Preis Widget muss noch umgeschrieben werden...
/var/www/sites/j4hwl/plugins/content/preisvergleich2019/preisvergleich2019.php:249:
object(mysqli_sql_exception)[63883]
  protected 'message' => string 'You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'gtin13">0718037827575</span>"
                             ORDER BY source ASC
' at line 1' (length=226)
  private string 'string' (Exception) => string '' (length=0)
  protected 'code' => int 1064
  protected string 'file' => string '/var/www/sites/j4hwl/libraries/vendor/joomla/database/src/Mysqli/MysqliStatement.php' (length=84)
  protected int 'line' => int 137
  private array 'trace' (Exception) =>
    array (size=21)
      0 =>
        array (size=5)
          'line' => int 137
          'function' => string 'prepare' (length=7)
          'class' => string 'mysqli' (length=6)
          'type' => string '->' (length=2)
      1 =>
        array (size=5)
          'file' => string '/var/www/sites/j4hwl/libraries/vendor/joomla/database/src/Mysqli/MysqliDriver.php' (length=81)
          'line' => int 1089
          'function' => string '__construct' (length=11)
          'class' => string 'Joomla\Database\Mysqli\MysqliStatement' (length=38)
      2 =>
        array (size=5)
          'file' => string '/var/www/sites/j4hwl/libraries/vendor/joomla/database/src/DatabaseDriver.php' (length=76)
          'line' => int 1912
          'function' => string 'prepareStatement' (length=16)
          'class' => string 'Joomla\Database\Mysqli\MysqliDriver' (length=35)
      3 =>
        array (size=5)
          'file' => string '/var/www/sites/j4hwl/plugins/content/preisvergleich2019/preisvergleich2019.php' (length=78)
          'line' => int 244
          'function' => string 'setQuery' (length=8)
          'class' => string 'Joomla\Database\DatabaseDriver' (length=30)
      4 =>
        array (size=3)
          'function' => string 'incphp' (length=6)
          'class' => string 'plgContentPreisvergleich2019' (length=28)
      5 =>
        array (size=3)
          'line' => int 50
          'function' => string 'preg_replace_callback' (length=21)
      6 =>
        array (size=5)
          'file' => string '/var/www/sites/j4hwl/libraries/src/Plugin/CMSPlugin.php' (length=55)
          'line' => int 289
          'function' => string 'onContentPrepare' (length=16)
      7 =>
        array (size=5)
          'file' => string '/var/www/sites/j4hwl/libraries/vendor/joomla/event/src/Dispatcher.php' (length=69)
          'line' => int 486
          'function' => string 'Joomla\CMS\Plugin\{closure}' (length=27)
          'class' => string 'Joomla\CMS\Plugin\CMSPlugin' (length=27)
      8 =>
        array (size=5)
          'file' => string '/var/www/sites/j4hwl/libraries/src/MVC/View/AbstractView.php' (length=60)
          'line' => int 312
          'function' => string 'dispatch' (length=8)
          'class' => string 'Joomla\Event\Dispatcher' (length=23)
      9 =>
        array (size=5)
          'file' => string '/var/www/sites/j4hwl/components/com_content/src/View/Article/HtmlView.php' (length=73)
          'line' => int 227
          'function' => string 'dispatchEvent' (length=13)
          'class' => string 'Joomla\CMS\MVC\View\AbstractView' (length=32)
      10 =>
        array (size=5)
          'file' => string '/var/www/sites/j4hwl/libraries/src/MVC/Controller/BaseController.php' (length=68)
          'line' => int 660
          'function' => string 'display' (length=7)
          'class' => string 'Joomla\Component\Content\Site\View\Article\HtmlView' (length=51)
      11 =>
        array (size=5)
          'file' => string '/var/www/sites/j4hwl/components/com_content/src/Controller/DisplayController.php' (length=80)
          'line' => int 121
          'class' => string 'Joomla\CMS\MVC\Controller\BaseController' (length=40)
      12 =>
        array (size=5)
          'line' => int 693
          'class' => string 'Joomla\Component\Content\Site\Controller\DisplayController' (length=58)
      13 =>
        array (size=5)
          'file' => string '/var/www/sites/j4hwl/libraries/src/Dispatcher/ComponentDispatcher.php' (length=69)
