• Wir sind dabei, den Suchindex des Forums neu aufzubauen. Bis ca. 6 Uhr morgens kann die Qualität der Suchergebnisse variieren.
[Sammelthread] Asus Maximus V Formula (Z77)
WIP
Willkommen im Asus Maximus V Formula Sammelthread
Asus Maximus V Formula bei Geizhals.at
Bilder
Spezifikationen
Specifications
CPU Intel® Socket 1155 for 3rd/2nd Generation Core™ i7/Core™ i5/Core™ i3/Pentium®/Celeron® Processors*
Supports Intel® 22 nm CPU
Supports Intel® 32 nm CPU
Supports Intel® Turbo Boost Technology 2.0*
* The Intel® Turbo Boost Technology 2.0 support depends on the CPU types.
* Refer to ASUS for CPU support list
Chipset Intel® Z77
Memory 4 x DIMM, Max. 32GB, DDR3 2800(O.C.)/2666(O.C.)/2600(O.C.)/2400(O.C.)/2200(O.C.)/2133(O.C.)/1866(O.C.)/1600/1333/1066 MHz Non-ECC, Un-buffered Memory
Dual Channel Memory Architecture
Supports Intel® Extreme Memory Profile (XMP)
* Hyper DIMM support is subject to the physical characteristics of individual CPUs.*
* Refer to ASUS or user manual for the Memory QVL (Qualified Vendors Lists).
Graphic Integrated Graphics Processor*
Multi-VGA output support : HDMI/DisplayPort ports*
- Supports HDMI with max. resolution 1920 x 1200 @ 60 Hz
- Supports DisplayPort with max. resolution 2560 x 1600 @ 60 Hz
Supports Intel® HD Graphics, InTru™ 3D, Quick Sync Video, Clear Video HD Technology, Insider™
Multi-GPU Support Supports NVIDIA® SLI™ Technology
Supports AMD 3-Way CrossFireX™ Technology
Supports AMD CrossFireX™ Technology
Supports LucidLogix® Virtu™ MVP Technology *1
Expansion Slots 3 x PCIe 3.0/2.0 x16 (x16 or dual x8 or x8/x4/x4) *2
1 x PCIe 2.0 x4*
3 x PCIe 2.0 x1*
1 x mini-PCIe 2.0 x1 *3
Storage Intel® Z77 chipset :*
2 x SATA 6Gb/s port(s), red
2 x SATA 3Gb/s port(s), black
1 x eSATA 3Gb/s port(s), red
1 x mini-SATA 3Gb/s port(s) , black
Support Raid 0, 1, 5, 10
Supports Intel® Smart Response Technology, Intel® Rapid Start Technology, Intel® Smart Connect Technology *4
ASMedia® PCIe SATA controller : *5
4 x SATA 6Gb/s port(s), red
LAN Intel®, 1 x Gigabit LAN Controller(s)
Wireless Data Network Wi-Fi 802.11 a/b/g/n
Supports dual band frequency 2.4/5 GHz
Bluetooth Bluetooth V4.0
Bluetooth V3.0+HS
Audio SupremeFX IV built-in 7.1-Channel High Definition Audio CODEC*
- Output Signal-to-Noise Ratio (A-Weighted): 110 dB
- Output THD+N at 1kHz: 95 dB
- TI 6120A2 high fidelity headphone amplifier
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
Audio Feature :
- SupremeFX Shielding™ Technology
- ELNA premium audio capacitors
- 1500 uF Audio Power Capacitor
- Blu-ray audio layer Content Protection*
- DTS Ultra PC II
- DTS Connect
- Optical S/PDIF out port(s) at back panel
USB Ports Intel® Z77 chipset :*
4 x USB 3.0 port(s) (2 at back panel, blue, 2 at mid-board)
8 x USB 2.0 port(s) (4 at back panel, black+white, 4 at mid-board)
ASMedia® USB 3.0 controller :*
2 x USB 3.0 port(s) (2 at back panel, blue)
Overclocking Features mPCIe Combo™ (mPCIe/mSATA combo card)
ROG Connect :
- RC Diagram
- RC Remote
- RC Poster
- GPU TweakIt
Extreme Engine Digi+ II :
- 8 -phase CPU power design + 4 -phase iGPU power design
- 2 -phase Memory power design
ROG Extreme OC kit :
- Slow Mode
- LN2 Mode
- EZ Plug
ProbeIt
UEFI BIOS features :
- ROG BIOS Print
- GPU.DIMM Post
GameFirst II
iROG
Extreme Tweaker
Loadline Calibration
USB BIOS Flashback
Overclocking Protection :
- ASUS C.P.R.(CPU Parameter Recall)
Special Features ASUS TurboV EVO :
- CPU Level Up
ASUS EPU :
- EPU*
ASUS Wi-Fi GO!
