[Sammelthread] Abit IP45-Pro / IP45-GT3/MAX / IX48 MAX (Intel P45 /X48)
Erste Bilder der P45 / X48 Boards
The model names are IP45-MAX, IP45 and IP43 Pro, and it gives away some information about what features the different models will have. Let's start from the bottom with the IP45, as this is a very basic P45 motherboard with a single x16 PCIe 2.0 slot, two PCIe x1 slots and three PCI slots. Around the back is a single PS/2 port, six USB 2.0 ports, a Gigabit Ethernet connector, 7.1-channel audio jacks with a coaxial S/PIDF out and a CMOS reset button.
This board is limited to DDR2 800 and 1,066MHz memory, according to the specs, and it also has six SATA ports and headers for a further six USB 2.0 ports. Depending on the market, Abit has three additional models of this board, one with 10/100Mbit Ethernet, one with 5.1-channel sound and one with both. This is what is commonly known as cost down.
Next up, we have the IP43 Pro, which appears to be a better motherboard than the IP45. It has the same slot layout and the same rear I/O layout, with the addition of an optical S/PDIF out. This board features Abit's micro Guru BIOS and silent OTES chipset cooling and supports DDR2 memory up to 1,200MHz.
The IP45-MAX has a pair of x16 PCIe 2.0 slots, two PCIe x1 slots and two PCI slots. Around the back you'll find a PS/2 port, eight USB 2.0 ports, FireWire, two eSATA, 7.1-channel audio with optical and coaxial S/PDIF out, Gigabit Ethernet and a CMOS reset button. This board also has six SATA connectors, headers for a further four USB 2.0 ports and, of course, silent OTES chipset cooling and micro Guru BIOS. Finally, this board has four DDR3 memory slots with support for 1,600MHz DDR3 memory.
Quelle : http://www.fudzilla.com/index.php?option=com_content&task=view&id=7579&Itemid=1
--------------------------------------- IP45 GT3 / MAX :---------------------------------------
Abit IP45 GT3: Intel P45 DDR3-1600, ATi CrossfireX Support.
The first abit's P45 motherboards that we saw is the IP45-MAX, which has four DDR3 DIMM slots (1600/1333MHz). The rest of the specifications look typical for a P45 board, with abit including only one Gigabit Ethernet unlike some other vendors. abit does include its own patented uGuru and Silent OTES technology. However, there is no exotic cooling solution for the board besides the now common heat pipe based cooler.
Specs des IP45 MAX :
------------------------------------------- IP45 Pro : -------------------------------------------
Similar to the MAX except for its use of DDR2 instead of DDR3 memory, the IP45 Pro has a more appealing color scheme in our opinion. The feature set remains however. LGA 775 , Intel® P45 , FSB 1600 , Dual DDR2 1200 , 2x PCI-E X16 (DualX8 CrossFire) , 2 x eSATA 3Gb/s , 6 x SATA 3Gb/s RAID , IEEE1394 , abit µGuru™ Technology , abit Silent OTES™ Technology ,100% Solid Solid Capacitors ,RoHS Compliant
------------------------------------------ IX48 MAX :------------------------------------------
While it has been available already, let's not forget the X48 chipsets amidst all the P45/43 releases. Here's abit's IX48-MAX, which supports up to 4 DIMM of DDR3 1600 memory and has 2 PCIe x 16 Gen 2 slots but no CrossFireX (no dual x8). It does have abit's proprietary uGuru and OTES technologies.​
Quelle : http://www.hardwarezone.com/articles/view.php?cid=18&id=2576
@weater 540 sind zwar nice, aber 1.55v sind ja auch recht heftig?
@IronAge welche nachteile hast du denn durch den vdrop?
Frag ma einer nach nem neuen Bios für das X48 DDR3 Board.
Bei dem günstigen Preis könnte ich auch schwach werden.
Nur der VDrop ist mir zu heftig. Hoffe das lässt sich durch ein Beta Bios fixen.
Also bei extremsystems war so OC-GURU extrem angetan von dem Board weil es so gut wie überhauptkeinen Droop hatte. (Name weiss ich jetzt grad net).
Brauch der wohl. Die Rampage Extreme Jünger hauen da auch noch mehr drauf um einen FSB von über 600 zu bekommen.
