C
coolcasis
Guest
Geht klar.
Ich denke in zwei Wochen wird es losgehen.
The Shopping Cart Contains:
Total Items: 5 Weight: 35.2lbs Amount: $267.75
Remove Product(s) Qty. Total
Delete
Lian Li PC-A05N-B Black Aluminum Mini-Tower Case Lian Li PC-A05N-B Black Aluminum Mini-Tower Case
- Drill Top Blowholes No Blowholes
- Bulgin LED Power Switch No Bulgin Switch Installed
- Power Supply (Stock) No Power Supply
- Floppy Drive No Floppy Drive
- Case Options Stock case
- Sleeve Color Black
- Heatshrink Color Black
- Bay Covers Do Not Drill/Install Rocker Switches
- Cold Cathode 12" Kit (Sleeved) No Cold Cathode Kit
- Extra 12" Cathode Tube (Sleeved) No Extra Tube
- Case Handles No case handles
- Optical Drive Covers No Drive Covers
- Aluminum 3.5 No Transfer Bracket
- Anodized Thumbscrews Stock Silver Screws/Thumbscrews
- Temperature Sensor Bay No Temperature Sensor Bay
$99.95
Delete
*** NEW *** Lian Li PC-Q07-B Aluminum Mini Tower Computer PC Case- Mini ITX Chassis - Black *** NEW *** Lian Li PC-Q07-B Aluminum Mini Tower Computer PC Case- Mini ITX Chassis - Black
$79.95
Delete
Pre-Wired Delrin Vandal Resistant Illuminated Switches 16mm Black - Sleeved Pre-Wired Delrin Vandal Resistant Illuminated Switches 16mm Black - Sleeved
- Vandal Switch Style Momentary Switch Style (ie. Power & Reset)
- 16mm Switch Type Vandal Orange Ring
- Heatshrink Color Orange
$27.95
Delete
Pre-Wired Delrin Vandal Resistant Illuminated Switches Black - 22mm Sleeved Pre-Wired Delrin Vandal Resistant Illuminated Switches Black - 22mm Sleeved
- 22mm Switch Type Vandal Blue Ring
$29.95
Delete
- 22mm Switch Type Vandal Orange Ring
$29.95
Sub-Total: $267.75
und ein mainboard tray?
Das ist leider auch zu G?0ß.Das habe ich aber auch schon ein paar Posts vorher gesagt warum das so ist.
Die Versandkosten betrugen in den letzten Sammelbestellungen zwischen 150-220 USD.![]()
