[Sammelthread] Abit IP45-Pro / IP45-GT3/MAX / IX48 MAX (Intel P45 /X48)
Erste Bilder der P45 / X48 Boards
The model names are IP45-MAX, IP45 and IP43 Pro, and it gives away some information about what features the different models will have. Let's start from the bottom with the IP45, as this is a very basic P45 motherboard with a single x16 PCIe 2.0 slot, two PCIe x1 slots and three PCI slots. Around the back is a single PS/2 port, six USB 2.0 ports, a Gigabit Ethernet connector, 7.1-channel audio jacks with a coaxial S/PIDF out and a CMOS reset button.
This board is limited to DDR2 800 and 1,066MHz memory, according to the specs, and it also has six SATA ports and headers for a further six USB 2.0 ports. Depending on the market, Abit has three additional models of this board, one with 10/100Mbit Ethernet, one with 5.1-channel sound and one with both. This is what is commonly known as cost down.
Next up, we have the IP43 Pro, which appears to be a better motherboard than the IP45. It has the same slot layout and the same rear I/O layout, with the addition of an optical S/PDIF out. This board features Abit's micro Guru BIOS and silent OTES chipset cooling and supports DDR2 memory up to 1,200MHz.
The IP45-MAX has a pair of x16 PCIe 2.0 slots, two PCIe x1 slots and two PCI slots. Around the back you'll find a PS/2 port, eight USB 2.0 ports, FireWire, two eSATA, 7.1-channel audio with optical and coaxial S/PDIF out, Gigabit Ethernet and a CMOS reset button. This board also has six SATA connectors, headers for a further four USB 2.0 ports and, of course, silent OTES chipset cooling and micro Guru BIOS. Finally, this board has four DDR3 memory slots with support for 1,600MHz DDR3 memory.
Quelle : http://www.fudzilla.com/index.php?option=com_content&task=view&id=7579&Itemid=1
--------------------------------------- IP45 GT3 / MAX :---------------------------------------
Abit IP45 GT3: Intel P45 DDR3-1600, ATi CrossfireX Support.
The first abit's P45 motherboards that we saw is the IP45-MAX, which has four DDR3 DIMM slots (1600/1333MHz). The rest of the specifications look typical for a P45 board, with abit including only one Gigabit Ethernet unlike some other vendors. abit does include its own patented uGuru and Silent OTES technology. However, there is no exotic cooling solution for the board besides the now common heat pipe based cooler.
Specs des IP45 MAX :
------------------------------------------- IP45 Pro : -------------------------------------------
Similar to the MAX except for its use of DDR2 instead of DDR3 memory, the IP45 Pro has a more appealing color scheme in our opinion. The feature set remains however. LGA 775 , Intel® P45 , FSB 1600 , Dual DDR2 1200 , 2x PCI-E X16 (DualX8 CrossFire) , 2 x eSATA 3Gb/s , 6 x SATA 3Gb/s RAID , IEEE1394 , abit µGuru™ Technology , abit Silent OTES™ Technology ,100% Solid Solid Capacitors ,RoHS Compliant
------------------------------------------ IX48 MAX :------------------------------------------
While it has been available already, let's not forget the X48 chipsets amidst all the P45/43 releases. Here's abit's IX48-MAX, which supports up to 4 DIMM of DDR3 1600 memory and has 2 PCIe x 16 Gen 2 slots but no CrossFireX (no dual x8). It does have abit's proprietary uGuru and OTES technologies.​
Quelle : http://www.hardwarezone.com/articles/view.php?cid=18&id=2576
So heute mein IX48 bekommen.
Habe zwar ein Max laut Webseite von Onlineshop bestellt , aber GT3 bekommen.
Also Max gibt es nicht oder?
geht denn überhaupt noch etwas im support bei abit? das ip35 bekommt wohl keine bios-updates mehr :o
Selbst wenn Abit nicht pleite wäre, würdest du wohl kaum noch Updates für das betagte Board bekommen.
aber hallo! ich kann ja zumindest erwarten, dass der cpu-support weiter gepflegt wird. alles andere wäre eine frechheit
erwarten kann man vieles, obs man bekommt ist was anders !;)
Sehr schade dass Abit stirbt, hatte (habe) 7 Boards von dene und alle waren Top !! Bleibt halt nur noch DFI übrig die was taugen !!:teufel:
Werde µGuru vermissen !!
Genau das habe ich auch grad gedacht.
Was soll denn beim IP35 noch an CPU Support gepflegt werden? Es werden doch alle aktuellen CPUs unterstützt! Und von Intel bekommt bestimmt nichts weltbewegendes neues mehr für den Sockel 775.