Bezüglich VDrop: Ich bin da wohl etwas erwöhnt. Ich hatte zwei DDR2 Boards hintereinander die bei LLC enable nur ca. 0,02 VDrop und 0,00 VDroop haben.
Sprich: ich hab vorzugsweise wenigstens annähernd gerne die Werte die ich im Bios einstelle und nicht eine gravierende Abweichung davon.
Am besten dann noch unterschiedlichen VDrop bei bestimmten VCores - der Unterhaltungswert das zu ermitteln hält sich in Grenzen.
Wichtiger wär allerdings zu wissen wie hoch der VDroop ist. Also der VCore Differenz zwischen Idle und Vollast.
Das Posting auf xtremesystems bezog sich auf Vdroop und nicht vdrop. Soll also geringen VDroop haben.
Das es hohen VDrop hat wurd dort von Usern mehrfach bestägt. Genauso dass es Probleme mit einigen Speicherteilern hat.
Das kommt mir irgendwie bekannt vor vom IX38 DDR2 Board.
BTW: Den Lüfter bekommt man runter ? bzw wie hoch wäre die NB ab Platine ohne den Lüfter.
gelistet war es schon lang, aber das neue ist die verfügbarkeit in einem shop
edit: fehlalarm, überall nur auf anfrage=nicht verfügbar
Habe für das IX48 GT3 mal ein beta Bios angefragt - obwohl ich das Board noch nicht mal besitze.:fresse:
Eventuell kann mal einer der hier anwesenden Besitzer testen was sich da getan hat.
Vielleicht kann man auch mal die Höhe des NB Kühlers mit und ohne Lüfter bekannt geben.
http://rapidshare.de/files/40572959/Abit_IX48_GT3_Betabios_M703D.rar.html
Flashen auf eigene Gefahr. Das ist das Original Archiv was ich erhalten habe von Abit. Habe es nur umbenannt.
Danke IronAge werde es heute oder morgen mal flashen.Hat Abit geschrieben was verändert worden ist?
Tenor: Die neuren E0 Steppings der Yorkfields/Wolfdales unterstützt werden und dass der Speicher besser gehen soll damit.
Okey das mit den Speicher wäre toll die gehen nicht gut auf dem Board.Also meine Cellshock oder OCZ vorallem von anderen Hersteller weiss ich es ja nicht.
Thx werde berichten.
Wenn nicht wenigstens DDR3-1600 CL7 gehen mit 2GB Cellshock Kit bzw DDR3-1600 CL8 mit einem 4GB Kit wär das äußerst schwach für ein X48 Board.
Wichtiger wäre allerdings zu wissen ist der VDrop besser geworden und wird die VCore durch CPU-Z richtig angezeigt.
und was bringt dir besseres vdrop? hab in diesem zusammenhang noch nie eine plausible erklärung gelesen und warte gespannt...
VDrop ist vor allem eines - lästig. Hatte das schon mal wenige posts vorher ausgeführt. Lies er dort.
Mal ganz abgesehen hat es nicht nur VDrop sondern die VCore wird auch noch falsch ausgelesen.
Es gibt hinreichende Gründe für ein neues Bios Update.
Und Du hast mal wieder einmal mehr einen absolut nutzlosen Post verfasst. :rolleyes:
Die meisten stört es einen so hohen VDrop zu haben - mich inklusive.
Nicht umsonst gibt es ettliche VDrop Hardware-Mods durch die man genau genommen auch noch die Garantie verliert.
Wenns Dich nicht juckt behalts für Dich - interessiert keinen - mich inklusive. :p
genauso wenig intererssiert die menschheit dein vdropgejammer. lass dir gesagt, du wirst es auch mit einem überleben
Frage ich mich jetzt auch grad so. Dann stellt man im BIOS halt einen höheren Wert ein und gut ist. Und wer viel im BIOS rumtüftelt, der soll sich dann ein Board mit nur gerigenm VDrop nehmen.
