Dafür wird makemkv benötigt. Das musst du manuell nachinstallieren ...Ich habe versuchteine br direkt abzuspielen.
Naja installiert ist makemkv aber er startet die m2ts datei nicht. Ohne Fehlermeldung.
If you are a user that managed to download and install a skin over the past few days, and that skin is missing textures or otherwise doesn’t look exactly right, you may need to delete and reinstall it. To do so, you will need to navigate to the packages folder inside your userdata folder, delete the skin zip file, and then open XBMC, uninstall the skin, and then reinstall it. This issue will likely affect a very, very limited minority of users, but for those it does affect, don’t hesitate to ask questions in the forums if you have issues.
