- Ort
- Pampa
- Desktop System
- PSBOX
- 7800X3D
- Strix X670E-A
- EK Velocity
- Kingston Fury Renegade 64GB
- RTX 5090 incoming
- Asus Rog Swift PG32UCDM
- M.2 1TB SIlicon M.2 980Pro 2TB M.2 980Pro 1TB
- Soundkarte
- Soundblaster G6 +HIFIman Arya+Endgear Microfon
- Lian Li O11 Vision Chrome Mora 420
- Corsair HX1200i
- Keyboard
- Logitech G915
- Mouse
- G502
- Win11 Pro
- Internet
- ▼100mbit
Gerade noch gelesen das bei dem Exemplar bei 3600 MHZ auch ende ist beim Ramtakt !
I also wanted to get you a run with DDR4-4000 CL16, but that was a no-go as the FCLK maxes out at 1867 MHz, which might already have some silent WHEA errors, so our default 1800 MHz FCLK, 1:1 with 3600 MHz memory is pretty much the best you can do unless you win the silicon lottery. Tightening the memory timings a bit further from DDR4-3600 CL16 1T to CL14 could be an option to eke out a bit more performance, but it won't be a night and day difference.
