Die Spielmodi:
* Capture The Documents
der spielmodus heißt capture the files, damit man weiterhin CTF sagen kann...
Die Spielmodi:
wie funktioniert das mit dem Demoman Achievement (Schick deinem Gegner eine Standbildaufname...einmal mit Hintern wackeln und da war doch noch ein anderes)?
Sind damit diese 3 Gestiken gemeint?
Team Fortress 2
General
* - Personal welcome message
* - One reserved slot (Ability to join a full server with 31/31 players)
* - No autoteambalance
* - Command "premium_switch" to switch to the other team
* - Disabled idle kick (usefull for idling items)
Fun Effects - Chat Commands
* - "glow" to glow
* - "dark" to make your model darker
* - "darker" to get a more darker model
* - "smoke" to get a more darker model
* - "hats" to wear all hats
* - Check the video in YouTube
Bots - Ability to control them
* - The Commands:
* - "premium_bot_follow" to let bots follow you
* - "premium_bot_move_to" to send bots to aimed target
* - "premium_bot_medic" to reserve a Medic bot
All classes
* - Faster movement speed
* - Increased fire rate with all weapons
* - Unlimited ammo
* - Bunny Hopping and Trimp Jumping
* - 50 bonus health points with each kill
* - Ability to use conc grenades with "premium_conc" command
* - Variable FOV settings with "premium_fov" command
* - Distance+Direction display to the next living enemy
* - Flare Gun immunity
* - Spy detection
Scout
* - Ability to make 5 double jumps in one row
* - Faster jumping speed
* - Get a new baseball after 5 seconds
* - Ability to use Bonk without pauses and with longer effect time
* - Conc grenades
Soldier
* - Higher rocket jumps than usual
* - 6 instead of 4 rockets
* - Keep rage amount after death
Demoman
* - Higher grenade jumps than usual
Heavy
* - Get instantly a new sandvich after you throw away the old one
Engineer
* - Increased fire rate of your dispenser homing rockets
* - Ability to build 4 sentries and 4 dispensers
* - Ability to build 3 teleporter entries
* - Teleporters have 2000 health points
* - Dispensers have 300 health points
* - Infinite metal
* - Conc grenades
* - Instant teleporter charge
* - Teleporter immunity against Spy sappers
Medic
* - Longer ubercharge time
* - Faster charge time
* - Ability to load ubercharge higher than 100%
* - Conc grenades
Sniper
* - Instant rifle charge to 100%
* - Faster reload and always perfect aiming with the bow
* - Get nearly cloaked while camping on a fixed position
* - Get 10 Jarates with spawn
* - Conc grenades
Spy
* - Unlimited cloak time (With every clock)
* - HP regeneration with Cloak & Dagger
* - Conc grenades
Viel schlimmer als das finde ich ja diese ganzen "Premium Server".
Die Leute die da mit ihren Premium-Accounts rumrennen, haben so viele Vorteile, das es mMn schon an einen "God-Mode" grenzt.
Das schlimme daran ist, das solche Server für jeden zugänglich sind, ganz egal ob Premium-Member oder nicht. Und solche Anfänger wie ich es bin, spielen auf solchen Servern sogar noch ihre ersten Matches und wundern sich wieso manche so unglaublich gut spielen und sogar "Moves" draufhaben, die nicht einmal im Handbuch stehen.
Die Serverlisten sind mit solchen gemoddeten Servern sowas von überschwemmt, das es schon gar keinen Spaß mehr macht einen normalen Server zu suchen.
Bis man mal einen ordentlichen Server ohne 9999 Runden die gleiche Map, ohne instant Respawn, ohne Premium ge-cheate und wohlgemerkt einen auf dem gespielt wird findet, vergeht wirklich sehr viel Zeit.
Ich finde das Spiel an sich sehr genial, sofern es denn un-gemoddet ist, aber ich verbringe wirklich mehr Zeit beim suchen eines Servers, als ich mit spielen verbringe.
Auf die Gefahr hin, das so etwas schon mal gepostet wurde, hier die ganzen Vorteile die man als "Premium-Mitglied" bei solchen Servern besitzt.
Fragt mich nicht wo die Motivation darin liegt mit solchen "Vorteilen" gegen normale Spieler zu zocken bzw. überhaupt zu zocken, denn das zerstört mMn die ganze Spielbalance.
Hier:
Code:Team Fortress 2 General * - Personal welcome message * - One reserved slot (Ability to join a full server with 31/31 players) * - No autoteambalance * - Command "premium_switch" to switch to the other team * - Disabled idle kick (usefull for idling items) Fun Effects - Chat Commands * - "glow" to glow * - "dark" to make your model darker * - "darker" to get a more darker model * - "smoke" to get a more darker model * - "hats" to wear all hats * - Check the video in YouTube Bots - Ability to control them * - The Commands: * - "premium_bot_follow" to let bots follow you * - "premium_bot_move_to" to send bots to aimed target * - "premium_bot_medic" to reserve a Medic bot * - Check the video in YouTube All classes * - Faster movement speed * - Increased fire rate with all weapons * - Unlimited ammo * - Bunny Hopping and Trimp Jumping * - 50 bonus health points with each kill * - Ability to use conc grenades with "premium_conc" command * - Variable FOV settings with "premium_fov" command * - Distance+Direction display to the next living enemy * - Flare Gun immunity * - Spy detection Scout * - Ability to make 5 double jumps in one row * - Faster jumping speed * - Get a new baseball after 5 seconds * - Ability to use Bonk without pauses and with longer effect time * - Conc grenades Soldier * - Higher rocket jumps than usual * - 6 instead of 4 rockets * - Keep rage amount after death Demoman * - Higher grenade jumps than usual Heavy * - Get instantly a new sandvich after you throw away the old one Engineer * - Increased fire rate of your dispenser homing rockets * - Ability to build 4 sentries and 4 dispensers * - Ability to build 3 teleporter entries * - Teleporters have 2000 health points * - Dispensers have 300 health points * - Infinite metal * - Conc grenades * - Instant teleporter charge * - Teleporter immunity against Spy sappers Medic * - Longer ubercharge time * - Faster charge time * - Ability to load ubercharge higher than 100% * - Conc grenades Sniper * - Instant rifle charge to 100% * - Faster reload and always perfect aiming with the bow * - Get nearly cloaked while camping on a fixed position * - Get 10 Jarates with spawn * - Conc grenades Spy * - Unlimited cloak time (With every clock) * - HP regeneration with Cloak & Dagger * - Conc grenades
Also ich spiele im Moment öfters auf den saigns.de-Servern und war schon in mehreren Runden Map-Leader auch ohne Premium-Account
Wer sich einen Premium-Account kaufen muss, ist sonst einfach zu schlecht und gibt es damit auch noch zu
Gute Server wurden hier schon öfters genannt. Einfach mal durchklicken
@pavo: Wenn die Rakete eine Critical war, kann sie dich auch als Heavy mit einem Schuss platt machen.
pyro is die sinnloseste klasse
einfach nur just for fun
