DDR2-Roundup
11 Module im Test - Benchmarks600MHzmitmanuellenTimings
Nun erhöhen wir den FSB, versuchen aber weiterhin die besten Timings zu verwenden. Mit 600 MHz Speichertakt konnten wir folgende Messungen vornehmen :
Sisoft Sandra Float FPU 600 MHz max. Timings | Corsair CM2X512-5300C4 4-3-3-8 | | 5652 | | | Micron ES PC2-4300U 4-3-3-8 | | 5647 | | | Corsair VS DDR2-533 4-3-3-8 | | 5647 | | | Crucial Ballistix 4-3-3-8 | | 5645 | | | Crucial PC2-4300U 4-3-3-8 | | 5643 | | | Corsair CM2X512-4200 4-3-3-8 | | 5640 | | | Infineon DDR2-533 3-3-4-12 | | 5618 | | | ADATA DDR-533 3-4-4-11 | | 5616 | | | Kingston KVR533 4-3-3-12 | | 5610 | | | Samsung PC3-4200U 3-4-4-12 | | 5607 | | | TwinMOS DDR2-533 4-3-4-12 | | 5606 | | | |
Sisoft Sandra INT Alu 600 MHz max. Timings | Crucial Ballistix 4-3-3-8 | | 5648 | | | Corsair CM2X512-5300C4 4-3-3-8 | | 5641 | | | Corsair CM2X512-4200 4-3-3-8 | | 5647 | | | Crucial PC2-4300U 4-3-3-8 | | 5647 | | | Kingston KVR533 4-3-3-12 | | 5606 | | | ADATA DDR-533 3-4-4-11 | | 5615 | | | Samsung PC3-4200U 3-4-4-12 | | 5600 | | | Infineon DDR2-533 3-3-4-12 | | 5617 | | | Micron ES PC2-4300U 4-3-3-8 | | 5649 | | | TwinMOS DDR2-533 4-3-4-12 | | 5595 | | | Corsair VS DDR2-533 4-3-3-8 | | 5647 | | | |
Quake3Arena 640x480 600 MHz max. Timings | Corsair CM2X512-4200 4-3-3-8 | | 419,8 | | | Micron ES PC2-4300U 4-3-3-8 | | 419,6 | | | Corsair VS DDR2-533 4-3-3-8 | | 419,4 | | | Corsair CM2X512-5300C4 4-3-3-8 | | 419,1 | | | Crucial PC2-4300U 4-3-3-8 | | 418,8 | | | Crucial Ballistix 4-3-3-8 | | 418,5 | | | Kingston KVR533 4-3-3-12 | | 416,2 | | | Infineon DDR2-533 3-3-4-12 | | 415 | | | ADATA DDR-533 3-4-4-11 | | 413,5 | | | Samsung PC3-4200U 3-4-4-12 | | 413,4 | | | TwinMOS DDR2-533 4-3-4-12 | | 413,4 | | | |
ScienceMark 600 MHz max. Timings | Crucial Ballistix 4-3-3-8 | | 5179,47 | | | Corsair CM2X512-5300C4 4-3-3-8 | | 5158,46 | | | Corsair CM2X512-4200 4-3-3-8 | | 5150,63 | | | Crucial PC2-4300U 4-3-3-8 | | 5157,27 | | | Kingston KVR533 4-3-3-12 | | 5133,99 | | | ADATA DDR-533 3-4-4-11 | | 5107,3 | | | Samsung PC3-4200U 3-4-4-12 | | 5111,49 | | | Infineon DDR2-533 3-3-4-12 | | 5156,93 | | | Micron ES PC2-4300U 4-3-3-8 | | 5179,22 | | | TwinMOS DDR2-533 4-3-4-12 | | 5086,06 | | | Corsair VS DDR2-533 4-3-3-8 | | 5166,38 | | | |
Aquamark 600 MHz max. Timings | Corsair VS DDR2-533 4-3-3-8 | | 32175 | | | Corsair CM2X512-5300C4 4-3-3-8 | | 32172 | | | Corsair CM2X512-4200 4-3-3-8 | | 32172 | | | Micron ES PC2-4300U 4-3-3-8 | | 32172 | | | Crucial Ballistix 4-3-3-8 | | 32169 | | | Crucial PC2-4300U 4-3-3-8 | | 32169 | | | Kingston KVR533 4-3-3-12 | | 32120 | | | Infineon DDR2-533 3-3-4-12 | | 32117 | | | TwinMOS DDR2-533 4-3-4-12 | | 32104 | | | Samsung PC3-4200U 3-4-4-12 | | 32098 | | | ADATA DDR-533 3-4-4-11 | | 32095 | | | |
Unser Kommentar :
Hier kristalliert sich immer mehr heraus, dass Corsair und Crucial die Nase vorne haben. Mal führt der eine, mal der andere Speicherriegel der beiden Hersteller. Beide sind sich in ihren Charakteristiken sehr ähnlich, da beide auf die Micron-Module setzen.
