Openelec.tv super schmales XBMC mit fast boot
OpenELEC 3.2 released
Whats new in OpenELEC 3.2?
Like OpenELEC 3.0, the 3.2 release is based upon XBMC Frodo (12.x) but “under the hood” it includes many notable changes:
Many feature enhancements and bugfixes to XBMC Frodo; including a number of backports from Gotham and speed improvements for RaspberryPi users
Linux kernel 3.10, bringing many new and updated drivers and improvements
Mesa-9.2
ALSA 1.0.27 (thanks to Anssi Hannula for various fixes and improvements)
Updated graphic drivers from AMD, Intel and nVidia
Updated and improved pi firmware (thanks to Dom Cobley)
Updated drivers and driver firmware
Updated XVBA, VDPAU and VAAPI libraries
Intel VPP (Video Post Processing API) support by Timo Rothenpieler (thanks also to various Intel developers like Haihao Xiang)
Support for many more remotes and keymaps
Initial PPTP and OpenVPN support (via connman)
Wireless tethering support (on WLAN cards that support it)
Completely reworked networking
Completely reworked bluetooth with support for more remotes
Added support for bluetooth keyboards and file transfers
Boot speed improvements for all platforms (particularly Raspberry pi)
Many bugfixes and package updates
OpenELEC has been working closely with several AMD engineers and our special thanks go out to Jamy and Sabre for their constant support and attentive listening. You may have spotted this on the changelog for the 13.6 fglrx driver:
[377379] Fix the regression of performance drop with XBMC for UVD playback, which was the direct outcome of their constructive work. Thanks also to Peter Frühberger (fritsch) and Rainer Hochecker (FernetMenta) for their work.
Wie erwartet gibts mit Haswell keine 24p Probleme ;)
und nun zurück zu OpenElec :angel:
ich hab grad gesehen, die 3.2.1 ist raus...
damit sollte jetzt auch das remote.xml und keyboard.xml gelöst sein...
Na dann viel Erfolg ;)
Jetzt weiß ich auch wieso ich mit 3.2.0 Probleme hatte meiner TV Karte (S471)
Hier das Changelog:
http://openelec.tv/news/22-releases/108-openelec-3-2-1-released
Changelog
update to xf86-video-intel-2.99.903
update to xbmc-12.2-cd71444
update to linux-3.10.13
update to service.openelec.settings-0.2.16
update to bcm2835-bootloader-86e7643
update to bcm2835-driver-86e7643
update to llvm-3.3
update to libva-driver-intel-1.2.1
update to libaacs-0.6.0, convert to new package format
update to libbluray-0.3.0, convert to new package format
update to wlan-firmware-0.0.14
update to fuse-exfat-1.0.1
update to timezone-data-2013d
update RPi kernel patch
downgrade to xf86-video-fglrx-12.10
downgrade to curl-7.31.0, this should solve non working FTP sources in XBMC
linux: fix setting up ondemand up_threshold value
linux: add support for Ubiquiti WifiStation
linux: mac80211: ignore (E)CSA in probe response frames, this should fix #2617
busybox: prevent cdrom from autoclose, this should fix #2510
Fixed eventlircd's 03_0755_2626.evmap to make most of the buttons of iRF Media Technology W-01RN_USB_V3.1 IR remote work out of the box.
bluez: fix udev rule for logitech keyboard support, this should fix #2599
eventlircd: add support for MS-Tech remotes
kmod: add patch to support /storage/.config/modprobe.d
v4l-utils: added some keys to rc6_mce map for xbox360 slim black remote, fixes #2331
eventlircd: update holtek remote mappings
linux: fix tevi s471
eventlircd: set default first repeat to 1000ms to avoid double keypresses on some remotes
xbmc: After suspend wait for the first NIC to come up before continuing
projects/*/linux: remove PSTATE support again
bcm2835-bootloader: fix create sdcard script
udevil: add 'nonempty' option for exfat
udevil: support mounting disks without partition tables
ich habe jetzt mit der 3.2.1 eine Einblendung unten links am TV...
"unsupported Hardware"
Wie bekomme ich die denn weg?
die Erklärung für das Wasserzeichen gibts hier...
Mal schaun wie schnell das gefixed wird...
Nein bin ich nicht, habe aber nichts anderes gefunden.
Ich habe gestern mal ein update auf 3.2.2 gemacht...
das positive, das Wasserzwichen von AMD ist nun weg...
allerdings hatte ich danach ein parr mehr Probleme...
1.) ich habe eine Asyncronität von Bild und Ton
2.) ich habe permanennte LAN abbrüche zwar nur kurzzeitig aber spürbar...
3.) ich habe massive artefackte bei den Sky HD Sendern (werden über VDR und sc-Plugin encodet)
4.) meine Lüfter drehen um einiges höher als vorher... (muß ich nochmal die Bios Einstellungen überprüfen)
Ich bin ersteinmal auf die 3.2.1 zurück auch wenn ich hier das Wasserzeichen habe aber mit der Version habe mit abstand das beste Bild im LiveTV
Sveni_Lee
Hast du mal 3.0.6 versucht oder 3.1.6?
Mit der 3.2 gibts irgendwie momentan sehr viele Probleme.
nee, hatte ich noch nicht versucht... Ich werd mal die 3.0.6 versuchen...
Ich weiß ja jetzt (dank meikelmoeller) wie man einfach einen downgrade opder update machen kann
wenn man die Images hat...
Dann sollte das hin und her springen zum Testen ja kein Problem sein...
