[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Mach doch bitte mal ein Video mit dem Handy vom Windows Boot, Speed Way Benchmark starten und bis zum Anzeigen der Score. :) Natürlich alles ohne Pause.
Sofern ich das nicht sehe, gehe ich immer noch von einem klaren exploit von dir aus.
Kannst du gerne von ausgehen, ist halt nicht so ;-)
Ich dagegen finde es spannend wenn du sagst das dein RAM noch auf +1800 läuft aber in keinem 3DMark von dir sieht man diesen hohen RAM Takt.
Wer weis schon wer da alles mit Tricks arbeitet … oder nicht immer ganz bei der Wahrheit bleibt.
Ich würde es begrüßen wenn du künftig solche Anschuldigungen sein lässt.
Danke
Danke
Wo habe ich das denn erwähnt?
Mein höchstes war „nur“ +1700 MHz. Siehe https://www.hardwareluxx.de/communi...handeln-sperre.1323338/page-360#post-29500611
Aussage gegen Aussage. Ich kann ohne Probleme einen run machen mit Handyvideo. Und du willst nicht. :)
Belassen wir es einfach dabei und sehen was Futuremark für ein Statement abgeben wird 👍
Viel Glück weiterhin beim Benchen
und lieferte auch nicht mehr Leistung als ne gut getaktete 3090
Aber immer noch genug Leistung um sich mit + abzuheben. Wenn man die maximale Leistung wollte, kam man nicht um die 3090 ti herum und ich bin mir sicher, dass 60-70% der Leute oder sogar mehr, vor der 4090 die 3090 ti genutzt haben...
Hier haben bestimmt noch einige mehr ein HDMI-4K-120Hz Anzeigegerät.
Mir ist heute morgen aufgefallen, dass ich mit der Einstellung 3840x2160 rechts und links Balken am Desktop habe. Erst mit der Pseudo-Einstellung 4096x2160 die mein LG in den EDID-Daten hat, wird der ganze Desktop gefüllt. Keine Verzerrung, wird nichts abgeschnitten.
Ein weiterer LG-User hat das bestätigt
https://www.hardwareluxx.de/communi...bildschirm-hdmi-2-1-vrr.1246942/post-29503895 (und folgende)
Haben das von euch auch welche mit anderen Anzeigegeräten? Ein Treiber-Bug (was ich vermute)? Ein Feature?
Ich hab die Skalierung im Treiber gestern erst verboten (weil ich ganz gerne mal in 3840x1600 zocke in 21:9 wenn es das Game weiter bringt), wahrscheinlich ist es mir deshalb nicht vorher aufgefallen.
Ich hab die 12900k und spiele auch immer auf max settings 3440x1440 Ultrawide. Neue cpu habe ich eigentlich auch kein bock. Kp ob ich da immer ins limit laufe da kein 4K Monitor. Aber hab mich zu sehr an 21:9 gewöhnt kann nicht mehr zurück zu 16:9😅
Mein 16:9 OLED kann 3840x1600 nativ mit Balken in 21:9 darstellen. Aber ich würde NIE auf die fast 1000 Pixel in der Höhe am Desktop verzichten wollen. NEVER^^ Das bedeutet so unendlich viel mehr Scrollen.
Hast Du am TV Just Scan aktiviert?
Du kannst auch mal mit CRU alle 4096 Auflösungen rauslöschen.
ich kann nachvollziehen, dass mehr Pixel in der Höhe auf dem Desktop nice sind ja, aber 720 (oder 560) sind jetzt nicht fast 1000 :P
bei mir am CX77 gleiches verhalten, am 27GP950-B keine Probleme
CX77 hier, keines dieser Probleme
Bzgl geforce experience vip. Laut nvidia ist es völlig wurscht ob ihr euch angemeldet habt
Ja. OVP schreiben alle welche noch die originale Verpackung haben. Wenn es unbenutzt ist schreibt man eigentlich "noch versiegelt".
Oder man schreibt wenn etwas neu und unbenutzt ist, dass es neu und unbenutzt ist.
Und genau das hat der Verkäufer gemacht:
„Die Grafikkarte ist neu und Unbenutzt“. ;)
Was ist "richtig"? Wenn ich die Skalierung verbiete, dann sollte es doch automatisch richtig sein.
https://www.reddit.com/r/OLED_Gaming/comments/pgmq5x/lg_c1_w_3080_ti_showing_black_bars_on_sides/ hilft das vielleicht?
"This issue has nothing to do with scale size and proportion settings. If you set up to "fill" the screen or no scaling, image gets distorted as the driver thinks the panel is 4096x2160 native and don't actually send 3840x2160 pixels to the TV."
Deine Zahlen sind doch rein aus der Luft gegriffen... Ganz ehrlich wenn Mehrleistung, dann muss sich das schon lohnen. Da gab es in der Vergangenheit schon deutlich bessere Ti Varianten!
Würdet ihr ne Zotac kaufen und dann den Bykski Block dafür nehmen oder lieber warten bis mal eine FE für 2200 auf Ebay kommt, weil es dafür nen EK oder Heatkiller Block gibt ?
Ach wie geil, es wird sogar in der Vorschau der Skalierung "richtig" angezeigt. Achtet mal auf die Balken am Vorschau-Bild.
Ähnliche Themen