          'line' => int 143
          'function' => string 'execute' (length=7)
      14 =>
        array (size=5)
          'file' => string '/var/www/sites/j4hwl/components/com_content/src/Dispatcher/Dispatcher.php' (length=73)
          'line' => int 56
          'class' => string 'Joomla\CMS\Dispatcher\ComponentDispatcher' (length=41)
      15 =>
        array (size=5)
          'file' => string '/var/www/sites/j4hwl/libraries/src/Component/ComponentHelper.php' (length=64)
          'line' => int 361
          'class' => string 'Joomla\Component\Content\Site\Dispatcher\Dispatcher' (length=51)
      16 =>
        array (size=5)
          'file' => string '/var/www/sites/j4hwl/libraries/src/Application/SiteApplication.php' (length=66)
          'line' => int 208
          'function' => string 'renderComponent' (length=15)
          'class' => string 'Joomla\CMS\Component\ComponentHelper' (length=36)
          'type' => string '::' (length=2)
      17 =>
        array (size=5)
          'line' => int 249
          'class' => string 'Joomla\CMS\Application\SiteApplication' (length=38)
      18 =>
        array (size=5)
          'file' => string '/var/www/sites/j4hwl/libraries/src/Application/CMSApplication.php' (length=65)
          'line' => int 293
          'function' => string 'doExecute' (length=9)
      19 =>
        array (size=5)
          'file' => string '/var/www/sites/j4hwl/includes/app.php' (length=37)
          'line' => int 61
          'class' => string 'Joomla\CMS\Application\CMSApplication' (length=37)
      20 =>
        array (size=4)
          'file' => string '/var/www/sites/j4hwl/index.php' (length=30)
          'line' => int 32
          'args' =>
            array (size=1)
          'function' => string 'require_once' (length=12)
  private ?Throwable 'previous' (Exception) => null
  protected string 'sqlstate' => string '42000' (length=5)
Western Digital WD4001FFSX Red Pro im Test - Fazit
Western Digital geht mit den Boliden der "Red Pro"-Serie klar in Richtung des KMU-Bereichs, wo Storage-Setups mit mehr als 8 Slots und entsprechend höheren Leistungsanforderungen vorherrschen. Aber auch für den Normalverbraucher können die neuen Laufwerke in Erwägung gezogen werden, sofern man mit einer angepassten Erwartungshaltung an deren Einsatzbereich herangeht. Mehrere Red Pro in einem arbeitsplatznah aufgestellten NAS sollten vermieden werden, denn gerade bei der Lautstärkeentwicklung zieht WD nun mit den Enterprise-Boliden von Seagate gleich. Bei Temperatur und Stromverbrauch konnte man sich noch etwas distanzieren, positioniert sich aber fernab der erstklassigen Werte der bekannten Red-Reihe. Zieht man einen direkten Vergleich zwischen einer normalen Red mit 4TB und der neuen Red Pro, so kann die Pro-Variante zwischen 20-30 MB/s lesend und ca. 20 MB/s schreibend Abstand gewinnen. Bei der Random-Access-Time sind es immerhin knapp 3 ms Differenz. Dafür steigt die Last-Temperatur auch um rund 8 °C, bei zusätzlichem Stromverbrauch von knapp 6 Watt. Die Geräuschemission steigt ebenfalls um rund 8 dB(A).
{jphoto image=67678}
Die Red Pros eignen sich genau für den Anwenderkreis, dem die bisherigen Red-Boliden zu langsam waren. Sie liefern eine hohe Durchsatz- und Allround-Performance, gekoppelt mir einem 5-jährigen Garantiezeitraum und entsprechend angepassten Toleranzwerten für den KMU-Einsatz in größeren NAS-Setups. Normalverbraucher sollten den Einsatz einer Red Pro jedoch gut abwägen, da die ausschlaggebenden Argumente der "normalen" Red-Serie (Stromverbrauch, Geräuschkulisse, Temperaturentwicklung) hier nicht mehr gelten. Betrachtet man andere HDDs im Enterprise-Segment, gestaltet sich der Kaufpreis von knapp 200 Euro für die WD4001FFSX vergleichsweise günstig.
Positive Aspekte von Western Digitals WD4001FFSX:
  • hohe Leistung
  • Garantiezeitraum
  • Gutes Preis-Leistungs-Verhältnis
Negative Aspekte von Western Digitals WD4001FFSX:
  • erhöhter Stromverbrauch
  • erhöhte Wärmeentwicklung
  • hohe Betriebslautstärke
Preise und Verfügbarkeit
Nicht verfügbar Nicht verfügbar Nicht verfügbar
Quellen und weitere Links
Es sind keine Quellen vorhanden
KOMMENTARE (10)
