mit der config läuft es mit ner 570 flüssig bei mir ohne ruckler.
wichtig ist nicht den vollen vgpu speicher zu geben.
8x as scheint die letzten kleineren ruckler zu beseitigen.also kein 16x einstellen.
falls noch welche auftreten sollten: speicherstand laden u. nochmal laden.
seta com_videoRam "1024" //sets the Video Card memory Set this to the amount you have in MB
seta com_maxfps "60" //limits the frames to 60 can be changed to what you desire
seta image_anisotropy "8" //Using the highest setting here but you can set as 2, 4 or 8
seta image_usecompression 0
seta image_filter "GL_LINEAR_MIPMAP_LINEAR" //filtering for light maps
seta image_preload "1" //Use preload images when ever possible
seta image_lodbias "-1" //LoD settings
seta image_ignoreHighQuality "0" //Sets up for using HQ gfx
seta image_ignoreLowQuality "1" //ignores the low textures
seta image_useCache "1" //Enabled Cache to allow the textures to load properly without popping
seta image_cacheMegs "250" //Cache size in Megabytes
seta image_cacheMinK "100" //Cache minimum size in kilobytes
seta r_aspectRatio "2" // 0=4:3, 1=16:9, 2=16:10, 3=5:4 TFT, -1 custom
seta r_fullscreen "1"
//seta r_customAspectRatioV "10"
//seta r_customAspectRatioH "16"
seta r_swapInterval 1 //VSYNC 1 enabled, 0 diabled
seta r_useHighQualityPostProcess "0" //Fore High Quality post proccessing
seta r_shadowsHighQuality "1" //Fore High Quality shadows
seta r_displayRefresh "0" //keep it so the engine doesn't double render a frame
seta r_renderer "best" //highest rendering options
seta r_multiSamples "8" //Set this to 16 or 8 if you're having low-fps as 32 is the Max Multi-sampling
seta r_useHBAO "1" //Ambient occlusion
seta r_useRenderThread "0" // 0 Disable or 1 Enable threaded rendering useful for newer cards to increase performance.
seta r_visDistMult "1"
seta r_useMotionBlur "1" //use blur
seta r_skipBump "0"
seta r_skipSpecular "0"
seta r_skipNewAmbient "0"
seta r_shadows "1"
seta r_cgFragmentProfile "best"
seta r_cgVertexProfile "best"
seta vt_lodBias "-1" //LoD settings
//below is cache settings
seta vt_pageimagesizeuniquediffuseonly2 "8192"
seta vt_pageimagesizeuniquediffuseonly "8192"
seta vt_pageimagesizeunique "8192"
seta vt_pageimagesizevmtr "8192"
