[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
ATX 3.0 brauchst du nicht zwingend für das 16-Pin PCIe 5.0 (12+4-Pin 12VHPWR) Kabel
Nebenbei das Kabel hat auch eigentlich mit ATX 3.0 nichts zu tun, sondern lediglich mit dem PCIe 5.0 Standard
Na komm, wer jetzt ein neues Netzteil kauft kann gleich Zukunftssicher in die neueste Technologie und damit ATX 3.0 investieren.
Ich würde jetzt jedenfalls kein olles 2.4 mehr haben wollen quasi am völligen Ende seines Zyklus….
Entweder nun das Thermaltake nehmen oder halt wie ich die Zeit mit dem Alten NT + UV überbrücken und warten das Seasonic, Corsair und Co ihren neusten shice endlich der Öffentlichkeit präsentieren 😏
@Catahecassa
Ich habe ja auch eine Figur im Gehäuse (R2D2), aber direkt auf der GPU?? Schmilzt das Teil nicht?
Die werden bestimmt auch in geringen Stückzahlen verfügbar sein. Und dann gehen die Scalper auch noch auf diese los ^^
Hab heute meine 4090 Phantom von Alternate bekommen. Das Lüftersägen oder ich würde es eher als Summen bezeichnen, ist bei mir nur minimal wahrnehmbar bei geöffnetem Gehäuse. Wird dann vom Spulenfiepen übertönt.
Beim Time Spy bei doppelten Frames wie mit der 3080 ist das Fiepen aber auch nicht schlimmer wie mit der 3080 Suprim X. Bin also von den Geräuschen zufrieden mit der Karte könnte viel schlimmer sein.
Ein Problem hab ich allerdings. Bei jedem Neustart friert der PC ein kurz bevor er in den Anmeldescreen von Windows umschalten soll. Der drehende Kreisel bleibt dann stehen und es tut sich nix mehr. Mach ich dann den PC mit dem Gehäuseschalter aus und starte wieder neu funktioniert es wieder. Beim nächsten Neustart dann das gleiche. Im Bios hab ich mal die Einstellungen zurückgesetzt und auch Windows Fast Boot ausgeschaltet. Hat alles nix gebracht. Eventuell hat noch wer nen Tip?
Danke!
Darf ich fragen wann du bestellt hast und ob du express Lieferung dazu gebucht hast ?
Ich würde auch nur ein ATX 3.0 Netzteil kaufen... alles andere wäre doch dumm :fresse:
Zur Not undervolten auf 0,875v und warten bis entsprechende NTs verfügbar sind.
Das Ganze hat doch nichts mit ATX 3.0/den aktuellen PSUs zu tun, sondern mit den mangelhaft verarbeiteten Kabeln teilweise (siehe be quiet).
dein beitrag grätscht da so in die adapterthematik rein und dann dein 2. satz impliziert dass du glaubst dass das undervolten das durchbrennen vermeidet ;)
Habe auch eine Phantom GS bei Alternate bestellt. Vielen dank nochmal an @ralle_h :bigok:
Bestellt wurde gestern, bezahlt mit Paypal Express Checkout, aber Standard Versand. Karte kommt laut DHL Tracking am Donnerstag.
der seasonic winkel ist aber auch ein bischen ungünstig , dann ist man damit gezwungen das kabel in einer richtung zu legen je nach hersteller über die karte oder unter die karte , je wie das gegenüber an der karte gedreht ist
Hat jemand schon die Karte in ein Dark Base 700 bekommen? Bin noch im Urlaub 🙈
Und zweite Frage, ich wollte meinen PC sowie so umbauen, ein Asus ROG Strix x570 E-Gaming WiFi II kommt rein, den Ryzen 3800x könnte mein Sohn bekommen, welche CPU wäre denn für das Board und die 4090 ok? Also nur zum daddeln und keine Benchmarkhits.
Heute kam endlich das be quiet! Kabel und es machte auf mich einen sauber verarbeiteten Eindruck, scheint ja sehr wichtig zu sein.
Ich habe es in meinen Augen in einem so hoffe ich gesunden Rahmen zurechtgebogen, ein Kompromiss aus Vernunft und Optik.
Weiterhin habe ich weder Kosten, noch Mühen gescheut und aus Sicherheitsgründen eine Elektrikerin beauftragt, die stets alle Werte überwacht und zur Not durch Schmelzung Komplikationen anzeigt.🧑‍🔧
Thja, gutes Beispiel wie man es nicht machen soll :fresse2:
Ich habe den Bequiet Adapter zwar noch nicht in der Hand gehabt aber die Biegung bei dir fängt direkt am Stecker an. Genau das gilt es zu vermeiden. Die Adern aus dem Stecker sollen über eine gewisse Strecke, 3,5cm wird von Cablemod genannt, gerade herauskommen bevor der eigentliche Biegeradius beginnt.
Du provozierst vermutlich dieses Szenario jetzt:
Habe heute zwei 4090 über Amazon bestellen können (direkt Amazon Deutschland) eine TUF und eine Strix.
Strix ist schon auf dem weg.
Guckt eigentlich von euch ab und an auch jemand bei Amazon?
Bei Mindfactory habe ich heute nochmal ne Suprim X bestellt.
Habe heute auch den erste Rückläufer als angebliche Neuware erhalten vom MM war ne TUF OC.
Kaum Spulenfiepen Taktet mit OC bis 3160MHz im Speedway ... VRAM war aber bei 1450 Schluss
VF-Curve 2840 bei 1050mV
Bislang hatten alle Karten Spulenfiepen je nach Last und FPS
Am schlimmsten waren jedoch bislang leider fast immer die Strix und MSI ... hörten sich nicht gesund an (Je nach FPS und Last!!)
Eigentlich suche ich genau davon eine "Gute".
Amazon ist doch viel zu teuer!
Muss bis Weihnachten fertig sein, dann bekommt der Kleine die alten Teile, 1080Amp, Asus Crosshair II Hero x470 und die cpu...
bei normalen kabel die grade rauskommen kanst ja über oder unter gehen und da ist auch egal ob es extra pins oder klemmen gibt , bei einem winkel ist man eben in eine richtung gezwungen und da die karten hersteller sich scheinbar nicht absprechen geht der winkel so wie er auf dem bild bei seasonic ist eben je nach karte nach oben oder unten weg , cabelmod und co werden sich sicher die adapter mit gold aufwiedern lasen cent artikel in der herstellung .... hoffe die wollen nicht mehr als 20-30 dollar und das ist schon viel aber vieleicht überraschen sie ja und machen ein doppelpack wo beide varianten drinne sind
Was für ein Taster ist das neben dem Stromstecker? BIOS Umschalter für Silent- und Gamingmodus?
Einfach nur geil, bei der 3090 waren es damals die Wärmepads und jetzt isses das Kabel und das für nur lumpige 2k :lol:
Ähnliche Themen
