[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Nicht? Was kann man denn z.B. bei der FE oder der Strix/TUF maximal an Spannung einstellen?
Naja, wenn ich schon über 2k ausgebe möchte ich auch alles ausschöpfen was die Karte kann.
Ärgerlich das mir so etwas passiert. Dort werde ich nie wieder etwas kaufen. Als der 11900K am Markt kam, kaufte ich auch dort ein und die Cpu war auch im Arsch.
Ständig Bluescreen konnte kein einzigen Bench laufen lassen.
Nächste Woche bekomme ich noch eine aus dem ASUS Shop, hoffe die geht dann..... ich werde berichten.
Sagen wir es mal so...warte auf 13900K und dessen Tests oder auf den 7800X3D, weil derzeit sitzt du so oder so im CPU-Limit.
Soweit ich weiß von 1,05V stock auf 1,1V...
Was geht nicht wirklich?
Wieviel PL kann sie und wieviel erreicht sie max?
Die 4090 kann wegen dem Spannungslimit von 1,1V keine 600W erreichen.
Mann muss auf neue Versionen vom Afterburner und Co warten...wenn das überhaupt was bringt.
Da der Chip nur Aktuell 1.1v max hergibt kann es technisch aktuell garnicht möglich sein 600w zu ziehen. Als peak ja aber sonst nicht. Guckt euch das Video von Bauer an da erklärt er es
naja, mehre MSI, ASUS, gigabyte oder andere name egal, das GPU alle gleichen für original NVIDIA.
Also, Original GPU Nvidia founders edition.
kein original für ASUS, MSI, gigabyte oder mehre egal name. GPU ist Nvidia original gehört.
Wettbewerb Witz für ASUS, MSI, gigabyte oder egal name wegen krieg markt gewinnen. :rolleyes:
Leistung MHZ unterschied Beispiel ASUS 1600mhz, MSI 1690mhz oder gigabyte 1720mhz.
nicht einfach, GPU alle gleich, aber bios andere wegen Einstellung MHz krieg Wettbewerb.
Leistung fehle möglich Grafikkarte Gheistaufgeben zu GPU totalschade.
Garantie möglich, aber warning wenn overclocking schnell kaputt, dann Garantie nicht erlaubt. selbst schuld.
overclocking missbraucht Garantie prüfe system firmware sehen, dann lehne ab Garantie. ob möglich sicher! :coffee2:
Daher meine Frage oben...
Was ist denn nun maximal möglich an PL?
(die Frage geht nur an Leute, deren Karte 600W PL im BIOS stehen hat. Bitte dazu schreiben, welche Karte ihr habt)
Also genau wie bei mir. Bei allen Karten gleich? Das ist ja schade :(
Bei 3090 ging auch nur max. 1,1V. Kein Grund traurig zu sein ;)
@alle mit 600W PL
Wurden bei euch die 600W jemals erreicht in irgendeinem Game/Bench?
Das mein Herr werde ich mit der Auros Master als erstes prüfen !
Roman konnte glaub ich Peak 540 messen bei 1.1 V 3015 MHz im Benchmark!
Aber ich glaub da findet sich ein Game was mehr Zieht!
Allgemein finde ich aber die 600W Top endlich mal nicht so limitiert!
Am Ende kommt es aktuell halt auch drauf an wie gut das Silizium ist!
Bin mal auf die Temps usw gespannt !
Ein Ek wird es ja für die Master geben das würde ich aber davon abhängig machen ob es eine Perle ist oder ehr ein Durchschnitts Chip.
Ob es ein Bios geben wird das noch mehr V erlaubt …Mmh?
Na sowas...
Gestern noch 6-7 Wochen - jetzt wieder 1-3 Tage :d
Wird doch nicht der Block sein, den ich gestern storniert hab :fresse:
Die Lüfter meiner Palit RTX 4090 Gamerock haben nervige Motorgeräusche. Vielleicht ist aber auch nur einer irgendwie defekt oder so. Zwar nicht laut, aber hört sich an wie ein Sägewerk. Sobald die Lüfter ausgehen ist alles still. Ansonsten performt sie im Fractal Torrent überdurchschnittlich gut laut 3DMark... Vielleicht auch Sounddesign, um das Spulenfiepen zu übertönen. 😅
Also doch nicht das PT, sondern die Kurve?
