[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Was habt ihr alle für Schneckenhäuser? Passt in mein jetziges Silverstone sowie in mein neues Phanteks Enthoo Pro 2, in dem ist dann auch noch ordentlich Luft unter der Karte + Bodenlüfter (Empfehlung :d)
Mein Case scheint für 5090 und 6090 zukunftssicher zu sein - Max 470mm :d
Aber eh Wurscht bei wakü
Lian Li PC O8, AGB extern hinten angehängt.
Maximale Länge der Graka 370mm
Da geht einiges, aber nicht alles. Aber ne Stix wird wohl passen.
Lukü und „Leise“ hat für mich noch nie gepasst. Ihr habt die Screens zu 3Ghz gesehen? Lüfter auf 100%, also Flugzeugturbine Und trotzdem nicht unbedingt kühl. Schade für die, die ihren PC auf dem Tisch direkt neben dem Ohr haben …. 8-)
Ist jetzt ausverkauft o_O
Das ging aber schnell... :fresse:
Haben die Corsair-Kabel einen größeren Querschnitt bei nur 2x 8Pin am NT
? Ich mein, wenn andere Hersteller 3x Stecker ab N-TRACK anbieten...
Spätestens wenn die ersten Strom/Gas Nachzahlungen fällig werden, wird der Markt von gebrauchten 4090 überschwemmt. :ROFLMAO:
Können 4090 gepfändet werden oder zählen sie zur „Grundversorgung“? :fresse2:
Plague Tale Requiem scheint ein guter erster Titel für die 4090 zu werden. Mit Ultra-Details wird für 1080p 60fps eine 3070 verlangt. Wenn man sich die Optik und insbesondere die Beleuchtung anschaut ist das für mich kein Wunder.
Ich denke neue Titel, die aktuelle Konsolen als Target haben, werden sich alle in diesen Gefilden bewegen, was die Systemanforderungen angeht. Somit ist eine 4090 keineswegs Overkill, sondern vermutlich auch eine der wenigen Karten, die eine gute Performance in 4k mit RT abliefern können.
Krass, ich hätte gedacht, daß in Deinem Gehäuse mehr geht. Aber wenn ich sehe wie hier manche ihre Gehäuse gemessen haben mit Zollstock außen am Gehäuse, dann würde mich nicht wundern, wenn der ein oder andere dann beim Einbauversuch doch noch merkt, daß da ein Teil im Gehäuse unerwartet den Raum verkleinert ;) Ein großens Gehäuse und ein großes Gehäuse ist hier nicht zwangsläufig das gleiche ;)
Grafikkarten werden normalerweise nicht einzeln gepfändet wenn sie eingebaut sind, sondern da wird wenn der ganze Rechner gepfändet. Unterschieden wird höchstens zwischen PC und Peripherie, aber PC ist eine Einheit. Wenn man es schafft ihn als unverzichtbar zu deklarieren gilt das eigentlich auch für die Grafikkarte ;)
Also ich finde den Boost Takt für sehr wichtig.
Ich verstehe aber auch noch nicht so ganz den Nutzen, der Boost-Takt hängt doch letztendlich auch von Auslastung, Kühlung usw ab. 3GHz wird man auch sicher nur in bestimmten Szenarien hinbekommen, bei anderen liegt er dann niedriger. Da kann es schon Unerschiede machen wie gut ein Kühler montiert oder die wie Wärmeleitpaste verteilt ist, ob eine Karte höher oder niedriger boostet. Für meine persönliche Kaufentscheidung ist diese Tabelle daher ziemlich nutzlos. Aber das ist nur meine Meinung, wenn sie Dir hilft ist ja alles ok :)
Welche Karten genau haben denn jetzt ein Bios für 600w? Hab da irgendwie den Überblick verloren.
Der große Nachteil bei den FEs, beim Umbau auf Wakü hat man bei nvidia direkt gelitten wenn doch mal ein Defekt auftritt.
Bei MSI, ASUS und Zotac stößt man da auf deutlich mehr Kulanzfreude. Das sollte man als Wakü Mensch vielleicht mit in seine Entscheidung einbeziehen.
Die schönste Luftkarte sollte ihr „Kleid“ anbehalten - Punkt :-)
Die anderen Karten dürfen ruhig nackt und nass gemacht werden :fresse:
Werde ich Probleme haben mit diesem Netzteil..?
HX1000 – 80 PLUS® PLATINUM​
Lg
Wenn Du es zusammen mit einem Threadripper und der 4090 betreibst: Ja.
Zum Beispiel: Eine ASUS Strix und eine Strix "OC" haben exakt die gleiche Hardware. Was rechtfertigt den höheren Preis?
ja die Hardware ist gleich, nur das Bios hat unterschiedliche Limits, ich denke, dass die OC mit Bios welches die höheren Limits hat getestet wurde, das muss aber nicht heißen, dass der Chip einer non OC schlechter taktet, wenn man selber Hand anlegt, so würde ich das verstehen.
Ob es den Mehrpreis rechtfertigt muss jeder selber entscheiden.
Wie gesagt, ein Techniker mit etwas Ahnung sieht das, egal was du machst. War alles im einwandfreien Ursprungszustand.
Kaputt war bei allen 3 Karten der GDDR6X Speicher. An den Temperaturen kanns übrigens nicht gelegen haben.
Es gibt einen Luxxer, der Erfahrung mit RAM-Chips-Tausch hat. Aber, ob er dass auch für andere Luxxer tun würde k.A.
Na super, dann brauche ich ja noch ein neues Netzteil Corsair hx1000 W Platinium reichen nicht für eine GPU mit 600w :coffee:
Lg
Ist aber kein ATX 3.0 Netzteil .
Denke mit einem guten 1000watt kommt man locker klar . Also im Härtefall 600 GPU + 250 CPU und Board + schnick schnack 50-60 Watt . Das sollte gehen . Im Gaming ist das alles wesentlich weniger . Glaube auch garnicht , dass die 4090er 600 Watt schlucken .
Ähnliche Themen
Antworten
6K
Aufrufe
392K
