daysleeper83
also nach dem Test hier bin ich bitter enttäuscht...
http://anandtech.com/cpuchipsets/showdoc.aspx?i=3153&p=1
Ich würde noch nicht so all zu viel auf die Benchmarks geben. Nehmen wir mal den Anandtech Bench:
Pov Ray Rendering Anandtech
Intel's Q6600 is 20% faster than AMD's fastest Phenom due out in Q1, it's 30% faster than Phenom at the same clock speed, and 35% faster at the most competitive price point.
Pov Ray Rendering Techreport
We caved in and moved to the beta version of POV-Ray 3.7 that includes native multithreading. The latest beta 64-bit executable is still quite a bit slower than the 3.6 release, but it should give us a decent look at comparative performance, regardless.
The pendulum swings the other way in POV-Ray's chess2 scene, where the Phenom 9600 finishes 21 seconds ahead of the Q6600 and the Phenom 9900 bests Intel's Core 2 Extreme QX6850. Intel's new 45nm Penryn-based Intel processors are faster still, however.
The benchmark scene is largely a single-threaded affair, which helps explains the Phenom's relatively slow performance.
Der 2. Test läuft überwiegend auf einem Thread, daher die schlecht Ergebnisse
Also von Pfui bei Anandtech auf Hui bei Techreport. Meints net, dass das etwas komisch ist? Dazu noch die IMC Probleme etc pp.
