[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ich kanns mir einfach immer noch nicht vorstellen dass das funktionieren wird. Auf ebay gibts gerade ne 3090 FE für 1000€ Sofortkauf. iwelche Customs findet man sicher auch iwo unter 1000€
Warum also nem Scalper 1000€ geben wenn man 2 High End GPUs haben könnte? ne 3090 zum überbrücken und iwann die 4090.. danach die 3090 wieder verkaufen.
Also nem Scalper würd ich die 1000€ sicher nicht schenken!
die 3090 ist ab dem heutigen tage kein "high end" mehr wenn man es genau nimmt :)
Das sehe ich anderst. 🤷‍♂️
Im Warenkorb ist das eine, ein erfolgreicher kauf etwas anderes.
Wieviel bestellungen wurden storniert ? Mehr als genug
Ich bin immernoch in der Schwebe..ich glaube meine Bestellung ist irgendwie vom "System" geschluckt worden, obwohl nichts ungewöhnliches bei der Bestellung statt fand.
Ich werde morgen mal freundlich nachfragen und darauf hinweisen, das ich eine FE haben will. :d
Kann mir gut vorstellen das für die Suprim X via Bios Update ein PT Erhöhung kommen könnte.
default wäre interessant. 100% ist ja cheat :d
Also wenn die Suprim X wirklich nur 5xx Watt hat, bin ich froh, dass ich sie nicht bestellt habe. Hatte heute um 15:05 Uhr mal mit dem Handy an der Arbeit bei CK reingeschaut, da gab es bei Alternate noch nichts. Hatte dann einen Termin und anschließend waren alle weg. Die Strixx sieht interessant aus aber ich wollte kein Asus Produkt mehr. Ich schau mir nun mal die Reviews der Customs an.
Richtig. 600W Volle kanne Volllast.
Kein Scherz
Ich habe gerade mal 5 Minuten gezockt mit 450W. Karte wird nicht wärmer als 45/46 Grad. Die STRIX ist ein Monster.
Zimmertemp 18 Grad? Auf TechPowerUp hat Sie unter Last 62 bzw. 65°C
wenn ich den pc jetzt rausstelle dann hat meine 3080ti bei 400w auch 40 grad :d
600W mit 50% Lüfterspeed = Max 55 Grad.
PC ist ganz normal im Zimmer. Temperatur im Zimmer liegt bei 22Grad.
Gibt es nun irgendwo eine Übersicht, welche Karte ab Werk 600W PL hat und welche Ref ist?
Mache ich bis Freitag alles fertig. Erste Seite wird es dann stehen.
das kann doch net sein. 55 grad bei 600w pl bei 50% fan speed
hast du eigtl die beiliegende gpu stütze benutzt?
Nein. Mein Gehäuse ist zu groß. Eventuell baue ich mir was mit Playmobil oder Legosteinen :d
Ich kann es bisher auch nicht glauben. Aber laut MSI Afterburner, Stats im Benchmark und in GPU-Z sind alle Ergebnisse korrekt.
die leistung stimmt auch bzw kommt hin mit dem was sie soll? auslastung auch am anschlag?
Hält den Takt locker bei 2820mhz ohne OC.
Bios-Switch im OC Mode?
Sehe gerade beim Suprim X Test, dass die ihre 2835mhz macht, somit würden die Karten sich nicht viel nehmen.
Ich hoffe die schieben noch ein Bios Update für die Suprim X hinterher, wie damals bei der FTW 3 Ultra.
Wäre schön, wenn jmd ausser @SH noch so einen Bench nachschiebt (nur dieses Settings einstellen)
Lg
Ja ist immer Powermode.
Suprim und STRIX trennen nur 30mhz.
Siehe unten die Tabelle. Habe sie auf der ersten Seite geupdated. Danke an @Brainscan1979
Ähnliche Themen
Antworten
6K
Aufrufe
392K
