ich würde gerne mein ABIT IS7-E verkaufen. Es läuft absolut stabil und ist schön leise. Natürlich in Top Zustand. Hier mal die Specs :
Features
Processor
- Supports Intel® Pentium® 4 Socket 478 processors (800/533MHz FSB)
- Supports Intel® Hyper-Threading Technology
Chipset
- Intel® 865PE / ICH5
- Supports Dual Channel DDR 400 Memory
- Supports Advanced Configuration and Power Management Interface (ACPI)
Memory
- Four 184-pin DIMM sockets
- Supports 4 DIMM Single/Dual Channel DDR 400 memory
- Supports 4 DIMM DDR400 up to 4GB
AGP
- Accelerated Graphics Port connector supports AGP PRO 8X/4X (0.8V/1.5V)
LAN
- On board 10/100MB LAN
Serial ATA
- 2 channels Serial ATA 150MB/s data transfer rate
USB 2.0
- 8 ports USB 2.0 supports 480MB/s data transfer rate
Audio
- 6-Channel AC 97 CODEC on board
- Professional digital audio interface supports 24-bit S/P DIF optical In/Out
System BIOS
- SoftMenu™ Technology to set CPU parameters
Internal I/O Connectors
- 1 x AGP PRO, 5 x PCI slots, 1 x Floppy Port supports up to 2.88MB
- 2 x Ultra DMA 33/66/100 Connectors
- 2 x Serial ATA 150 Connectors
- 2 x USB 2.0 headers
- 1 x CD-IN, 1 x AUX-IN
Back Panel I/O
- 1 x PS/2 Keyboard, 1 x PS/2 mouse, 1 x Printer Port, 1 x COM port
- 1 x S/PDIF Out connector, 1 x S/PDIF In connector
- 1 x Audio connectors (Front Speaker, Line-in, Mic-in, Center/Sub, Surround Speaker)
- 2 x USB 2.0, 1 x RJ-45 LAN Connector
- 2 x USB 2.0
Miscellaneous
- ATX form factor
- Hardware monitoring - Including Fan speeds, Voltages, System environment temperature
NeuPreis laut Preistrend ist : Der billigste Händler wo es lieferbar, bietet es für 95€ an. Sagen wir 75% vom Neupreis wären 79€.
Features
Processor
Chipset
Memory
AGP
LAN
Serial ATA
USB 2.0
Audio
System BIOS
Back Panel I/O
- 2 x USB 2.0
Miscellaneous
- ATX form factor