@topace neue steppings zb, die das auslesen der tempdiode verhindern und somit die lüftersteuerung nutzlos machen? deine arroganz in ehren, ich seh dich jetzt schon am weinen, wenn der support für das ip45 ebenfalls eingestellt wird (oder ebenfalls schon ist?)
Was hat das mit Arroganz zu tun? Das ist die Realität! So ist das mit der Produktpflege, schließlich soll der Kunde doch auch was neues kaufen, warum in dann also mit was altem bei der Stange halten.
Und ich wage mal die Vermutung, dass keine neuen Steppings mehr kommen werden.
Aber was bitte schön möchtest du mit einem Stepping, dass das Auslesen der Tempdiode verhindert und eine Lüftersteuerung nutzlos macht?
Übrigens, ich habe gar kein IP45. Ich weiß auch nicht, wie du darauf kommst. Ich habe mich nämlich bewusst gegen Abit entschieden, weil ich Gefahr laufen will für ein neues Board keine BIOS Updates zu bekommen.
Jungs!! Bitte nicht streiten !! ;)
keiner will das Abit die Tore schlisst, aber es ist nun mal so ! In ein Paar Jahren gibts auch DFI nicht mehr, weil alle nur noch Mainstream Boards kaufen werden !!
Konnte sehr gut auf Anus, Gigabyte, MSI, ESC, etc. bis jetzt verzichten, aber langsam wirds verdammt eng !
genau das passiert bei aktuellen e8xxx, die temp wird mit konstant 100° angezeigt=die tempabhängige lüftersteuerung greift nicht mehr
Spekulationen über den zukünftigen Support müssen hier nicht diskutiert werden, das IP35 ist ohnehin nicht Gegenstand dieses Threads. Also bleibt beim Thema, bitte.
aber wenn das ein Problem von Intel (CPU) ist, dann kann das beste BIOS Support das auch nicht beheben !! bie der 8xxx Reihe ist doch bekannt das die dioden fürn Ars..h sind !!
nene, das liegt am neuen stepping. das gleiche kann somit auch auf dem ip45 bei ausbleibendem bios-updates passieren. ist das mobo eigentlich schon irgendwo erhältlich bzw hats schon einer?
Ist AFAIK nicht erhältlich und auch ungewiss wann bzw ob es überhaupt kommt.
Es war mal eine zeitlang auch auf der Abit Homepage gelistet, ist dort aber wieder verschwunden. Dort tauchen jetzt nur das IX48 und das IP43 auf.
Ich vermute ja immer noch, dass das IP45 garnicht mehr erscheint.
:heul:
& deswegen mußte ich mir das Asus P5Q-Deluxe ordern.
Hätte lieber das Abit genommen:), da Biostar & DFI ja nun auch nicht so die Bringer sind:fresse:
Na, ob du damit aber so glücklich wirst? Ich hätte dir ansonsten das Biostar TPower I45 ans Herz gelegt.
@TopAce888
war's Du es nicht, der das Biostar wieder verkaufen will/hat?
Es scheint mir nicht 24/7 tauglich zu sein:hmm:
Ich hab ja noch das P5Q-E und das läuft mit nem Q6600 einwandfrei, ist gefühlt sogar schneller als mein Hauptsys mit nem P35DQ6 und nem E8400@4 ghz
Kann schon sein. Aber auch nur aus dem Grund, weil das Board für meine Zwecke überdimensioniert ist, ich hatte dann ein "kleines" TP34-D2A7 von Biostar ausprobiert, das war dann aber für meine Zwecke unterdimensioniert. Deswegen bleibe ich jetzt beim Tpower! Und wieso sollte es nich 24/7 tauglich sein. (wenn mir der Mod die OT-Frage gestattet)?
IX48 GT3
Cellshock 1600 2Gb
E8400
Seasonic + 650W.
Ati 1950Pro
Dtek.
Alles angeschlossen zack start und lauft.
GA-EX38T-DQ6 hat da mehr Startprobleme.
HDD Seagate ST3250620AS mit XP32 Part. und Vista 64x Part.
Gleich in OS mit beide kommt von P35 und EX38T
Giga Treiber deinstalliert und Abit darauf + Uguru.
Erst mal Memtest > Speicher OK.
Prime kurz gestartet OK.
Jetzt mal FSB getestet ganz schnell 530 lauft.
Dann 400x 9 Ram 1280 7-7-7-20 TR1 mit 1.7
Enorme Vdrop ins BIOS 1.3250
CPU-Z 1.18 bis 1.20 Everest genau so.
Aber jetzt kommt es : auf jeder anderes MoBo was hier war weniger Vdrop CPU-Z 1.32 um Prime Stable zu bekommen.
Jetzt erst 2 Stunden Prime Small > OK
2 Stunden Prime Large > OK
Jetzt lauft Custom schon 9 Stunden ohne Fehler.
Intel Burn Test > OK
Was soll dass ganze jetzt bedeuten?
