[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ja wenn ich Zuhause wäre könnte ich dir schnell Nachweise zeigen (in Spiderman, Far Cry 6, BF2042, Warzone und wie sie nicht alle heißen... in 4587x1920 (und jetzt sag nicht "ist nicht UHD" das sind 8,8 Mio Pixel... UHD hat weniger), aber die Diskussion bringt doch jetzt auch nicht wirklich was, und gehört in dem Umfang hier auch nicht mehr rein denke ich :)
Wieso bringt die nichts. Genau das war die Ursprungsfrage. Und die hatte ich dem User geantwortet. Danach meint Ihr ich wäre falsch könnt aber kein konkretes Ergebnis nennen. Dann beendet ihr lieber die diskussion da die argumente ausgehen.
Echt noch keine mit den Thema Bios flash beschäftig?
Habe ich gemacht. Meine GPU ist dann bei 99%! Sehe da keinen CPU Flaschenhals.
RTX 4090 - 21:9 // Overkill for 3440x1440?​
ich dachte wir reden von UHD???
Und jetzt die wichtige frage.
Hast du bei deinen 99% gpu load 144fps oder deine Wunsch fps erreicht?
Wie viel hast du denn im Schnitt?
nen block mit anschlüssen am langen ende ist noch nicht angekündigt oder? so wie das ek ding von der 3090
Für manche vielleicht interessant :)
Ach, wer hätte das gedacht? :-)(y)
Drop cu? Nix 14 Uhr?
Ok. Gebe mich geschlagen. Das liegt aber irgendwie an dem game.... mehr beispiele wirds wohl nicht geben oder?
Hallo Zusammen,
da ich neu im Forum bin, kann ich keine PM an memphis@mg schicken. Soweit ich das gelesen habe sammelt er / du (falls du es selbst liest :d) die Seriennummern von den Gainward Phantom Karten.
Zu meiner Phantom GS -> bei 30% Lüfter das schöne Rasseln oder was auch immer der / des defekten Lüfter/s. und wenn sie höher drehen sind Frequenzen dabei, die meinen kompletten Tisch vibrieren lassen.
Habe das Ding bei Alternate gekauft und dort vorhin auch mal den Support angehauen. Mal schauen was die dazu sagen.
Aber auch um was positives zu bereichten - kein Spulenfiepen und aus dem Stand heraus macht sie erst mal 2820 Mhz ohne dass ich da mit Tools was verändert hätte.
mfg Zorn
Habt ihr mal geprüft ob es ggf die Lamellen vom Kühler sind die ab einem bestimmten Luftstrom zu vibrieren anfangen?
Habe das heute an meiner FE festgestellt, Damit hat sich das Problem an meinem Auslasslüfter mit dem "Zirpen" scheinbar erledigt. Etwas die Lamellen gedrückt und dann wars wieder ruhig.
Keine Ahnung, ist natürlich auch ne Möglichkeit.
Ich will doch nur ACC endlich ordentlich in VR zocken 😁
Mfg
Kiryu
Wo du es gerade anspricht...
Hab mit VR-Gaming null Erfahrung. Welche Titel sind begehrt und welche VR-Brille taugt was?
Reverb G2 wurde gerade genannt - bin gespannt
(funktioniert die Brille auch mit der PS5?)
Habe nicht die wunsch fps erreicht. Wenn die gpu bei 99% ist kann sie ja nicht schneller. Der 5900x ist bei ca. 50%. Werde es später mal ohne rt probieren.
Du kannst nicht hergehen und eine gpu ins gpu limit drücken um daraus die these aufzustellen, in 4k limitiere eh immer die gpu
Das ist hirnrissig.
Es gibt mehr als spidermann und cyberpunk. Deutlich mehr
Far Cry 6:
Dann ist das deine schuld wenn du deine Wunsch fps nicht erreichst weil du die regler nicht bedienen willst.
Daraus pauschal zu behaupten die cpu wird nicht zum problem ist leider dein Bier.
Ich kann da ehrlich gesagt gar nicht viel zu sagen, da ich nur Cockpitspiele zocke, also hauptsächlich Rennsimulationen.
