runter takten ja ,abe nicht den vcore ,dazu musst du offset oder auto nutzen
kurze zwischenfrage: ist es möglich, dass mittels manuell gesetzter, fester vcore und eingeschalteten stromsparmechismen der 2500k'er im idle runtertaktet? oder geht das nur über offset? sofern man eben übertaktet.
gruß
..::mcpaschetnik::..
Ist blos komisch das jeder der ne wakü hat mit nem 2500 oder nen 2600k und oc betreibt nen hk 3 drauf hat.
Jetzt die entscheidene Frage warum blos ?
Mer sage ich da zu nicht mehr.
The OverClockers BSOD code list
BSOD codes for overclocking
0x101 = increase vcore
0x124 = increase/decrease QPI/VTT first, if not increase/decrease vcore...have to test to see which one it is
on i7 45nm, usually means too little VVT/QPI for the speed of Uncore
on i7 32nm SB, usually means too little vCore
0x0A = unstable RAM/IMC, increase QPI first, if that doesn't work increase vcore
0x1A = Memory management error. It usually means a bad stick of Ram. Test with Memtest or whatever you prefer. Try raising your Ram voltage
0x1E = increase vcore
0x3B = increase vcore
0x3D = increase vcore
0xD1 = QPI/VTT, increase/decrease as necessary, can also be unstable Ram, raise Ram voltage
0x9C = QPI/VTT most likely, but increasing vcore has helped in some instances
0x50 = RAM timings/Frequency or uncore multi unstable, increase RAM voltage or adjust QPI/VTT, or lower uncore if you're higher than 2x
0x109 = Not enough or too Much memory voltage
0x116 = Low IOH (NB) voltage, GPU issue (most common when running multi-GPU/overclocking GPU)
0x7E = Corrupted OS file, possibly from overclocking. Run sfc /scannow and chkdsk /r
