen warm ist oder was? *ggg*
Gibt es aktuell eine "eindeutige" Empfehlung hinsichtlich einer ruhigen 4090?
Eindeutig ist eigentlich gar nichts, jedoch scheint eine magerere Spannungsversorgung eher für ruhige Karten zu sorgen (Palit, PNY, etc.).
Die Suprim X ist für Rasseln ebenso berüchtigt wie die Strixen.
Ein Kompromiss der für viele funktioniert hat sind Gigabyte-Karten, wo selbst die größten Karten einigermaßen ruhig zu bleiben scheinen. Nur die Lüftersteuerung hat manchmal ihre Macken. Oder du nimmst einfach eine der billigen. Auch hier werden gute Chips verbaut.
Das Kabel hat bei mir auch zu 99% funktioniert, bis es eben nicht mehr funktioniert hat. Hab es mehrfach neu eingesteckt (sowohl NT als auch an der Karte) und nach ner Woche hatte ich immer wieder das die DWM.exe abstürtzte (nicht reproduzierbar) und seit dem ich das Kabel gewechselt habe hatte ich nie wieder nen Fehler. Gab hier auch schon mehrere Threads in die selbe Richtung, wo das Cablemod Kabel mangelhaft war. Ist kein großes Ding, glaube der Stecker ist einfach an sich im Beta-Status.
Die PNY Karten sind ziemlich laufruhig was lüfter angeht und du hast ne erhöhte Chance ne Karte zu bekommen die nicht störend fiept. Würde mir, sofern ich ne neue Karte kaufe, diese kaufen.
Eindeutig gibt es leider nicht. Aber es gibt eine Tendenz. Habe mich wegen dem Coilwhine Ada Thread für eine PNY 4090 Verto entschieden. Bin was Kühlung, Lautstärke und Fiepen angeht bestens zufrieden 👍🏻
Asus ROG Matrix bereits auf Geizhals gelistet:
Finde die siht echt nice aus und würde gut in meinen fast Full Asus Build passen... :LOL: Weiß man den Preis? Wird sich aber wohl nicht lohnen die zu kaufen und FE Verkauf... das sind sicher wieder 400-500€ Differenz. Muss ja echt nicht sein.
2500 mindestens
weil ROG, weil matrix, weil special design
Tippe auf mindestens 3K, dachte aber die sollte erst Ende Q3 kommen!?
Hätten aber eher einen sehr guten Custom Wasserblock machen sollen statt mit AIO .
Wenn man so liest in älteren Threads und manche Videos vom Roman Hartung angeschaut hat , haben sich die AIO´s bei den Grafikkarten
einfach nicht bewährt. Wenn ich sowas auf der CPU habe und die geht defekt habe ich jede menge Alternativen.
Naja, die Suprim X AIO hat ja dasselbe Layout wie die Air. Also mal abwarten.
Ja das hat mich bisher auch von AiO GPUs abgehalten.
Die wichtigste Info fehlt imho noch: Soll dann im September diesen Jahres raus kommen.
Ähnliche Themen
Antworten
6K
Aufrufe
381K
