[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Du willst eine Aufzählung? Gerne doch:
  • Ein neuer 12VHPWR-Anschluss (auch bekannt als 12+4-Pin) für PCIe-Karten, der bis zu 600 W liefern kann. Der 12VHPWR-Anschluss sollte mit einem Etikett versehen sein, das die maximale Leistung angibt, die er liefern kann.
  • Alle Netzteile mit einer maximalen Leistung von mehr als 450 W müssen einen 12VHPWR-Anschluss haben. Ansonsten können alle 6-Pin und 6+2-Pin-Anschlüsse weiter genutzt werden
  • Das Netzteil kommuniziert mit der Grafikkarte über Seitenbandsignaledes 12VHPWR seine Leistungsfähigkeiten, so dass letztere ihre Leistungsgrenze entsprechend einstellen kann.
  • Netzteile sollten in der Lage sein, sich 175.200 Mal pro Lebensjahr ein- und auszuschalten, ohne kaputt zu gehen! (Das ist Wahnsinn und wohl auch teuer)
  • Bei der Effizienz im Niedriglastbereich gibt es einige Änderungen. Mehr als 60 % Effizienz sind für 10 W oder 2 % der maximalen Nennleistung erforderlich und mehr als 70 % sind jetzt nur noch eine Empfehlung statt einer Anforderung.
  • Erhöhte Toleranz für hohe Leistungsspitzen, die bis zu 200 % der Nennleistung des Netzteils für 100 μs mit Intels benutzerdefiniertem Tastverhältnis erreichen.
  • Erhöhte Anstiegsgeschwindigkeiten für transiente Lasten (2,5 – 5x höher für die +12V-Schiene. Sie bleiben für die anderen Schienen gleich).
  • Zum ersten Mal kann die 12-V-Schiene bis zu 12,2 V betragen, um geringere Spannungsabfälle bei transienten Lasten zu ermöglichen (Ich schrieb ja bereits ausführlich darüber).
  • Breitere Grenzen für die Lastregulierung der +12V-Schiene (+5 bis -8% bei den PCIe-Anschlüssen und +5 bis -7% bei den anderen Anschlüssen).
  • Es gibt einige Änderungen bei der Geschwindigkeit des Einschaltsignals, um eine schnellere Reaktion und ein schnelleres Aufwachen des Systems zu ermöglichen, auch wenn die Schienen nicht auf Nullpegel, sondern irgendwo dazwischen liegen.
  • Effizienz- und Designanforderungen für Alternative Low Power Modes (ALPM), die früher als Alternative Sleep Modes bezeichnet wurden. Eine davon setzt der Effizienz der Standby-Schiene Grenzen!
  • Die Etiketten auf den Netzteilen sollten unter anderem T1- und T3-Timings enthalten. Die Rolle dieser Timing-Signale wurde aufgewertet.
  • Die wichtigste Neuerung ist schließlich die Hinzufügung eines neuen Zertifizierungsstandards, Cybenetics (Aris‘ Firma), neben 80 Plus, der im Abschnitt Referenzen zu finden ist.
Quelle: https://www.igorslab.de/atx-3-0-im-ueberblick-seifenblase-oder-revolution-was-sich-wirklich-aendert/
Ja Tolle Liste, auch gelesen? Und trotzdem der Meinung dein neues Netzteil muss unbedingt 3.0 sein ... na dann mach ... kauf halt irgend eines bei dem 3.0 drauf steht ;-)
Dir ist schon bewusst das vieles davon auch bereits gute 2.4 Netzteil übertreffen ...
Vollzitat seriously? Why?
Na klar ist auch bei ATX 3.0 nicht alles Gold was glänzt, aber hey ich bin hier nicht der Salesman der Netzteil Hersteller und ich will dich gar nicht großartig überzeugen.
Jedem das seine und mir das meiste wie ich immer zu sagen pflege, oder anders ausgedrückt: Kauf doch was du willst, ich halte es ebenso. 🙏
PS:
Vieles? Hm, Nope 👎
Die meisten Sachen sind nagelneu und gab es so eben noch nicht.
Werde ich tun, sobald es mehr als nur ATX 3.0 Netzteile von Thermaltake gibt wie aktuell.
Dann noch Testberichte abwarten und gemütlich das beste aussuchen, wie immer halt.
Na klar ist auch bei ATX 3.0 nicht alles Gold was glänzt, aber hey ich bin hier nicht der Salesman der Netzteil Hersteller und ich will dich gar nicht überzeugen.
Ps:
Vieles? Hm, Nope 👎
Die meisten Sachen sind nagelneu.
Was ist Neu ? der 600Watt 12VHPWR ?
Netzteile sollten in der Lage sein, sich 175.200 Mal pro Lebensjahr ein- und auszuschalten?
Erhöhte Toleranz für hohe Leistungsspitzen, die bis zu 200 % der Nennleistung des Netzteils für 100 μs?
Das ist vielleicht neu das der Standard das vorgibt aber doch nicht das es Netzteile gibt die das schon können.
Aber wie du ja selbst gesagt hast ... Jedem das seine.
