[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
hab das tearing des öfteren trotz gsync. in der regel immer am unteren rand. da hilft dansn nur vsync an
Kann mir jemand sagen welches HDMI Kabel 2.1 geeignet PC -> LG C2
Danke
Hey benutze dieses Kabel seid gut 1 Jahre. Noch keine Aussetzer oder ähnliches gehabt.
Angebot: 8K HDMI 2.1 Kabel 3M, Etseinri Zertifiziert 48Gbps Ultra High Speed HDMI Kabel Unterstützt 8K@60Hz 4K@120Hz, RTX 3080 eARC HDR10 HDCP 2.2 2.3 Dolby Atmos, Kompatibel mit PS5 Xbox TV Monitor Mehr https://amzn.eu/d/5u37eKB
Habe zwei je 3 Meter an meiner asus Strix 3080Ti an meinem LG B1 und denon verstärker angeschlossen.
Jetzt nur noch 1 weil die Suprim X nur 1HDMI hat.
musste neu installiern, das hats gelöst
Weil es tatsächlich so ist ;) bin da nämlich extrem empfindlich und merke sofort wenn es nicht passt.
Meint ihr kommende Woche kommt nochmal ein Frachter mit 90ern? Erstaunlich wie fix die immernoch weg gehen solange es keine 400+ Euro Aufpreis sind
Würde mit meiner FE passen
~+140 GPU waren in Games stable und die +1500 Mem auch wobei ich die max. auf +1000 laufen lassen.
3 GHz packt die damit auch. 3100Ghz nicht. Ich vermute aber dass das oft an den Benchmarks abhängt. DEr eine läuft mit 3100 Stable der andere kack bei 2900 ab.
Außerdem müsste man vermutlich mal eher den finalen Takt betrachten. Der Offset variiert ja von Model zu Model.
Wenn einer im Silent Bios ist wo ggf der Speichertakt auf 10.000 MHz runtergetaktet ist, kann er auch +2000 MHz Offset geben.
Also meine FE hatte bisher so um die 3 Ghz GPU Takt (variiert aber je nach Spiel. Mal rennt sie auf 2970MHz und bei nem anderen Titel auf 2860 MHz) geschafft und mit den +1500 Mhz auf Mem waren es 12000 Mhz Speichertakt^^.
Ich glaube, der Speichertakt gilt für alle gleich. Ich gebe +2000MHz und erhalte somit 12500MHz. Basis ist für alle wohl 10500MHz.
Beim GPU Takt hast du recht, da sollte man vom finalen Takt reden. Da ich aber nicht mehr als +100 geben can, bzw die FE eine niedrigen Basistakt hat, ist die GPU einfach eine oc-Krücke. Da hilft auch ne Wakü nicht viel (werde trotzdem eine draufballern). Die +2000MHz auf den VRAM Takt müssen das eben dann kompensieren.
Habe nun den oc scanner machen lassen. Der liefert ganz brauchebare Ergbnisse, jedenfalls so, dass ich davon ausgehen can, dass die Shice stabil bleibt. Werde dann mal damit etwas benchmarken und schauen wie +2000MHz auf VRAM kompensieren.
Schön zu sehen, dass die User bei EKA ihre Karten nicht los werden 😁. Habe auch einige angeschrieben und gemeint, ich nehme diese zum Selbstkostenpreis und ihre Preiserklärungen sind aberwitzig.
Wenn man sonst nichts anderes zu tun hat...
live
Ich hab kein Tearing mit Gsync -VRR auf meinem 77C1 LG Oled.
V Sync immer aus Limit 117 FPS.
Dann schreib doch bitte das du es nicht merkst anstatt zu erzählen du hast kein tearing. Umso höher die Frames desto weniger merkt man das teart aber es ist nun mal Fakt das es ohne Vsync tearing gibt, ausser Fastsync ist an. Nicht böse gemeint
Ich habe trotzdem immer vsync Off. Merke da kein tearing oder frame pacing problem…
Viel Lesestoff auf den folgenden Seiten in dem Artikel…aber das wichtigste ist bei GSync ON die Frame Rate Cap auf -2/3fps vom Monitor. Vsync in Cyberpunk zb ist total laggy…
Vsync im Treiber aktivieren und im Spiel deaktivieren, dann ist auch in Cyberpunk nichts laggy und alles schön glatt.
Also ich kann auf meinem CX nicht ohne Vsync aus spielen. Das ist so unruhig und doch eine ganze Menge Tearing, nichts was nur selten vorkommt. Vysnc + Gsync muss beides an sein. Dann lieber ein paar ms Latenz
Nichts, aber die Frage ist ob Sie funktionieren.
Viele Kabel die ich damals probiert habe, haben nicht funktioniert.
der Mann hat schon recht, habe hier einen LG Beamer mit 15m HDMI Kabel angeschlossen(quer durch den Raum halt). Musste 5 verschiedene Glasfaser HDMI Kabel kaufen die angeblich alle HDMI 2.0 waren aber nur das für 80 € hat dann ohne Sound/Bildaussetzer funtioniert. Marke Atzebe war das btw.
Und wenn du Pech hast bekommst gar keine mehr, weil China versucht Taiwan heim ins Reich zu holen, es Weihnachtet schon sehr, lecker Spekulatius. :LOL:
Der typ versucht doch eh die ganze zeit nur den 4090 besitzern den kauf madig zu machen, weil er von seinen finanziellen möglichkeiten auf andere schließt und jahre warten dann immer besser ist als zum launch zu kaufen. :bigok:
Das die karte die alte gen komplett versägt will er nicht mal wahrhaben, siehe nachbar thread. Am besten einfach ignorieren
Mein persönlicher Überraschungshit des letzten Jahres "The Ascent" hat einen DLC bekommen (Cyber Heist) und diesen konnte ich am Wochenende mit der neuen Grafikkarte und Monitor abschließen.
Durch Ultra Details, Raytracing Schatten und Reflexionen doch recht fordernd in 4k/120fps. Mit 75% Powertarget und DLSS Quality konnten die Ziel FPS aber sehr gut gehalten werden. Optisch, aber auch vom Gameplay ein echter Cyberpunk Traum und für mich ganz großes Kino da hier mehrere Sachen zusammen kommen.
Anbei ein paar Schnappschüsse: https://imgur.com/a/M63IShp Auf dem letzten Bild sind auch ein paar Performance stats eingeblendet.
Energiesparoptionen auf "Ausbalanciert" gibt Ruckler in speed way.
Energiesoptionen auf "Höchstleistung", keine Probleme moar.
Habt ihr das auch?
Es gibt bei Gainward/Palit ein neues Bios für die RTX 4090. Die Datei ist bei allen Palit/Gainward Grafikkarten identisch.
VBIOS RELEASE NOTE
OBE builds with UEFI 70009 image, resolve no display issue before the driver loading with some mobo
when booting the system.
Hat Nvidia eigentlich jemals nen BIOS für seine Grakas rausgeballert? Habe da irgendwie nichts in Erinnerung? Oo
Ähnliche Themen
Antworten
6K
Aufrufe
392K
