DDR2-Roundup
11 Module im Test - Benchmarks700MHzundmaximalebertaktungmitmanuellenTimings
Nun übertakten wir weiter, drei Module fallen hier jedoch schon raus. Der Samsung DDR2-533-Riegel, der TwinMOS DDR2-533 und der ADATA DDR2-533 konnten nicht mehr mit 700 MHz betrieben werden. Wieder die Benchmarks mit bestmöglichen Timings :
Sisoft Sandra INT ALU 700 MHz max. Timings | Micron ES PC2-4300U 4-3-4-8 | | 6622 | | | Corsair VS DDR2-533 4-3-4-8 | | 6614 | | | Crucial PC2-4300U 4-3-4-8 | | 6610 | | | Crucial Ballistix 4-3-4-8 | | 6606 | | | Corsair CM2X512-4200 4-3-4-8 | | 6605 | | | Corsair CM2X512-5300C4 4-3-4-8 | | 6598 | | | Kingston KVR533 4-4-4-12 | | 6581 | | | Infineon DDR2-533 4-4-4-12 | | 6494 | | | |
Sisoft Sandra Float FPU 700 MHz max. Timings | Corsair CM2X512-4200 4-3-4-8 | | 6608 | | | Corsair VS DDR2-533 4-3-4-8 | | 6607 | | | Crucial Ballistix 4-3-4-8 | | 6606 | | | Micron ES PC2-4300U 4-3-4-8 | | 6605 | | | Corsair CM2X512-5300C4 4-3-4-8 | | 6603 | | | Crucial PC2-4300U 4-3-4-8 | | 6602 | | | Kingston KVR533 4-4-4-12 | | 6519 | | | Infineon DDR2-533 4-4-4-12 | | 6516 | | | |
Quake3Arena 640x480 700 MHz max. Timings | Crucial PC2-4300U 4-3-4-8 | | 487,9 | | | Micron ES PC2-4300U 4-3-4-8 | | 486,8 | | | Crucial Ballistix 4-3-4-8 | | 486,3 | | | Corsair CM2X512-5300C4 4-3-4-8 | | 486,1 | | | Corsair VS DDR2-533 4-3-4-8 | | 486,1 | | | Corsair CM2X512-4200 4-3-4-8 | | 483,3 | | | Kingston KVR533 4-4-4-12 | | 478,3 | | | Infineon DDR2-533 4-4-4-12 | | 476,3 | | | |
ScienceMark 700 MHz max. Timings | Crucial PC2-4300U 4-3-4-8 | | 6013,68 | | | Corsair VS DDR2-533 4-3-4-8 | | 6009,66 | | | Crucial Ballistix 4-3-4-8 | | 6008,6 | | | Micron ES PC2-4300U 4-3-4-8 | | 6007,72 | | | Corsair CM2X512-4200 4-3-4-8 | | 6006,83 | | | Corsair CM2X512-5300C4 4-3-4-8 | | 6002,87 | | | Kingston KVR533 4-4-4-12 | | 5925,03 | | | Infineon DDR2-533 4-4-4-12 | | 5922,57 | | | |
Aquamark 700 MHz max. Timings | Crucial Ballistix 4-3-4-8 | | 32366 | | | Corsair CM2X512-5300C4 4-3-4-8 | | 32366 | | | Micron ES PC2-4300U 4-3-4-8 | | 32366 | | | Corsair CM2X512-4200 4-3-4-8 | | 32363 | | | Crucial PC2-4300U 4-3-4-8 | | 32363 | | | Corsair VS DDR2-533 4-3-4-8 | | 32363 | | | Infineon DDR2-533 4-4-4-12 | | 32307 | | | Kingston KVR533 4-4-4-12 | | 32303 | | | |
Unser Kommentar :
Kingston und Infineon fallen aufgrund der schlechteren Timings etwas zurück, die Micron-basierten Module können immer noch den Ton angeben. Hier liegen Crucial und Corsair wieder an der Spitze.