Na wenn alles schon vorhanden ist, cool. Glaube ich zwar nicht ansatzweise, aber hey, ich will dir deine Illusionen gar nicht rauben.
Schönen Abend dir noch 🙏
Passt auf die KFA denn der Referenz Block? Kann mich nicht entsinnen, eine Bestätigung gelesen zu haben. Wenn nicht, kommt für sowas exotisches wohl kein Block oder wenn, dann sehr spät.
Die KFA hat wohl das Referenzdesign.
Auf Nachfrage bei Byksi passt der Referenzblock.
Grüße
Der super Stecker von be quiet passt doch auch beim Dark Power Pro 11 850 Watt, das steht mal nicht auf der Kompatibilitätsliste...ich hatte das irgendwo gelesen das es auch geht. Weiß das jemand zufällig. Beste Grüße
Hab vorhin noch ne 4090 Asus Tuf bei MM schnappen können, ich hoffe das GPUs bei der 19% Aktion morgen nicht ausgeschlossen sind, dann wäre das teil echt günstiger als die FE.
Habe eben mal meine beiden beQuiet Kabel von Alternate angeschaut und die sehen in Ordnung aus. Da ist nichts wackelig und die Kabel sind so fest in dem Stecker verbaut/eingeklemmt, dass ich gar nicht weiss, wie die rausrutschen könnten, selbst, wenn man die biegen sollte.
Wie hast du das denn geschafft ? Oo
Wundert mich eigentlich auch. Hab den ganzen Tag versucht bei MM ne 4090 zu kaufen und hatte immer nen Fehler. Um 19:05 kam der Alert für die 3090 TUF in Telegram. Hab die aufm Handy in den Warenkorb gelegt, konnte aber nicht kaufen. Paar Minuten später am PC eingeloggt und da wär die Karte im Warenkorb auf grün und ich konnte es im zweiten Anlauf kaufen.
So, heute wieder im Idle ein Flackern und "Hardware-Fehler"-Eintrag im Zuverlässigkeitsverlauf. Habe nun mal das BIOS der Gainward 4090 geupdated, mal schauen, ob es das bringt.
Bevor ich das gefunden habe ist Weihnachten vorbei.
Hier in thread hatte einer das Problem das er seinen Rechner nicht mehr runter fahren konnte. Kann sich derjenige mal bei mir melden bitte.
Kumpel von mir hat seid gestern eine Asus tuf non-OC. Und er hat das gleiche Perücken.
Er bekommt den Rechner nicht herunter gefahren, er rebootet einfach. Bitte um Hilfe
VBios Update schon durchgeführt?
Ich hatte vor paar Tagen das gleiche Problem mit einer 3080 TUF, weiß allerdings nicht mehr wie ich das wegbekommen habe.
@Aupia Hast du vor dem Einbau DDU durchlaufen lassen?
Hm. Mein Windows 10 war mal ein Windows Vista, und hat etliche Boards und Grafikkarten hinter sich (zuletzt eine 3090), Und es läuft alles super, von solchen Tools halte ich nicht so viel. Nun ist halt das Problem mit dem Flackern da, aber das haben ja andere User auch. Aber ja, ist halt der erste Treiber, daran kann es ja auch liegen.
DDU ist seriös. das ist kein bumstool wie ccleaner und co :)
nvidia soll den herstellern 90grad adapter liefern bzw die kohle dafür abdrücken und die hersteller geben an jeden käufer so ein ding raus. (kompatibel zum modell)
das wäre mein idee
Nachricht gelöscht
Das finde ich nicht, weil nur die Oberfläche gemessen wurde.
Wie heiß ist es darunter?
An der Unter statt Oberseite des Steckers ist es schonmal 10° heißer laut meinem Infrarot-Thermometer. Wie heiß es innerhalb der Verbindung ist, würde mich brennend (haha) interessieren.
das wäre mein idee
Warum soll Nvidia was machen der 12+4 Pin Stecker ist doch PCI 5.0 und kein Nvidia eigen Ding und die Hersteller müssen doch keine Adapter bei legen das machen sie eigenständig und freiwillig
weil nvidia die vorgabe getroffen hat dass der adapter zu verwenden ist. sonst hätte asus ja auch sagen können, ne is kacke lass mal bei 3x8 pin bleiben
Betreibt wer seine 4090 in einem Corsair 7000d und kann was zum Seitenabstand sagen? Möchte mein geliebtes Evolv X tauschen, da ich mehr Luftdurchzug brauche und auch etwas mehr Platz allgemein.
Bei mir ist zwar keine 4090 verbaut, sondern eine 3090 aber genug Platz wirst Du haben und der Airflow stimmt auch.
Konnte ohne Platzprobleme eine 420er AiO für die CPU und eine 360er AiO für die GPU einbauen.
Ich hatte mir das 7000X zusammen mit den Front und Top Aiflow Panels bestellt.
Sollte der Vollausbau der 4090 noch kommen, wird sie dort ihren Arbeitsplatz beziehen.
Ähnliche Themen
Antworten
6K
Aufrufe
381K
