[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Also werden die Karten für Gamer teurer
Nvidia hat wieder was zur Preistreiberei gefunden
Hab ich schon vor ein paar Tagen gesagt, Lederjacke biegt das schon so hin das die Karten knapp sein werden :ROFLMAO:
:poop:
Mmh...da bin ich mal gespannt, ob das wirklich so kommt. Oder ob das Gerücht jetzt mit Absicht gestreut wurde, um hier weiter anzuheizen.
Die US-Regierung arbeitet eigentlich gerade genau an dem Gegenteil in Bezug auf China:
so bin durch mit den Benches von der Gamerock non OC. Gekauft an day 1 bei NBB. Übler Sprung von meiner alten rtx msi 2080 gaming x trio!
Hatte um 15:00 ca. 2 Minuten die Auswahl zwischen der Gigabyte OC, MSI Gaming Trio und der Gamerock non OC.
Gigabyte ist bei mir durch den hässlichen Plastikkühler ausgeschieden. Die MSI weil die Gaming Trio leider nicht mehr das Topmodell ist wie früher :(
Die Gamerock hingegen ist wertig verbaut(Metall) und m.M. sieht die top aus. Besser als die alten Gamerocks. Dazu kommt, dass diese relativ kompakt ist. Dadurch keine Probleme im be quiet Silent base 802.
Zur Performance. Die non-OC hat nur den 3-fach 8-Pin Netzteiladapter dabei. D.h. Powerlimit ist fest auf 450 Watt eingestellt.
Auf dem Core geht bis +176 hier also knapp unter 3ghz
Der Memory aber, alter Falter, +2000 mehr erlaubt der Regler nicht. ECC ist ausgeschaltet und eine Erhöhung des Takts bringt auch stets mehr Performance!
Hier die Benchwerkte:
Port Royal:
https://www.3dmark.com/pr/1812092
Time Spy Extreme:
https://www.3dmark.com/spy/31762948
Gestestet wurde auf einem x470 Brett (also nur PCIE-3) und einem Ryzen 5800x3d
Die Karte bleibt stets unter 70 grad im suboptimalen Silent Base 802. Beim Gaming nicht sehr laut.
Vor allem kein Spulenfiepen!
Leider ist die Karte auch nicht perfekt und eine Art "Brummen" der Lüfter im unteren RPM Bereich hörbar, wenn man die Case Fans runterdreht.
Definitiv aber nicht so extrem wie in dem verlinkten Video. Dreht man die Case Fans etwas auf, unhörtbar. Vielleicht überträgt sich da was aufs Case durch die GPU Stütze, muss Ich mal entfernen und testen.
Werde die Karte definitiv behalten
Komisch ich habe nur Ram + 1000 und meine CPU ist auch schwächer als deine , aber insgesamt besseres Ergebnis.
Ich denke auch das auch wenn weniger Produziert werden die Nachfrage relativ schnell gedeckt sein wird und die Preise dann schnell sinken. Ähnlich der 3090ti die hat in ein paar Monaten 1000euro verloren.
Das war bei der 3090 nur lange nicht der Fall da halt die Nachfrage nie gedeckt werden konnte durch das Mining wo faktisch unendlich viele Karten benötigt wurden da jede weitere Karte mehr Geld gab. Ohne diesen Faktor ist die Nachfrage letztlich endlich auch wenn ggf. Firmen auch mal mehrere für Renderaufgaben kaufen verglichen zu dem unendlichen Bedarf vom Mining ist das immer noch ne kleine Anzahl an Karten.
Ich denke nächstes Jahr wirds die 4090 für 1500-1700euro aufjedenfall geben.
Und? Was sagt das Geschrei der Spulen?
Kann man hören, ist aber nicht so laut wie meine 3080 Strix.
Wenn das Gehäuse zu ist, kann man es nur wahrnehmen wenn man wirklich drauf achtet.
Zeig mal einen screenshot des curve editors!
Wieviel V zieht die GPU während des Benches?
Wie hoch ist der VRAM Takt?
Wie hoch ist das Powerlimit im Afterburner?
Das Powerlimit steht auf 90% bei Afterburner,aber ich habe da nichts eingestellt.
Da die Inflation immer mehr steigt, wird das wohl noch was länger dauern bis die 4090 auf dem Preisniveau angekommen ist.
Mich würde es nicht wundern wenn die EU sich einmischt und hohen Stromverbrauch bei Hardware bestraft.
Und das werden die Hersteller dann an die Endkunden weitergeben.
Dann importiert man halt alles aus USA.
Sobald Amazon.com Karten hat, dürften die jetzt schon billiger sein als Caseking und NBB auch wenn man die 19% draufrechnet.
Dein Wort in Gottes Ohren….
Wenn die EU diese Hardware verbietet, wird diese garnicht durch den Zoll kommen.
Passiert auch mit Handys ohne CE Zeichen.
Selbst wenn, import bei solch teuren Sachen ist immer mit Risiko verbunden. Alleine schon
wegen den Garantieansprüchen.
Ich glaube eher das die Leute die sich heute eine 4090 kaufen, diese ohne Verlust verkaufen können nächstes Jahr weil der
Preis immer mehr ansteigt.
So meine MSI Suprim X geht jetzt zurück, hab genug von dem blöden Drecksding.
