[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Bei so einem Durchschmoren kann der Grafikkarte oder dem Netzteil an sich nichts passieren.
ja, das sollte man vielleicht mal ein paar anderen erklären. Vor allem denen die keine Chance auslassen zu erwähnen das dieser Adapter Menschen tötet und Existenzen ausrottet. Denn es gab schon ein zwei hier die behaupten das Häuser abbrennen und darin Menschen sterben. Auch wenn hoffentlich alle Forenteilnehmer wissen das sowas komplett übertrieben ist.
Naja wenn der Stecker an der Karte mit an schmort ist die Karte aber auch hin, also im schlimmsten Falle aber gut man soll positiv denken.
Und was machste dann? Vermutlich das gleiche was du mit jeder anderen defekte Karte auch machst. Oder?
Ist das die KFA, Spulenfiepen?
Verhält sich ruhig bisher, Spulen sind leiser als bei meiner 3090 Suprim aber fang jetzt erst an zu testen
Als Katzenbesitzer hab ich Angst bei solchen Bildern...
Plexiglashaube drüber 😁
Bzgl dem Bild
Fand das nur optisch sehr ähnlich, bisher ist die KFA2 sehr leise muss aber noch testen
Mein BQ Kabel bestellt bei CU hat Verspätung muss erstmal mit dem Adapter leben und möchte den nicht knicken, kann daher auch nur 3 Kabel anschließen
Eine Plexiglashaube würde die eine davon nicht abhalten, ich nenne sie liebevoll "der Zerstörer". Die macht auch richtig schwere Schranktüren auf wenns sein soll. Insofern: richtiges Case geschlossen oder es überlebt nicht.
Dir aber viel Spaß mit der KFA. Ist glaube ich garnet so verkehrt das Ding. Ein User hat zwar schon über einen mäßigen Lüfter berichtet, aber ich weiß nicht ob das die Regel ist.
Die Strix ist echt ekelahft geworden... Also dieses rot-blau Muster hätte auch locker eine schöne RGB Beleuchtung werden können aber nein. Deshalb griff ich lieber zur Gigabyte Gaming OC, die von der Größe gleich daher kommt und wenigstens schöne RGB Beleuchtung besitzt die man individuell einstellen kann und die ist schön schlicht schwarz.
An sich wäre es ja vollkommen egal wie die Karten so vorne aussehen, ist es dir wahrscheinlich auch aber mir ist das extrem wichtig, weil sie vor meiner Nase vertikal durch das Glasgehäuse zu sehen ist und unter dem an der Wand hängenden LG OLED steht.
Wäre aber mal gespannt wann und ob so eine Asus Rog Strix RTX 4090 LC kommen wird 🤯🤩
Hui
Das ist ja mal ein toller Kasten ! Hast du den Selber gebaut ? Schaut echt gut aus
Unabhängig von der Thematik, dass bei den Varianten die Anzahl der Pads im Inneren des Steckers wichtig sind, wären hier mehr Daten die zerstörungsfrei erhoben werden können interessant. Kommt schon, noch ein paar Besitzer einer GeForce RTX 4090 hier, die noch nicht teilgenommen haben?
Werde nicht daran teilnehmen. Das Thema Stecker ist für mich abgeschlossen nach meinem bestandenen Stecker-Test. Keine Probleme damit.
4090 FE DROP... in Frankreich, Spanien und Italien...
Es ist ne wichtige News, da Nvidia trotz Adaptergate immernoch FEs raushaut.
Hui
Ich danke dir!
Ja, hatte vorher ein Thermaltake Core V21 und es sollte etwas edleres werden aber das Prinzip eines liegenden Mainboards und der stehenden GPU beibehalten und so wurde nach langem Überlegen und nach vielem Gesuche das Raijintek Paean Benchtable dafür "missbraucht" in liegender Position und mit einem zusätzlichen Seitenteil, das eigentlich für weitere AiOs gedacht ist, ist jetzt ganz vorne als Glasabdeckung, die ich jederzeit sehr einfach abnehmen kann und ins Gehäuse komme :)
Seit Minuten verfügbar, wäre schön wenns in DE auch mal so leicht wäre
Grüße in die Runde. Ich habe heute eine Gainward Phantom geordert und da ich sowieso auch ein neues Netzteil wollte direkt das Silverstone ATX 3.0 dazu bestellt. Hab da in der Bucht noch etliche Punkte gehabt die verfallen wären.
Kommt wohl beides schon am Feitag. Bin echt gespannt :)
uh, mein EKWB Vector2 Block ist schon in DE und wird vermutlich Mi. / Do. zugestellt,
heisst am Wochenende wird die 4090 FE auf Wakü umgebaut :banana:
Bist du dann der zweite mit einem Wasserblock? Oder haben jetzt schon mehrere einen? Bin mal gespannt wie er sich verhält im Vergleich zu ALC.
Edit: hier stand ein Rechenfehler ! ^^
An die 02:00Uhr Nachts-Weckersteller,
schaut aktuell so aus, als ob CableMod doch erst Dienstag 06:00Uhr (unsere Zeit) den Sale öffnet.
Aber sollte man heute wahrscheinlich noch paar Mal aktualisieren, wer weiß wie oft sich das noch verschiebt...
wie? 16 Uhr + 10h ist doch 2 Uhr Nachts?
Toll. Jetzt hab ich den Wecker natürlich schon deaktiviert
Ich kann nur so viel sagen einmal bequiet immer bequiet. Das dark Power 12 pro 1500w tut seine Dienste, das Kabel ist hochwertig, und das NT wird auch noch für die next 5090 reichen. Dann eventuell zur 6090 neues NT 😁😁😁
LDLC hat immernoch 4090FEs in Stock...nach 1 Stunde:20min...
Warum kriegen wir nur so wenige?
Wenn ihr eure 4090 mal so richtig knechten wollt :banana:
Ohne DLSS natürlich ;)
Can it run Doom RTX ... Yes die 4090 kann das sogar ziemlich gut
Installation ist ganz einfach, falls ihr Doom habt, einfach die doom.wad in den entpackten Ordner einfügen und starten
nochmals für die jüngeren
iddqd und idkfa im Spiel eingeben --> frohes Testen
Könntest du DLSS auswählen? Bei mir ist das ausgegraut.
Ähnliche Themen