Schlussendlich hier die Werte mit höchster Frequenz. Der Kingston KVR533 stieg bei 700 MHz als höchste Frequenz bereits aus, also sind noch sieben Module im Rennen, die unser ASUS P5AD2 Premium bis an die Grenzen des Boards trieb. Wir nehmen an, dass die meistens erreichten 720 bis 724 MHz dem Board-Limit entspechen und die Module teilweise noch auf höhere Frequenzen getaktet werden können :
Sisoft Sandra Int ALU 640x480 max. Frequenz max. Timings | Corsair VS DDR2-533 724 Mhz @ 4-4-3-8 | | 6814 | | | Corsair CM2X512-5300C4 724 Mhz @ 4-4-3-8 | | 6811 | | | Crucial PC2-4300U 724 Mhz @ 4-4-3-8 | | 6804 | | | Micron ES PC2-4300U 724 Mhz @ 4-4-3-8 | | 6803 | | | Crucial Ballistix 721 Mhz @ 4-4-4-12 | | 6742 | | | Infineon DDR2-533 721 Mhz @ 4-4-4-12 | | 6722 | | | Corsair CM2X512-4200 720 Mhz @ 4-4-4-12 | | 6712 | | | |
Sisoft Sandra Float FPU 640x480 max. Frequenz max. Timings | Corsair CM2X512-5300C4 724 Mhz @ 4-4-3-8 | | 6817 | | | Corsair VS DDR2-533 724 Mhz @ 4-4-3-8 | | 6808 | | | Micron ES PC2-4300U 724 Mhz @ 4-4-3-8 | | 6807 | | | Crucial PC2-4300U 724 Mhz @ 4-4-3-8 | | 6806 | | | Crucial Ballistix 721 Mhz @ 4-4-4-12 | | 6738 | | | Corsair CM2X512-4200 720 Mhz @ 4-4-4-12 | | 6713 | | | Infineon DDR2-533 721 Mhz @ 4-4-4-12 | | 6692 | | | |
Quake3Arena 640x480 max. Frequenz max. Timings | Crucial PC2-4300U 724 Mhz @ 4-4-3-8 | | 501,7 | | | Micron ES PC2-4300U 724 Mhz @ 4-4-3-8 | | 501,3 | | | Corsair CM2X512-5300C4 724 Mhz @ 4-4-3-8 | | 501,1 | | | Corsair VS DDR2-533 724 Mhz @ 4-4-3-8 | | 501,1 | | | Crucial Ballistix 721 Mhz @ 4-4-4-12 | | 495,8 | | | Corsair CM2X512-4200 720 Mhz @ 4-4-4-12 | | 494,5 | | | Infineon DDR2-533 721 Mhz @ 4-4-4-12 | | 489,5 | | | |
ScienceMark max. Frequenz max. Timings | Corsair CM2X512-5300C4 724 Mhz @ 4-4-3-8 | | 6410,08 | | | Micron ES PC2-4300U 724 Mhz @ 4-4-3-8 | | 6225,74 | | | Crucial PC2-4300U 724 Mhz @ 4-4-3-8 | | 6192,71 | | | Corsair VS DDR2-533 724 Mhz @ 4-4-3-8 | | 6190,33 | | | Corsair CM2X512-4200 720 Mhz @ 4-4-4-12 | | 6120,23 | | | Crucial Ballistix 721 Mhz @ 4-4-4-12 | | 6108,22 | | | Infineon DDR2-533 721 Mhz @ 4-4-4-12 | | 6095,84 | | | |
Aquamark max. Frequenz max. Timings | Corsair VS DDR2-533 724 Mhz @ 4-4-3-8 | | 32385 | | | Crucial PC2-4300U 724 Mhz @ 4-4-3-8 | | 32382 | | | Micron ES PC2-4300U 724 Mhz @ 4-4-3-8 | | 32382 | | | Corsair CM2X512-5300C4 724 Mhz @ 4-4-3-8 | | 32379 | | | Crucial Ballistix 721 Mhz @ 4-4-4-12 | | 32363 | | | Corsair CM2X512-4200 720 Mhz @ 4-4-4-12 | | 32363 | | | Infineon DDR2-533 721 Mhz @ 4-4-4-12 | | 32328 | | | |
Unser Kommentar :
Die beste Performance im Test erreichen die Module, die 4-4-3-8 mit 724 MHz erreichen : Der Corsair CM2X512-5300C4, der Micron ES PC2-4300U, der Crucial PC2-4300U und der Corsair VS DDR2-533 sind hier das Maß der Dinge. Die anderen Module sind keineswegs schlechter, aber diese vier scheinen nicht nur hohe Frequenzen, sondern auch noch gute Timings bei denselben mitmachen zu können. Alle Module basieren auf Micron-Chips.