Ich hab mal schnell AC Valhalla mit 80% PT und mit 133% PT getestet. Nen Unterschied gibts da nicht, obwohl es nicht nach CPU-Limit aussieht, die Karte liegt zu 99% bei 96% oder mehr Last.
Anhang anzeigen 802636Anhang anzeigen 802637
Ist der Graph bei euch auch so voll mit Spikes? Ich hab leider keinen alten Screen mit der 3090 gefunden, aber ich glaub bei den ganzen AC-Games war der Verlauf nie "glatt".
mit 100 und mit 133% PL
tobi
Die Spikes kommen von deiner CPU :d
Da steht doch CPU Frame 25ms bzw 58ms max...DAS sind die Spikes.
Vielleicht sollte ich im Hintergrund keine Updates laufen lassen^^
Aber na klar. Jetzt wo Du es sagst. Allerdings sehen die auf dem Screen von Tobi auch so aus.
Die Lüfter meiner Palit RTX 4090 Gamerock haben laute Motorgeräusche. Vielleicht ist aber auch nur einer irgendwie defekt oder so. Fast wie ein Sägewerk hier. Sobald die Lüfter ausgehen ist alles still. Ansonsten performt sie im Fractal Torrent überdurchschnittlich gut laut 3DMark...
Du scheinst das selbe Problem zu haben wie wir mit unsere Gainward GeForce RTX 4090 Phantom da Gainward/Palit die gleiche Marke Hersteller ist
Schreib mal memphis@mg er Sammelt die Seriennummer von denn Karten und sendet sie an Gainward es scheint wohl ein größeres problem zu sein mit denn Lüftern
Da wird schon noch was kommen :)
Naja, schon, denn so kann man das Powerlimit halt nicht ausreizen :d
War mit der 3090 auch nicht anders, nur dass das PL limitiert hat. Nun ist es die Spannung
Dreht man hier, limitiert es dort...
Will eines von den EVGA RTX 4090 Kingpin Samples. :LOL:
Bringt nur nichts, wenn bestimmte Sachen auf dem PCB fehlen, die die Kingpin hatte (der Classified Controller ;))
Ich werde EVGA vermissen... :cry:
download.axd
ich wollte damit eigentlich sagen, dass es shice-egal ist was da steht. die karte hat soviel ram, dass du nie in die verlegenheit kommst, dass sie über ihr interface auf den langsamen systemspeicher swappen wird. warum das bei dir so angezeigt wird, kann etliche ursachen haben.. von softwarefehlern bis kontaktschwierigkeiten oder stromsparmodi.. solange es die performance nicht beeinflusst, würde ich es schlicht ignorieren. oder stellst du dir echt vor, dass du damit irgendwo die 11000 schaffst, wo jetzt bei 10700 schluss ist? die chance besteht.. die graka könnte aber auch schon mit dem nächsten treiber von ganz allein dahin kommen..
btw,
ich hatte gedacht, die können alle schon PCIe 5.0
edit
tobi
Ja ne mir ist es klar, dass es nur minimal ist und insgeheime hoffe das es ein Treiberfehler ist. Aber ich habe für die Karte am launch Tag 2350€ bezahlt und gestern habe ich eine zur UVP im Asus Shop für 2250 bekommen. Mit dieser werde ich gegen testen und die teurer geht dann zurück.
Deswegen habe ich ja in die Runde gefragt ob das jemand mit einem Z590 Board auch so geht.
Hab die Nieten geknackt... damit ist aber der Käfig im Arsch.
Form follows Function :d Was ich schon alles an meinem Gehäuse im Laufe der Zeit "erweitert" habe, das wechselt schon die Farbe von schwarz nach grau wenn ich wieder mit dem Dremel oder der Bohrmaschine anrücke :asthanos:
Kommt da wohl ein Kühler??
lol, AC bringt also einen Referenzdesign Kühler
@HisN Tobi hat genau dasselbe Problem: Die CPU erzeugt die Spikes. Der Benchmark sagt ganz klar aus, das die GPU nur maximal 9-10ms pro Frame brauchte, aber die CPU 21-22ms. Je höher, desto niedriger die FPS, ergo Spike. Ist ja auch nur ein 9900k :d
Ähnliche Themen
Antworten
6K
Aufrufe
392K