Nutze eine Index ohne Controller, aber mit der 4090 sollte auch eine HP g2 wohl problemlos laufen, die hat nochmal ne deutlich höhere Auflösung.
Mfg
Kiryu
Je nachdem was du spielen willst.
Racing Sims:
- ACC ist gut, allerdings nicht wirklich sauber optimiert.
- Ich spiele aktuell mit der 4090 Automobilista 2 (Hauptgrund für den Kauf der 4090). Das bringt jetzt in vielen Szenarien konstant die 90fps bei Max Settings (außer Regen+Nacht mit vollem Fahrerfeld, übrigens auch CPU limitiert :)) auf der Reverb G2.
Half Life Alyx ist auch richtig gut. Das lief auch schon mit der 3090 in Max Settings auf der Reverb G2 mit 90 fps.
Ansonsten MSFS, den habe ich aber selber noch nicht getestet, lade ihn gerade.
Ich zocke VR games (ASUS TUF 4090) ; (HL Alyx, Star wars squadron etc) mit meiner Quest 2 und alles läuft bisher einwandfrei, darunter auch MSFS2020 (wenn auch stark CPU limitiert mit meinem Ryzen 9 5900X) mit 37fps. Für MSFS muss man zunächst mal viel einstellen und sich langsam hocharbeiten, da dieser Sim wirklich geisteskrank-extrem leistungshungrig ist.
Unterm Strich bin ich im Vergleich zu meiner alten GTX1060 und der nach nur 3 Monaten wieder verkauften 6700XT nun endlich extrem zufrieden. AMD hat immer noch massive Probleme mit ihren Treibern und VR. Ich bleibe bei Team Grün!
Hä??? Wenn ich die Rregler runtersetze würde die FPS doch steigen!
Würdet ihr die Karte zurückschicken ? Man hört dieses brummen des Lüftermotors durch das geschlossene Case.
Es sind alle 3 Lüfter die so brummen. Im Zotac Reddit Forum sind auch schon andere Leute die das selbe Problem haben.
Im Video muss man die Lautstärke hochdrehen, da es ziemlich schwer ist das brummen aufzunehmen.
Was auch auffällt ist das nicht die Lüfter brummen sondern die Motoren. Merkt man daran, das sobald ich die Lüfter stoppe im AB
das das brummen direkt weg ist, obwohl die Lüfter noch nachlaufen.
Interessant. Deine Beschreibung hört sich so ähnlich an wie der Fall bei mir an der FE wo der hintere Lüfter ab 60% höherfrequent "brummt". Scheint bei mir auch Lüfter/Baulich bedingt zu sein
Gedanklich schon, aber es sich trauen bei der teuren Karte xD
Aber okay man hat ja zwei Biose bei der Suprim
Das FE Bios würde mich interessieren das wäre auch mit 600W PT aber dafür mit einem super Idle Verbrauch..
Naja hier hat einer kanpp 600 Watt gezogen bei diese open CL Benchmark mit einer Strix, da ist man dann mit einer suprim zb. im Nachteil:
"Nachteil" bei Benchmarks evtl.
Aber so wirklich mehr FPS bekommt man doch zwischen 450 und 600 Watt eh nicht. Viel mehr Hitze und Lärm, aber keine spürbaren FPS.
UVing ist das neue OCing. ;-)
Also meine 4090 hängt in CP2077 häufig im CPU Limit in 4k RT Psycho, gerade mit RT wird die CPU zum Flaschenhals.
Auch mit der 3090 schon, zwar nicht ganz so häufig aber definitiv vorhanden.
Also meine 3090 hängt bei 1080p mit RT @ Ultra im GPU Limit sprich bei 99% Auslastung. Also RT saugt massiv GPU Leistung, nicht CPU Leistung.
Und man kann damit sogar echtes Geld rausholen statt wie vorher Geld zu verbrennen 😁
Wenn die 3090 in diesen settings weniger fps produziert als die cpu ist das auch klar. Das heißt aber nicht dass die cpu nicht vpn rt beansprucht wird..Das tut sie nämlich ziemlich stark. Reicht aber in deinem Fall dennoch für mehr fps als die 3090 kann. :)
Ähnliche Themen