Eine Aussage zu Hi10P in Openelec von fritsch:
fritsch schrieb:
hi10p is _not_ handled on the GPU - not at all. hi10p was the worst decission by a quad core xeon paid by mammi anime scene ... (I blame the scene, not the guy that invented the codec)
I implemented hi10p multithreading, which is also in OpenELEC 3.2.3 - so at least all your cores are used, but this does not make 1080p hi10p working, cause of too less CPU performance of your Fusion E350.
Quelle
Hat Jemand Erfahrung mit der Integration eines ALC662 und einer Fire DTV S2?
Gibt es denn Probleme damit? Hast du es mit einem LiveStick mal ausprobiert?
Vor allem das erste ist doch normal unproblematisch?!
Ich habe eine fire dtv s2 und bei mir gab es immer hänger in openelec als ich noch eine zweite Karte drin hatte, mir der alleine ging es glaube ich, bin mir aber nicht mehr so sicher. Musst du mal ausprobieren.
Also ich bekomme keinen 5.1 sound aus openelec 3.2.2.
Zur fire dtv ich habe tv headend server und client aktiviert und habe den server entsprechend eingerichtet. Die Sender die er automatiach gefunden hat, habe ich gemapt.
Diese werden auch sofort in der liste angezeigt. Ich bekome aber keinen stream. Auch per wui/vlc nicht.
Gesendet von meinem GT-N7000 mit der Hardwareluxx App
Über was willst du den Sound ausgeben? Viele geben ihn ja über HDMI aus, und dann wäre bei dir der Geforce Treiber
dafür zuständig und nicht der Realtec. 3.2.3 ist die aktuelle Version ;)
Die Fire sollte doch eig. gehen - https://github.com/OpenELEC/OpenELEC.tv/issues/211
Hast du es mal mit vdr versucht?
Hehe ich bin wohl der einzige der net schlafen kann/darf ;)
Ich gebe den Sound anlalog aus. Stereo funzt "wunderbar"
Settings sind auf 5.1 analog
Fehlermeldung TV:
No Service enabled. oder No Input detected
VDR hab ich bisher nicht getestet.
*Update
Mit VDR gehts. Jetzt muss ich nur noch mein Sky und HD+ Abo ans laufen bekommen.
Wobei HD+ wohl unmöglich sein wird mit dieser Hardware.
Fehlermeldung TV:
*Update
hast du nur die Fire dtv drin oder noch eine Karte?
Nur die Fire DTV S2.
Nach nem Reboot läuft es nicht mehr.
Hey Jungs,
kann mir einer sagen, warum ich beim Verbinden zum wlan immer nen Input/output error bekomme? Als Schnittstelle steht unter den Wlan-Netzen auch eth1 und nicht wie linux-üblich wlan0. Leider finde ich die Einstellung nicht, das zu ändern.
Habe die neuste Version von der openelec Homepage.
Ist ein HTPC mit ZotacGeforce-9300-ITX Wifi also "onboard"
3.2.3 ION / Intel / Fusion 32/64 wäre präziser als neueste Version, da gibts auch noch die 2.0 und vers. Beta Images ;)
Kannst du das Board mal verlinken? Finde hier nichts dazu - Mainboards mit CPU mit Mainboard-Hersteller: Zotac Preisvergleich | Geizhals Deutschland
Oder ist es das? Zotac GeForce 9300-ITX Wi-Fi, GeForce 9300 (dual PC2-6400U DDR2) (GF9300-I-E) Preisvergleich | Geizhals EU
Laut der Liste ist das Board kompatibel mit OE: Supported Hardware - OpenELEC
Oder weist du welcher WLAN Chip drauf ist?
War vorher ein anderes OS drauf und hat über WLAN funktioniert? Oder ist noch eins paralell drauf?
Kannst du mal gucken ob diese Befehle aus Post 3 bei dir gehen und was da rauskommt?
Via VT-6656 WLAN Adapter funktioniert nicht
Na da bin ich ja wohl an jemanden geraten, der Ahnung hat :)
Alsooo
Laufen tut die "OpenELEC Stable - Generic x86_64 Version:3.2.3", war mir nicht so sicher, was ich da nehmen soll und "catch-all" klang vertrauenswürdig ;)
Das Board, was ich habe ist die GF9300-D-E Edition Zotac GeForce 9300-ITX Wi-Fi, GeForce 9300 (dual PC2-6400U DDR2) (GF9300-D-E) Preisvergleich | EU - Hardwareluxx - Preisvergleich
Wlan Chip ist ein VT6656.
Erkannt wird das Modul ja, Netze finde ich auch, nur verbinden klappt nicht.
Vorher war WinXP drauf, da hat er ohne weiteres funktioniert. Jetzt ist aber nur noch OpenElec drauf.
Kannst du mir sagen, wie ich bei Openelec ins terminal komme? Dann poste ich dir, was er ausspuckt.
Nicht wirklich ;)
Für dich wäre die ION Build die bessere, da du eine Nvidia GPU hast.
Aber macht in dem Fall keinen Unterschied, die ION sollte nur evtl. ein wenig
angepasster auf NV sein und ein wenig schlanker. Mit WLAN sollte es nichts zu tun haben.
Woher weist du dass das Modul erkannt wird?
Am einfachsten ist Terminal von einem anderen PC aus, hast du da Windows oder Linux?
Linux: terminal -> ssh root@openelec
pw: openelec
Windows: Putty sollte das glaube ich können.
SSH hast du bei dem Einrichtungsassistent aktiviert?
Auch wenn das zotac 9300itx ein sockel 775 ist? Ich habe nämlich das gleiche.
Ssh muss man imho in den openelec conf8gs erst aktivieren.
Sockel ist doch egal, hauptsache ist welche GPU du nutzt, und das ist ja bei dir die Nvidia 9300.
Ja, deswegen ja die Frage
Man kann ssh auch nachträglich im Menü aktivieren.
und die:
und die:
