[Sammelthread] Corsair Dominator Platinum - ft. Corsair Link ( DDR3-1600 bis 2800+ )
emissary42
Kapitän zur See
Nehr'esham
Corsair Dominator Platinum Series, with Corsair Link Connector
Press Release
The latest generation of the performance legend.
The new heatspreader design incorporates dual-channel DHX cooling to efficiently pull heat away from the PCB.
Corsair Dominator® Platinum builds on the legacy of the world’s most awarded high-performance memory, adding a striking new industrial design and LED lighting effects. Like all Dominator memory modules, they are built using only select memory ICs, highly-screened for performance and stability, and feature our patented DHX (Dual-path Heat eXchange) cooling technology, so you can push them to the limit.
Fanatical screening for phenomenal performance
Dominator Platinum memory modules are assembled using a “best of the best” IC screening process. Individual ICs are hand-screened to our highest performance threshold, and then the assembled modules undergo more rounds of rigorous screening and stability testing. The result is reliable performance under extreme pressure.
Cooler temperatures for better overclocking headroom
Excess heat limits overclocking potential, reduces performance, and can even lead to shorter component life. Our patented dual-channel DHX cooling system pulls heat away from the modules and allows Dominator Platinum to run at cooler temperatures than lesser memory kits. This advanced cooling technology, combined with our relentless screening, delivers phenomenal overclocking potential.
Customize your look
The integrated light bar provides a subtle downwash lighting effect that gives your system an impressive look but subtle look. Additional light bars (available separately, beginning September 2012) allow you to match your system’s color scheme.
Corsair Link compatible
Add an Airflow Pro (available separately), and connect with Corsair Link system monitoring and control solutions for real-time activity and temperature monitoring.
Designed for Enthusiasts. Backed by Corsair.
World-famous reliability and performance
There's a reason why world-champion overclockers, extreme gaming enthusiasts and high-end system builders all trust Corsair for high-performance memory that they can install with confidence and pride. Whether you're breaking your own records or you're simply building a dream gaming rig, you can count on Corsair memory.
Lifetime limited warranty
Your performance investment is protected. All of our memory products are backed by a limited lifetime warranty.
The Corsair Advantage
With a long history of building enthusiast-grade memory and components, we've earned a reputation for quality, compatibility, and performance. Need help? We're available by phone call, email or web forum.
Preisvergleich: Dominator Platinum
Spezifikationen
SpeichertypDDR3
Package Memory Pin240
Package Memory FormatDIMM
SpeicherkonfigurationDual / Quad Channel
Performance ProfileXMP, Version 1.3
Lüfter inbegriffenNein
Heat SpreaderPlatinum, Customizable Lightbar and DHX Cooling Technology
geprüfte Betriebsspannungabhängig vom Kit entweder 1.50V oder 1.65V
GeschwindigkeitPC3-22400 (2800MHz)
PC3-21300 (2666MHz)
PC3-19200 (2400MHz)
PC3-17066 (2133MHz)
PC3-15000 (1866MHz)
PC3-12800 (1600MHz)
SPD Betriebsspannung1.5V
SPD Geschwindigkeit1333MHz
SPD Latenz9-9-9-24
GarantieLebenslange
[tr]
[td]Speichergröße[/td][td]64GB, 32GB, 16GB, 8GB Kits, je 4GB oder 8GB Module[/td][/tr]
Produkt Links
  1. Dominator Platinum DDR3-3000 CL12-14-14-36-2T 1.65v 4GB Dual Kit (2x 2GB) (Chips: Hynix)
  2. Dominator Platinum DDR3-2666 CL10 1.65v 16GB Quad Kit (4x 4GB) (Chips: Samsung, Hardware Heaven Review)
  3. Dominator Platinum DDR3-2400 CL9 1.65v 16GB Quad Kit (4x 4GB) (Chips: Samsung, ...?)
  4. Dominator Platinum DDR3-2133 CL9 1.5v 8GB Dual Kit (2x 4GB) (Chips: Samsung, ...)
  5. Dominator Platinum DDR3-1866 CL9 1.5v 8GB Dual Kit (2x 4GB) (Chips: Samsung HCH9, Nanya, Micron...?)
  6. Dominator Platinum DDR3-1866 CL9 1.5v 16GB Quad Kit (4x 4GB)
  7. Dominator Platinum DDR3-1866 CL9 1.5v 16GB Dual Kit (2x 8GB)
  8. Dominator Platinum DDR3-1600 CL9 1.5v 8GB Dual Kit (2x 4GB)
  9. Dominator Platinum DDR3-1600 CL8 1.5v 8GB Dual Kit (2x 4GB)
  10. Dominator Platinum DDR3-1600 CL9 1.5v 16GB Dual Kit (2x 8GB)
Bilder
Reviews
HARDWARELUXX OC Ergebnisse
Takt | Timings | Spannung | Menge | Plattform | Prime/ SPI / 3D-stable | User | Screen
DDR3-2949 | 10-12-12-31 1T | 1.78v | 2x4GB (CMD16GX3M4A2666C10) | Z77 | Validation | websmile | Screen
DDR3-2933 | 10-12-12-25 1T | 1.72v | 2x4GB (CMD16GX3M4A2666C10) 3+4 | Z77 | Spi 1M | websmile | Screen
DDR3-2933 | 10-12-12-31 1T | 1.79v | 2x4GB (CMD16GX3M4A2666C10) 1+2 | Z77 | Spi 1M | websmile | Screen
DDR3-2933 | 11-13-13-35 1T | 1.82v | 2x4GB (CMD16GX3M4A2400C9) | Z77 | Spi1m | websmile | Screen
DDR3-2815 | 10-12-12-25 1T | 1.62v | 2x4GB (CMD16GX3M4A2666C10) | Z77 | Spi32m | websmile | Screen
DDR3-2802 | 9-12-12-21 2T | 1.90v | 2x4GB (CMD16GX3M4A2400C9) | Z87 | Spi32m | websmile | Screen
DDR3-2800 | 10-12-12-25 1T | 1.66v | 2x4GB (CMD16GX3M4A2666C10)1+2 | Z77 | Spi32M | websmile | Screen
DDR3-2800 | 10-12-12-28 1T | 1.72v | 2x4GB (CMD16GX3M4A2400C9) | Z77 | Spi32m | websmile | Screen
DDR3-2800 | 10-13-13-30 1T | 1.71v | 2x4GB (CMD8GX3M2A2133C9) | Z77 | Spi32m | donkel | Screen
DDR3-2800 | 11-13-13-28 2T | 1.65v | 2x4GB (CMD16GX3M4A2400C9) | Z77 | Spi32m | Punk Sods | Screen
DDR3-2800 | 11-13-13-31 1T | 1.68v | 4x4GB (CMD16GX3M4A2400C9) | Z77 | Spi1m | emissary42 | Screen
DDR3-2800 | 11-13-13-36 2T | 1.71v | 2x4GB (CMD8GX3M2A2133C9) | Z77 | Spi32m | donkel | Screen
DDR3-2800 | 11-13-13-31 1T | 1.675v | 2x4GB ("CMD16GX3M4A2666C10") | Z77 | nur CPUz | Dancop | Screen
DDR3-2734 | 10-12-12-28 1T | 1.685v | 4x4GB (CMD16GX3M4A2400C9) | Z77 | Spi32m | Punk Sods | Screen
DDR3-2715 | 10-12-12-25 1T | 1.725v | 4x4GB ('CMD16GX3M4A2400C9') | Z77 | Spi32m | Punk Sods | Screen
DDR3-2696 | 10-12-12-31 | 1.656V | 2x4Gb (CMD16GX3M4A2400C9) | A85X | SPI32M | emissary42 | Screen
DDR3-2695 | 10-12-12-28 1T | 1.65v | 2x4GB ("CMD8GX3M2A2133C9") | Z77 | Spi32m | donkel | Screen
DDR3-2680 | 10-12-12-28 1T | 1.584v | 4x4GB (CMD16GX3M4A2400C9) | Z77 | Spi32m | websmile | Screen
DDR3-2666 | 9-12-12-21 1T | 1.734v | 2x4GB (CMD16GX3M4A2400C9) | Z77 | Spi32m | websmile | Screen
DDR3-2666 | 9-12-12-25 1T | 1.734v | 4x4GB (CMD16GX3M4A2400C9) | Z77 | Spi32m | websmile | Screen
DDR3-2666 | 9-12-12-28 1T | 1.71v | 2x4GB (CMD16GX3M4A2666C10) 1+2 | Z77 | Spi 32M | websmile | Screen
DDR3-2666 | 10-12-12-25 1T | 1.65v | 2x4GB (CMD16GX3M4A2400C9) | Z77 | Spi32m | emissary42 | Screen
DDR3-2666 | 10-12-12-28 1T | 1.60v | 4x4GB (CMD16GX3M4A2400C9) | Z77 | Spi32m | Punk Sods | Screen
DDR3-2666 | 10-12-12-28 1T | 1.61v | 2x4GB (CMD8GX3M4A2133C9) | Z77 | Spi32m | websmile | Screen
DDR3-2601 | 10-12-12-31 2T | 1.62v | 2x4GB (CMD8GX3M2A2133C9) | Z77 | Spi32m | trust13 | Screen
DDR3-2600 | 9-11-11-21 1T | 1.73v | 2x4GB (CMD16GX3M4A2400C9) | Z77 | Spi32m | websmile | Screen
DDR3-2600 | 9-12-11-25 1T | 1.740v | 4x4GB (CMD16GX3M4A2400C9) | Z77 | Spi32m | Punk Sods | Screen
DDR3-2600 | 10-12-12-21 1T | 1.670v | 2x4GB (CMD16GX3M4A2133C9) | Z77 | Spi32m | xXSR1D3RXx | Screen
DDR3-2600 | 10-12-12-25 1T | 1.540v | 4x4GB (CMD16GX3M4A2400C9) | Z77 | LinX | Punk Sods | Screen
DDR3-2600 | 10-12-12-28 1T | ???v | 2x4GB ("CMD8GX3M2A2133C9") | Z77 | Spi32m | donkel | Screen
DDR3-2600 | 10-12-12-31 1T | 1.560v | 2x4GB (CMD8GX3M4A2133C9) | Z77 | Spi32m | websmile | Screen
DDR3-2451 | 10-12-12-29 2T | 1.578v | 2x4GB (CMD8GX3M2A2133C9) | Z77 | nur CPUz | Razzorone | Screen
DDR3-2600 |11-12-12-31 1T | 1.660v | 2x4gb (CMD16GX3M4A2133C9) | Z77 | Spi32m | xXSR1D3RXx | screen
DDR3-2413 | 10-11-11-28 1T | 1.525v | 2x4GB (CMD8GX3M2A2133C9) | Z77 | Spi32m | daffy | Screen
DDR3-2412 | 9-11-11-25 1T | 1.553v | 4x4GB (CMD16GX3M4A2400C9) | Z77 | Spi32m | websmile | Screen
DDR3-2412 | 10-11-11-25 1T | 1.45v | 2x4GB (CMD8GX3M4A2133C9) | Z77 | Spi32m | websmile | Screen
DDR3-2400 | 9-11-10-22 1T | 1.650v | 4x4GB (CMD16GX3M4A2400C9) | Z77 | Spi32m | Punk Sods | Screen
DDR3-2400 | 9-11-11-21 1T | 1.620v | 2x4GB (CMD16GX3M4A2133C9) | Z77 | Spi32m | xXSR1D3RXx | Screen
DDR3-2400 | 9-11-11-21 1T | 1.640v | 2x4gb (CMD16GX3M4A2133C9) | Z77 | Spi32M | xXSR1D3RXx | screen
DDR3-2400 | 9-11-11-25 1T | 1.6v | 2x4GB (CMD8GX3M4A2133C9) | Z77 | Spi32m | websmile | Screen
DDR3-2400 | 9-11-11-27 1T | 1.625v | 2x4GB (CMD16GX3M4A2133C9) | Z77 | Spi32m | xXSR1D3RXx | Screen
DDR3-2400 | 9-11-11-28 1T | 1.575v | 2x4GB (CMD8GX3M2A2133C9) | Z77 | Spi32m | donkel | Screen
DDR3-2400 | 9-11-11-31 1T | 1.605v | 2x4GB (CMD16GX3M4A2133C9) | Z77 | Spi32m | xXSR1D3RXx | Screen
DDR3-2400 | 10-11-11-21 1T | 1.503v | 2x4GB (CMD8GX3M2A2133C9) | Z77 | Spi32m | tigerstyle | Screen
DDR3-2400 | 10-11-11-21 1T | 1.515v | 2x4GB (CMD16GX3M4A2133C9) | Z77 | Spi32m | xXSR1D3RXx | Screen
DDR3-2400 | 10-11-11-21 1T | 1.59v | 2x4GB (CMD8GX3M2A1866C9) | Z77 | Spi32m | Stax Eisbecher | Screen
DDR3-2400 | 10-11-11-24 1T | 1.512v | 2x4GB (CMD8GX3M2A2133C9) | Z77 | LinX | trust13 | Screen
DDR3-2400 | 10-11-11-24 1T | 1,635v | 2x4GB CMT8GX3M2B2133C9 | Z77 | Spi32 | xXSR1D3RXx | Screen
DDR3-2400 | 10-11-11-25-1T | 1.520v | 2x4GB (CMD8GX3M2A2133C9) | Z77 | LinX | wernersen | Screen
DDR3-2395 | 10-12-12-30 2T | 1.575v | 2x4GB (CMD8GX3M2A2133C9) | Z77 | Prime | Tiger1975 | Screen
DDR3-2200 | 8-10-10-28 | 1.644V | 4x4Gb (CMD16GX3M4A2400C9) | A85X | SPI32M | emissary42 | Screen
DDR3-2200 | 9-9-9-24 1T | 1.62v | 2x8GB (CMD16GX3M2A1866C8) | Z87 | Spi32m | Minutourus | Screen
DDR3-2200 | 9-10-10-20 1T | 1.54v | 2x4GB ("CMD8GX3M2A2133C9 ") | Z77 | LinX | Blacky66 | Screen
DDR3-2133 | 9-9-9-24 1T | 1.58v | 2x8GB (CMD16GX3M2A1866C8) | Z87 | Spi32m | Minutourus | Screen
Bitte macht im Screenshot vier CPUz Tabs (CPU, Mainboard, Memory, SPD) sichtbar und blendet die Vdimm mit einem Monitoring Tool ein.
Ob Prime, SuperPI, Linx, OCCT oder ein anderes Tool für den Stabilitätstest verwendet wird ist euch überlassen.
Custom Light Tubes & Corsair Link Kit (Stand 09.10.2012)
Die Lightningbars kommen demnächst! (Okt./Nov.) Aktueller Stand!
Corsair Link wird ebenfalls bald in der Version 2.0 erscheinen und dann auch den Weg in den Handel finden. (Die Erste Version war und ist als "Beta" ausgeschrieben, weshalb wir von einer Verteilung im Handel abgesehen haben)!
Das System wird immer umfangreicher und verbindet zum Ende des Jahres die AX Platinum PSU Serie, die kommenden Corsair Hydro Systeme und die Dominator Platinum Speicher auf einer ganz speziellen erweiterten Ebene. Es werden ebenso mehr Erweiterungen Einzug halten die sich auf die Gehäuse, Chipsets und andere Komponenten ausweiten werden. Die Chipset und CPU Hersteller haben ebenfalls sehr großes Interesse an der Integration des Link Systems in kommenden Chipsetgenerationen geäußert. In sofern kann man sich auf jede menge Funktionen der Kontroll- und Regeltechnik freuen, mehr Individualität und Sicherheit. Wir freuen uns ebenfalls bald mehr Corsair Link Produkte vorzustellen, die immer mehr Funktionen und Kombinationsvorteile erlauben werden. Mit Corsair Link hat man auf jeden Fall ein sich stetig weiterentwickelndes System und jede der Corsair Link kompatiblen Produkte erweitern diese Möglichkeiten.
Corsair Light Bar Upgrade Kit CMDLBUK02B (Stand 30.03.2013)
Das Corsair Light Bar Upgrade Kit (CMDLBUK02B) ist nun auch in einigen Shops in Übersee und auch im UK (Scan) verfügbar. Der Preis beläuft sich auf umgerechnet 25,- bis 30,- Euro (Preisvergleich).
Die Bars selbst haben nun offenbar ein andere Oberflächentextur:
Mit dem blauen Inlay sieht das dann so aus:
Würde auf einem schwarz-blauen Mainboard sicherlich besser aussehen ;)
Corsair Dominator Platinum - Alternative Kühlung
Wir arbeiten daran in 2013 Luft und Wasserkühler ebenso wie einen LN2 Aufsatzadapter in den Handel zu bringen.
Der Könnte mir gefallen :). Aber die Corsair Link Kits sind in Deutschland immernoch nicht zu haben -.-
Die Corsair Link Kits sollen im September eintreffen (ohne Gewähr).
Den Speicher selbst gibt ab sofort, die Kits sind also schon unterwegs zu den Händlern ;)
ich werd mir mal das 1866iger Kit genauer anschauen ;)
wobei... meine Crucials laufen auch mit 1866Mhz....
Es ist
1. albern, dass > 2133 nur als 16GB erhältlich ist.
2. albern, dass man 2133 CL9 1,5V als "Platinum" neu auflegt, wenn die Dominator GT das schon seit Ewigkeiten können.
...und es is albern das erst jetzt langsam die Tempsensoren einzug halten in ddr3 modulen...gibt es auch in den crucials ich weiß matti :)
Sollten aber eig fast alle haben mittlerweile...mMn
@digidoctor: Wieso albern? Dass mit größeren Kits einfach mehr Geld zu verdienen ist und das beste Binning deshalb für größere Kits verwendet wird, sollte auch einleuchten und solange es keine neuen "Wunder"-Chips gibt, wird sich bei den Takt-/Timingkombinationen nicht viel ändern. Zudem sind die beiden Modellreihen durch die unzähligen zuszätzlichen Features der DomPLT sehr gut von den DomGT differenziert.
Bei anderen Herstellern ist die Farbe des Heatspreaders teilweise der einzige Unterschied zwischen verschiedenen Modellreihen ;)
Dafür wirst du die Lightbar tauschen müssen, schätze ich. Die Customization Kits soll es ab September im Handel geben.
Das steht so auch oben geposteten Press Release =)
Video Preview:
das würde ich gerne mal sehen auf einer intel plattform. :sleep:
Wenn man einen guten Kumpel hat, könnte man sich das auf 2x4 GB pro Nase aufteilen....es ist halt bei Garantietausch doof.
Ich bin mal gespannt, bei wie vielen von den inzwischen sieben gelisteten Kits die Timings im Preisvergleich noch geädert werden o_O
Hm..kann man die Heatspreader entfernen ? Arg hoch die Dinger.
das 1866iger Kit soll laut Geizhals um die 90€ kosten. Da bleib ich dann wohl doch bei meinen Crucies^^
@TobiasAlt: Nicht von den Preisvergleichsangaben täuschen lassen. Die Timings im ersten Beitrag beachten!
Ich habe im Corsair Herstellerbereich bereits eine Anfrage dazu erstellt (auch weil ich CL9-9-9-24 @ 1.5v für unrealistisch halte).
Bei SPD Latenz ist bei allen Kits von Corsair 9-9-9-24 angegeben, darunter verstehen sie normalerweise DDR3-1333, also die Frequenz beim ersten Booten wenn man selbst nix eingestellt hat.
Und CL11 scheint ein Fehler zu sein, das Kit heißt ja schon 2400C9. :hmm:
Timings bei 2133 schlechter als bei den jahreälteren Dominator GT (beide 1,5 Volt!) und kein 8 GB Set > 2133 ist einfach ein Fail!
Die Platinum Reihe soll die GT-Reihe nicht ersetzen. Eventuell kommen ja auch noch ein paar 8GB Kits...