Nicht nur das die Karte Spulenfiepen hat wie blöd wie bei vielen anderen hier, die Karte verhindert aktiv das ich meinen Rechner herunterfahren oder in den Energiesparmodus versetzen kann.
Jeder Versuch den Rechner herunterzufahren via Windows resultierte in nem Neustart, egal ob übers Startmenü oder cmd shutdown.
Nur das Drücken der Power Taste am Gehäuse konnte den Rechner ausschalten, aber das ist wie wenn ich jedes mal zum Fernseher laufen muss um ihn abzuschalten anstatt die Fernbedienung zu nutzen.
Hab gestern und heute so ziemlich alles an Troubleshooting versucht was ich im im Netz da finden konnte ohne Erfolg.
Dann dämmerte es mir dass das einzige was ich an Hard/Software geändert habe am Rechner die Graka war (Board Bios / Win Treiber waren schon vor der 4090 auf dem aktuellsten Stand), also heute die 4090 raus, die alte Zotac 3080Ti wieder rein und siehe da es läuft alles wieder ohne Probleme.
Die Ada MSI Karten werde ich ab jetzt meiden und schauen das ich ein 1950€ Model abgreifen kann, bis dahin heißt es zurück zu Ampere.
[/URL]
[/URL]
jau, ich bin auch nicht so der OC Typ, aber ich hab gerade auch einfach mal Ram +1200MHz und Powerlimit und angehoben, dabei komme ich auch auf ein besseres Ergebnis als von der 2000+ Mhz 4090, aber nicht ganz deines. Wenn ich auf 1500 gehe wird das Ergebnis 200 Punkte schlechter, hängt glaube ich aber auch mit dem Powerlimit der Zotac AMP Extreme Airo zusammen.
Ja schade aber manche Karten können paar Macken haben. Hier die Gainward, so schlimm waren die Lüfter gar nicht, würde die aber Montags zurückgeben, mit konstantem Lüfter war die ruhig. Die Gaming OC ist super bis auf das Displayport Problem gestern kurzzeitig. Die will ich unbedingt behalten, ich hoffe das war nur ein Windows/Treiber Aussetzer, aktuell läuft alles.
Ja kam da schon über 500 Watt teilweise.
Je nach dem Peak auch mal 540 Watt .
600 Watt Power Limit ist schon recht optimal für die Karten zu testen .
Schön zu sehen, dass die User bei EKA ihre Karten nicht los werden 😁. Habe auch einige angeschrieben und gemeint, ich nehme diese zum Selbstkostenpreis und ihre Preiserklärungen sind aberwitzig.
der grund ist ganz einfach. nicht jeder kann während der arbeit mal eben das handy auspacken und ne karte schnappen ;)
ja nur haben 90% derer die hier schreiben eine oder sogar mehrere zuhause. Das ist ja der Witz. Man besitzt eine und regt sich trotzdem über andere auf die welche teurer verkaufen.
Was ihr mit eurer lebenszeit so macht. das manche ernsthaft ebay abgrasen oder gar leute anschreiben
was ein trauriges leben
Hat hier jemand eine KFA2 die laut fiept? Ist glaube gar nicht so vertreten hier oder?
Wahr. ein Bürohengst, der den ganzen Tag im Homeoffice seine Runden auf dem Drehstuhl verbringt 😘.
Und was ist daran so schlimm?
Z.b. schreit meine MSI einfach nur pervers aus dem Rechner. Die geht zurück … und nun? Gibts nicht mal so eben um die Ecke neue Karten 😉.
In über 10 Jahren hat das nie geklappt. Ist und bleibt echt ein Mythos ^^.
Wüsste auch nicht, was elektrotechnisch sich bei den Netzteilen untescheiden sollen ... außer vill. die Restwelligkeit.
Tja, was soll ich sagen. SuperFlower Leadex III 850W gegen Seasonic Prime Gold 850W getauscht, weil ich das noch OVP aus einer RMA liegen hatte. Das Spulenfiepen ist nicht weg und noch hörbar, aber es hat sich in seiner Art verändert und ist deutlich leiser.
Bleibt noch der Umstand, dass die Karte scheinbar eine von den schlechteren ist, die nicht über 2680 MHz manchmal auch 2670 MHz boosten mag (OOB ohne Anpassungen, 3 PCIe Kabel dran, sprich 450W die sie in den Momenten nicht zieht). Ich lass es mir durch den Kopf gehen ob sie zurückgeht.
Scheiß Spulen bleiben halt scheiß Spulen. Ein Netzteil liefert auch nur Strom und Spannung.
Kann’s mir technisch nur mit der Restwelligkeit erklären.
Ja, kann sein dass die Restwelligkeit einfach anders ist und durch die andere Frequenz jetzt das Schwingen der Spulen verändert ist. Komisch ist es in jedem Fall.
Gut möglich. Hatte ich viele Jahre immer wieder versucht. Hat nie geklappt. Letztlich geht der Schrott zurück, bis was anständiges vorliegt.
Oder unterschiedliche Testszenarien.
Unterschiedliche Testszenarien kann ich weitgehend ausschließen. Einfach weil ich immer Standardsettings wie TimeSpy, Firestrike oder den Benchmark aus Cyberpunk 2077 genutzt habe. Wärme im Raum wäre natürlich ein Faktor, aber sicher auch nicht 10°C hin oder her.
Ähnliche Themen
Antworten
6K
Aufrufe
392K