- Wi-Fi GO! Function: DLNA Media Hub, Smart Motion Control, Remote Desktop, Remote Keyboard & Mouse, File Transfer, Capture & Send*
ASUS Exclusive Features :
- AI Suite II
- Ai Charger+
- USB Charger+
- USB 3.0 Boost
- Disk Unlocker
ASUS Quiet Thermal Solution :
- ASUS Fan Xpert 2
ASUS EZ DIY :
- ASUS O.C. Profile
- ASUS CrashFree BIOS 3*
- ASUS EZ Flash 2*
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Code
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM*
- ASUS Q-Connector
Back I/O Ports 1 x DisplayPort
1 x HDMI
1 x eSATA 3Gb/s
1 x LAN (RJ45) port(s)
4 x USB 3.0*
4 x USB 2.0*
1 x Optical S/PDIF out
1 x Optical S/PDIF in
5 x Audio jack(s)
1 x Clear CMOS button(s)
1 x ROG Connect On/ Off switch(es)
Internal I/O Ports 1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s)*
2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
6 x SATA 6Gb/s connector(s)
2 x SATA 3Gb/s connector(s)
2 x CPU Fan connector(s) (4 -pin)
3 x Chassis Fan connector(s) (4 -pin)
3 x Optional Fan connector(s) (4 -pin)
1 x S/PDIF out header(s)
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x 4-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x System panel(s)*
1 x Slow Mode switch(es)
8 x ProbeIt Measurement Points
3 x Thermal sensor connector(s)
1 x LN2 Mode header(s)
1 x EZ Plug connector(s) (4-pin Molex power connector)
1 x Power-on button(s)
1 x Reset button(s)
1 x Go Button(s)
1 x mPCIe Combo header(s)
Accessories User's manual
I/O Shield
2 x SATA 3Gb/s cable(s)
4 x SATA 6Gb/s cable(s)
1 x SLI bridge(s)
1 x Q-connector(s) (2 in 1)*
1 x ROG Connect cable(s)
1 x 12 in 1 ROG Cable Label(s)
1 x mPCIe Combo card(s) with dual band WiFi 802.11 a/b/g/n module + Bluetooth v4.0/3.0+HS module
1 x 2-in-1 RF Cable(s)
2 x Wi-Fi Ring Moving Antenna(s)
BIOS 64Mb UEFI AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI2.0a Multi-Language BIOS
Manageability WfM2.0, DMI2.0, WOL by PME, PXE
Support Disc Drivers
Kaspersky® Anti-Virus
DAEMON Tools Pro Standard
GameFirst II
ROG CPU-Z
Mem TweakIt
ASUS AI Suite II
ASUS WebStorage
ASUS Utilities
Form Factor Extended ATX Form Factor*
12 inch x 10.1 inch ( 30.5 cm x 25.7 cm )
Note *1: LucidLogix Virtu MVP supports Windows 7 operating systems.
*2-1: PCIe 3.0 speed is supported by Intel® 3rd generation Ivy Bridge Core™ Processors.
*2-2: x8/x4/x4 mode is supported by Intel® 3rd generation Ivy Bridge Core™ Processors.
*3-1: The mPCIe 2.0 x1 slot is located on mPCIe Combo™ expansion card.
*3-2: The mini-PCIe slot is pre-installed with an Wi-Fi/Bluetooth module.
*4: Supports on Intel® Core™ processor family with Windows® 7 operating systems.
*5: These SATA ports are for data hard drives only.
Downloads
BIOS, Drivers, ETC.
passende CPU Kühler
Luftkühler:
teilt mir eure Konfigs mit...
Wasserkühler:
Heatkiller 3.0 LC/LT, Copper, Black Nickel/Chrome
XSPC Raystorm
Passender Schlauch:
Primochill Schlauch PrimoFlex Pro 16/10 (3/8"ID) Clear
RAM
G.Skill RipJaws-X DIMM Kit 8GB PC3-17066U CL11-11-11-30 (DDR3-2133)
Patriot Viper 3 PC3-17000 2133 Mhz (2x4 Gb)
G.Skill Ripjaw Z F3 -17000CL9Q-16GBZH (4x4 Gb)
G.Skill Ripjaw X F3- 17000CL9Q-4GBXMD (2x4GB, 2 Kits in Vollbetückung laufen auch !)
More to come...
ohne änderungen läuft der speicher halt auf 1333 ... standard sollte ja zumindest 1600 sein ... d.h. der speicher läuft nicht nur langsamer als er lt. hersteller kann sondern auch langsamer als er soll :(
Falsch.
SPD Geschwindigkeit des Rams ist 1333 Mhz (Jedec) und das wird vom Board als "Standard" ausgelesen. Also völlig korrekt.
XMP Profile funzen oft nicht durch automatisches Laden der Einstellungen. Da muss man dann die Werte manuell eingeben.
Es kann aber auch sein, dass die Cpu ein Problem mit 32 Gb Speicher hat und Du da Nebenspannungen anpassen musst (Vcsa,vtt,vdimm).
Probier einfach mal, ob es mit zwei Riegeln also 16 Gb klappt.
ist doch blöd das ganze ... hab den speicher extra aus der kompatibilitätsliste gekauft um genau so nen scheiss zu vermeiden ...
und wie hast du den speicher laufen? 1866 lt. xmp profil? hast du sonst noch was übertaktet? könntest du screenshots (oder abfotografieren) machen von den bios einstellungen (ganze seite da ja nicht alles auf einen screen passen wird) ... danke!!!
Stell ma den Ln2 schalter um evtl. hilft der bei Dir ja auch was o_0
is oben Rechts zu finden.
mich würden da erst eher details zu Lajocy's einstellungen im bios im detail interessieren ...
phlebiac
du mußt dich mal weng einlesen wegen den spannungen , dann manuel alle fix einstellen ......
bei vollbestückung mußt du eventuel VCCIO weng anheben damit es dann stabil wird wegen der vollbestückung
VCCIO ist Max von Intel vorgegeben mit 1.080 V
IMC/VCCSA ist Max von Intel 0,971 V angegeben
Ich hatte bei vollbestückung Vccio 1,062 V ungefair und VCCIO 1,059 V
eingestellt
aber erhöhe wenn die spannungen nur langsam und nicht gleich denken paar milivolt mehr wird nicht schaden da mußt dich rantasten ;-)
:) ich wüßte selber gerne die bios einstellungen die ich haben will ...
das hier ist mein speicher: Vengeance®
wird im bios als 1333 angezeigt
cpu-z sagt:
dram frequency 668.7 MHz
FSB : DRAM 1:5
CL 9.0
tRCD 9
tRP 9
tRAS 24
CR 2T
lt. herstellerseite
SPD 1333MHz
SPD Latenz 9-9-9-24
geprüfte geschwindigkeit 1866MHz
Getestete Latenz: 10-11-10-30
ich will nur den speicher entweder zumindest auf 1600 oder eben 1866 laufen lassen und das mit so wenig wie möglichen einstellungen im bios, schon gar nix mit spannungen usw. verändern
aktuell hab ich alles auf auto
hilft dir das mir zu helfen?
mit spannungen verändern will ich eigentlich nichts zu tun haben, ist mir zu heiss da was - und wenn auch nur versehentlich - falsch zu machen, dann lass ich den mist lieber auf 1333 laufen
was genau hat es eigentlich mit den 1333/1600 lt. ARK | Intel® Core auf sich bzw. wie muß ich das verstehen?
ich hab mir das beim kauf halt so vorgestellt: der speicher ist in der kompatibilitätsliste und ich bau den ein und entweder wird er automatisch erkannt (wird er ja auch nur halt auf 1333) oder ich stell irgendwo einfach auf 1866 um und dann läuft das ... :(
und einlesen: ich wüßte nichmal wo ich damit anfangen sollte und wenns nicht auf "normalem" weg (drop down aufmachen 1866 wählen höchstens noch manuell latenzwerte lt. herstellerangaben anpassen) geht dann ist mir meine hardware zu teuer/wichtig um durch nen fehler irgendwas kaputt zu machen
@phlebiac
nun wenn du nichts mit den Spannungseinstellungen zu tun haben möchtest , tja dan lass deine Riegel so weiter laufen wie gehabt . Du wirst nicht drum rum kommen deine Spannungen Manuel einzustellen wenn du die Riegel mit 1600MHz oder 1866MHz laufen lassen möchtest .
Dazu noch wenn du Bioseinstellungen von jemand anderem übernimmst,muß es nicht heisen das es dann bei Dir auch läuft .
Fakt ist entweder du liest dich weng ein mit den Spannungen oder Du lässt es ganz einfach bleiben
wenn du nicht weist wo lesen googel hilft gib mal ( Ivy Bridge overclocking )ein dann kommen einige seiten die von profis erstellt worden sind die auch verständlich geschrieben sind .....
m.f.g. Razzor
Alle Ramspannungen/ Veränderungen kann er gerne übernehmen.
Da passiert nichts. Vorsicht aber bei den CPU-Einstellungen, die sind erstens CPU-abhängig,
außerdem kühle ich mit Wasser. Hab übrigens auch die Southbrigde unter Wasser. Mit ein bisschen
Bastelei überhaupt kein Problem.
was will er den da übernehmen ????:d bei dir steht doch alles auf Auto......
ausser die Dram Voltage, die hast weng angehoben ...... Der Speichercontroller ist in der CPU und hat nichts mit der Southbridge zu tun
Sein Speichercontroller wird mit der vollbestückung nicht klar kommen , bei einem takt von 1600MHz , daher vermute ich das durch eine leichte anhebung der VCCIO und VCCSA spannung das problem aus der welt geschaft ist ... ;-)
mit freundlichen grüßen Razzor
@ Lajocy: erstmal danke!!!
bezogen nur darauf den speicher auf 1866 zu bekommen:
hast du hier nur die memory frequency und DRAM Voltage geändert? (und wie bist du auf 1.55000 DRAM Voltage gekommen?)
und rest auf auto gelassen? bzw. muß ich sonst noch was ändern? einige änderungen betreffen ja dein cpu OC
warum verwendest du das xmp profil nicht?
und wieviel speicher hast du überhaupt? 2 x 8 oder 4 x 4 oder 4 x 8 ? und sicher genau denselben wie ich ?
@ Razzorone: ja nur laut hersteller sollten die riegel sowohl bei 1333 als auch bei 1866 mit 1.5V laufen ...
und google: dies ist mein erster kontakt mit OC von daher kann ich als laie nicht beurteilen welche artikel gut sind und welche nicht ... zumal die meisten ja nicht nur den ram wie in meinem fall "overclocken" sondern auch die cpu ... hier versteh ich auch nicht ganz warum man cpu overclocking nicht visuell im bios bzw. overclocking menü trennt vom ram overclocking ... würde die sache imo einfacher machen ...
und wenn ich nur memory frequency auf 1866 und dram voltage auf 1.55000 ändere ... und beim booten keine fehlermeldung kommt ... reicht das dann schon um zu sagen es hat funktioniert oder wie kann ich das dann am besten und gefahrlosesten testen hinsichtlich systemstabilität
Einfach in das Feld 1.55000 eingeben und mit Enter bestätigen. Ich brauchte diese Spannungserhöhung wegen der 32 GB .
Kannst zuerst mal mit Aida 64 überprüfen. das reicht vorläufig.
danke ... ich werds heute noch ausprobieren ... kann aber noch 2-3 stunden dauern ... hab grad zuviel offen
woher hast du die 1.55000 ? durch ausprobieren? oder andere quelle? wenn ja welche?
Die Riegel wurden beim Hersteller auf 1866MHz getestet mit der angegebenen DRam voltage . daher kannst du die angegebene Spannung 1,5Volt laufen lassen mit 1866MHz
da der Speichercontroller aber in der CPU ist mußt du die Spannungen anpassen..... es ist halt nunmal so. Der Speicher läuft ja auf deinem Board .
Eine vollbestückung ist immer Problematisch dazu noch höheren takt .......
Standart Spannung :
VCCIO 1,050 Volt
VCCSA 0,925 Volt
CPU PLL 1,8 Volt
PCH 1,050 Volt
diese spannungen kannst du fix einstellen da diese Intel vorgaben sind , dann versuchst du mal VCCSA um eine stufe hoch zu stellen mit der + Taste dann raus ausm Bios , Speichern und Exit .Wenns immer noch nicht geht nochmal ne stufe hoch , geh mal 3 stufen hoch insgesamt ....
wenn das nichts genutzt hat gehst du mit VCCIO mal eine stufe hoch .......du mußtr dich da ran tasten
Testen ob das ganze stabil ist kannst du z.B mit INTEL BurnInTest findest du mit googel ;-)
OC ist immer alles auf eigene Gefahr , nun mußt du eben für dich entscheiden ob du dich da ran traust ......
zum teil versteh ich das aber andererseits auch wieder nicht
wenn asus ein mainboard wie das maximus v formula auf den markt wirft und sagt da läuft ne i7-3770K cpu drauf und dann in ihre ram kompatibilitätsliste unter 1866 schreibt speicher x (in meinem fall also das 32 gig pack und nicht nur ein 16er davon) dann gehe ich davon aus das reinzustecken und es funktioniert ohne dass ich da noch spannungen oder volt oder was auch immer (ja, kein plan) umstellen muß ... höchstens von 1333 auf 1600 oder 1866
was es im zusammenhang mit der cpu mit 1333 und 1600 auf sich hat weiß ich im übrigen immer noch nicht ...
jo Asus gibt auch lauter Overclocking funktionen mit, wenn man aber beim ASUS support anruft wird Dir da keiner Auskunft geben für was die sind :d ist doof is aber so ......
was meinst den genau mit zusammenhang, CPU mit 1333 und 1600
hmm ... also warum es z.b. überhaupt die angabe 1333 und 1600 gibt und was vor allem die 1600 da zu suchen hat wenn standard 1333 ist
so ... habs erst heute geschafft auszuprobieren ... sowohl einfach memory frequency auf 1866 gestellt mit 1.55000 dram voltage als auch xmp profil geladen und dann auf 1.55000 dram voltage gestellt ... bei beiden kommt beim raus ausm bios reboot ein 55 ram not installed, muß dann rechner ganz ausmachen und neu starten, dann kommt overclocking fehlermeldung
steht jetzt also erstmal alles wieder auf standard mit 1333
@Lajocy: falls du mal zeit hast, du kannst ja deine aktuellen einstellungen als profil speichern und jederzeit wieder laden, von daher sollte es schnell ausprobiert sein: du hast ja auch deine cpu übertaktet und da ebenfalls paar einstellungen geändert die sich vielleicht dann auch auf den ram auswirken ... könntest du mal die default settings laden, also damit alles so wie bei mir ist, und dann mal versuchen nur den speicher auf 1866 zu bekommen? natürlich nur mit memory frequency auf 1866 und dram voltage auf 1.55000 ...
und was mich noch interessieren würde, wie hast du dich an die 1.55 rangetastet? was waren deine ersten versuche und in welchen schritten von wo nach wo bist du bei 1.55 gelandet?
im xmp profil steht übrigens was von 1.50V-1.30V ... und wenn die 1333 mit 1.5V laufen wovon muß ich dann ausgehen bei 1600 oder 1866 ... weniger oder mehr als 1.50V ???
ich werd morgen oder so dazu wohl noch ein eigenes topic aufmachen weil das hier eigentlich etwas zu speziell wird
Wenn der Takt wächst, wächst auch die Spannung. Im Idealfall bleibt sie wie sie ist, niedriger wird sie eigentlich nie.
Geh bei deinen Test in 0,02 V Schritten vor, bis du ihn das erste Mal richtig stabil hast. Danach kannst du dich mit kleineren Schritten nach "unten" zurück bewegen bis es wieder instabil wird und schon hast du deine Grenze.
Du darfst nicht vergessen, dass du hier an mehreren Grenzen der CPU stehst: Maximaler Speicherausbau ( Sowohl bei Menge als auch bei Riegelgröße ), oberhalb der empfohlenen Frequenz. Da kann es, Kompi hin oder her, mal passieren, dass man anpassen muss. Dafür streuen auch die IMCs einfach zu stark.
@phlebiac
du kannst die Dram spannung auf 1,6 stellen und du wirst die gleiche fehlermeldung bekommen , die fehlermeldung 55 ist Memory not installed ..... dein speichercontroller kommt damit nicht klar deswegen , wie ich schon davor erwähnt habe, nußt du deine VCCIO / Vccsa anpassen ..........
m.f.g. Razzor
Habe da einen anderen Verdacht: sind deine Riegel eigentlich richtig fest reingedrückt in die Sockel???
alle rausnehmen und alle nochmal rein drücken. Da geht nichts kaputt, aber die müssen bombenfest sitzen!!!
danke, ich werds bei gelegenheit nochmal ausprobieren, also auch speicher nochmal rausnehmen und neu einbauen, und auch das mit vccio und vccsa
@phlebiac
m.f.g. Razzor
Muss nicht. Ich kann 55 auch hervorrufen, indem ich die Timings/Frequenz überreize bzw. es mit dem VDimm untertreibe. Geht alles.
erstmal werd ich den ram auf 1333 lassen ... hatte gestern und heute jeweils 1 x rechner aus im laufenden betrieb (windows, in beiden fällen nicht wirklich was nennenswertes gelaufen), im event manager steht natürlich nix :( ... hab nun erstmal die ai suite (hat mich irgendwie eh genervt weil ständig die lüfter drehzahlen verstellt waren oder lüfter nicht liefen usw.) komplett deaktiviert und kucke mal was passiert
irgendwelche ideen was für das rechner aus noch verantwortlich sein könnte? dass ich direkt defekte hardware (psu, mainboard, ...) erwischt habe schließe ich erstmal aus
dafür grad ne runde portal 1 mit allem bis zum anschlag gespielt ... zumindest die gpu scheint es nicht bemerkt zu haben :) temperatur blieb konstant bei 45° was ich auch im idle hab
@ Polarcat
das aber in seinem fall nicht so ist , da die Riegel ja auf 1866 getestet sind, also sollten sie die frequenz auch mit machen.....
nun ich mußte bei mir auch die VCCSA/VCCIO anpassen bei vollbestückung sonst liefen die auch nur mit 1333MHz
Corsair Dominator Platinum 2x4GB
Geil Evo Corsa 2x4GB
nun ich habe ihm auch mal geraten sich weng einzulesen was es damit auf sich hat , links gepostet wo wissenswertes darüber drin steht
da er ja tips wollte aber eigentlich keins davon annimmt weil , was hätte wäre wenn und was weiß ich noch.......
dann ist es das beste er belässt alles so wie es ist..........
m.f.g. Razzor