@IronAge
- CPU-Z hat bei einigen Abit-Platinen (+ aktuellem Bios) Schwierigkeiten, die VCore korrekt auszulesen. Dies ist aber mit Sicherheit ein Fehler in CPU-Z, da z. B. µGuru den Wert richtig ermitteln kann
- Obwohl VDrop nun wirklich kein Problem ist, trotzdem folgende Anmerkung dazu: Schon mal daran gedacht, dass das Hardware-Monitoring der Boards i. d. R. nur Näherungswerte liefert ? Da wir hier von Messwerten im Nachkommabereich sprechen, wundert mich ehrlich gesagt die Naivität vieler "VDrop-Gegner"
...dass das Hardware-Monitoring der Boards i. d. R. nur Näherungswerte liefert ? Da wir hier von Messwerten im Nachkommabereich sprechen..
jo, was soll also die erbsenzählerei? stellst nen höheren wert ein und gut is. von 1,4v per bios kommen 1,37 aufm mobo an. und? ist das ein grund am mobo rumzulöten, die garantie zu gefährden um einzig die korrekte spannung angezeigt zu bekommen?
sorry, dazu fällt mir einfach nur :wall: :wall: :wall: ein
Falsch. Die Messungenauigkeit ist bei den besseren aktuellen Boards zu vernachlässigen bewegt sich meist zwischen 0,01 - 0,03.
(Gibt tatsächlich User die sich die Mühe machen das mit einem Digi-MM nachzumessen)
Mit einem geringen VDrop der bei jeder VCore gleich bleibt kann ich auch leben.
Beim IX48 bewegt sich das leider in anderen Regionen auch wenn das hier anscheinend einige noch nicht mitbekommen haben. :wall:
Unsinn. Die Messungenauigkeit hat nichts mit der Qualität der Boards zu tun, sondern hängt ausschließlich vom HW-Monitoring-Chip und der Anpassung an das jeweilige Board ab. Winbond z. B. gibt für alle Chips, von billig bis teuer, eine max. Messwertabweichung von 2 % an. Eigentlich ein guter Wert - aber leider schlampen einige (viele ?) Hersteller bei der Anpassung an das Boarddesign. Das ist auch der Grund, warum keine Pauschalaussage zur Genauigkeit möglich ist.
Man kann also, wenn mit MM nachgemessen wird, nur eine Aussage für den überprüften Mainboardtyp abgeben.
Bei mir z. B. hat das teuerste und qualitativ beste MB die höchsten Abweichungen von 3 vermessenen Boards:
bei 12V Abweichung von 0,38 V unter Last
bei 5V Abweichung von 0,26 V unter Last
Genauigkeit sieht anders aus - ich denke, da sind wir uns einig.
Abweichung auf der V12 und V5 Schiene ist wohl weniger wichtig.
Wichtig ist was beim Core bei der NB und beim Speicher ankommt.
Und da ist die Ungenauigkeit dessen was das Bios ausgibt und was mit MM nachgemessen werden kann bei den besseren Boards wesentlich geringer.
Abweichung von der VCore ist noch weniger wichtig, die kann man korrigieren. Was beim Speicher, beim Core und bei der NB ankommt, kann man einstellen, für die 12V und 5V Schiene geht das nicht.
Tschuldige aber für mich ist die Genauigkeit der Werte auf die ich Einfluß nehmen kann wichtiger.
Was V12 V5 beim Board ankommt hängt von der Beschaltung des Netzteiles und des Motherboards ab und da gibt sowieso auch gewisse Toleranzen innerhalb derer das ganze ATX Konform und damit sicher ist.
Eben deswegen sind diese Werte wesentlich wichtiger, weil es selbst hier extreme Ausreißer gibt.
Aber was solls, das ist nicht das Thema des Threads!
Sagt mal Leute, war das IP45 eigentl. je auf der Abit Seite zu sehen?
Falls ja..., da ist es jetzt nämlich nicht mehr.
Dafür ein P43, weis jetzt nicht obs das schon länger gibt, kann sein das ich nicht drauf geachtet habe.
Ja, war es und dann war es auf einmal verschwunden. Bei Alternate steht mittlerweile dann auch Oktober als Liefertermin, dort wurde es bislang immer um einen Monat verschoben.
Stellt sich die Frage ob es sich lohnen würde auf das UT P45 zu warten.
Ich hatte noch nicht ein DFI deswegen kenn ich die Unterschiede nicht so genau.
Von der Ausstattung her würde sich der Aufpreis ja nicht lohnen, da würde mir das DK reichen.
Die Frage ist, wie siehts mit dem Bios aus?
Hat da das UT entscheidend mehr zu bieten?
Oder bezieht sich der Preis hauptsächlich darauf, weil es eben die grüne TOP Schiene von DFI ist?