Falsche Werten in CPU-Z und Everest oder lauft CPU auf ABIT mit viel weniger Vcore?
Habe soeben mein Abit von der Post abgeholt.Werde es heute Abend gleich mal Testen.
Was mich ein bisschen irritiert ist das nur 1333mhz RAM Support gegeben wird? Für ein X48 aber schwach.Sicher wird das mit einem Biosupdate noch kommen.(wird ja Abittypisch lange gehen) Aber mehr wenn ich das Teil am Strom habe.
Da spricht jmd der komplett ahnungslos ist.
1. Abit (bzw Usi) ist nicht pleite: Es lässt sich nur zu wenig geld mit Mobos verdienen
2. Wird der Support nicht eingestellt. Biosupdates für die E0 Steppings sind angekündigt und werden hoffentlich bald auch kommen. Danach gibts ja dann eh keine Core2s mehr, also find ich den Zeitpunkt für den Ausstieg (wenn er denn kommen muss) ziemlich gut gewählt.
3. Hat Abit noch nie alten Mobos keine Updates mehr geschrieben wenn es möglich war, schon gar nicht in nem halben Jahr bis Jahr (so alt ist das IP35 nämlich grade mal)
Also: Mach die Leute hier nicht nervös mit haltlosen Anschuldigungen und dummem Geschwätz.
Wenn du dir das Biostar Mobo gekauft hast ist ja gut, ist nen tolles Board werd glücklich damit. Hier bist du allerdings komplett falsch.
Ich gebe nur das wieder, was man in der Presse liest. Von USI habe ich ja auch nicht geredet, sondern von Abit, dann geht halt eben die Mainboarbsparte den Bach runter. Schade ists, ob Abit aber mit digitalen Bilderrahmen mehr verdient?
Ankündingen kann man viel! Das IP45 Pro ist auch schon seit Monaten angekündigt und kann man es schon kaufen? Nein!
Und wie lange hat man z.B. beim IP35 Pro auf ein aktuelles Update warten müssen und wann gab es vollständigen Wofldale Support. Wenn das schon von jeher so lange gedauert hat, dann wird sich die Zeit sicherlich jetzt nicht verkürzen.
Da wäre ich mir in der mißlichen Lage von Abit im Moment nicht so sicher!
Wie laut ist eigentlich der Lüfter auf der Northbridge?
Usi IST Abit. Da geht auch nichts den Bach runter. Die Renditen sind einfach nicht attraktiv.
Die Ankündigung für das E0 Update ist erst nach dem Ausstieg aus der Mobo Sparte gekommen. Das IP45 war nie offiziell angekündigt (Webseite, Pressemitteilung usw)
Und wie lange hat man z.B. beim IP35 Pro auf ein aktuelles Update warten müssen und wann gab es vollständigen Wofldale Support. Wenn das schon von jeder so lange dauert, dann wird sich die Zeit sicherlich jetzt nich verkürzen.
Hat knapp nen Monat gedauert nachdem die ersten Wolfie verfügbar waren.
Bios Issue Date:2008/05/26. Ausserdem liefen die CPUs ja wie die E0 nun auch so übergangsweise.
Wenn dann wäre höchste Abit USI, denn Abit ist lediglich ein Geschäftsbereich von USI! Aber was willst du denn eigentlich? Wenn die Renditen nicht attraktiv sind, dann wird der Laden dicht gemacht, also gehts den Bach herunter.
Das IP45Pro konnte man eine ganze Weile auf der globalen Abit Webseite begutachten, sogar mit Bildern vom Board und dem I/O-Panel (und von der Verpackung glaube ich auch).
Ich habe ja auch nichts gegen Abit. Ich hätte mir gerne ein IP45 Pro (oder auch anderes) gekauft. Aber Verfügbarkeit und die ungewisse BIOS und Support Zukunft sind schon sehr bedenklich.
Aber was solls, du scheinst ja ohnehin alles besser zu wissen.
BTW hab ich von Abit innerhalb von 20 mins ne email mit den aktuellen E0 Beta BIOSEN für ALLE aktuellen Mobos bekommen (nur für das p965 AB9 QuadGT nicht)
Ich stell sie mal in die passenden Mobo Threads
(IP35, IX38)
Für das X48 gibts sicher auch eins, hab ich nur leider nich nach gefragt :>
Mal schauen, ob die auch über den Beta Status hinaus gehen, aber ansonsten lässt es sich wahrscheinlich auch gut mit einer Beta leben (wenn sie denn gut funktioinert).
Frag ma einer nach nem neuen Bios für das X48 DDR3 Board.
Bei dem günstigen Preis könnte ich auch schwach werden.
Nur der VDrop ist mir zu heftig. Hoffe das lässt sich durch ein Beta Bios fixen.
