[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Naja Chip lotterie auch nur wenn man es sich einredet oder ,immerhin bekommt man die hz zahlen Dienstag stehen und bis jetzt sogar immer mehr auf Stock .....alles andere ist Wunschdenken
Ich würde mir ja gerne eine ne Strix kaufen .... Werde wochentlich einmal Asus nerven , bis jetzt wirds immer weggekauft und versucht auf eBay Kleinanzeigen zu verticken ...3200 die sollen ersticken daran
Die Strix ist echt ekelahft geworden... Also dieses rot-blau Muster hätte auch locker eine schöne RGB Beleuchtung werden können aber nein. Deshalb griff ich lieber zur Gigabyte Gaming OC, die von der Größe gleich daher kommt und wenigstens schöne RGB Beleuchtung besitzt die man individuell einstellen kann und die ist schön schlicht schwarz.
An sich wäre es ja vollkommen egal wie die Karten so vorne aussehen, ist es dir wahrscheinlich auch aber mir ist das extrem wichtig, weil sie vor meiner Nase vertikal durch das Glasgehäuse zu sehen ist und unter dem an der Wand hängenden LG OLED steht.
Wäre aber mal gespannt wann und ob so eine Asus Rog Strix RTX 4090 LC kommen wird 🤯🤩
Super, das heisst die kabeln die seasonic gratis an die kunden jetzt schickt sollte man mit max 450 watt betreiben?
Hauptsache wäre in dem Fall, dass man auch eine 600 Watt fähige Version damit uneingeschränkt betreiben darf.
In meinem Fall eine Gigabyte Gaming OC, die ich aber sowieso mit so wenig Saft wie möglich nutzen würde.
Habe jedenfalls auch eins bei denen bestellt und es soll irgendwann im November kommen.
@andi0138
Nein, dass heißt das Kabel meldet der Grafikkarte immer 600W, auch wenn das Netzteil maximal 450W liefert…
Das ist ein ganz anderes Thema..
Wenn Seasonic nicht geschlampt hat und das NT in Ordnung ist, sollte im worst case die OCP getriggert werden, wenn überhaupt.
Ich meinte den Lüfter der gpu ;)
Achso :d
Habs grad mal ausprobiert, funktionert im Idle, nach dem Beenden eines Spieles aber noch nicht, mal schauen was ich da mit den Lüfterkurven des Afterbrurners noch rausholen kann.
Ich fand es schlimm bei der Gigabyte Master das die nach Zerofan also ab 65C+ mit 1450RPM aufwacht um 1-2 Minuten später wie auszugehen um wieder mit knapp 1500RPM an zu laufen.
Das soll bei der Suprim ja bei 900 RPM liegen und bei der Strix bei 1000RPM .
Was von der Geräuschkulisse Welten sind die 500-600RPM weniger.
Die Gigabyte Master ging für mich damit gar nicht klar von der Lautstärke!
Ach so und ich sitze knapp 3m weg vom geschlossenen Gehäuse und meine 16 Lüfter von meiner Wakü mit 375 RPM höre ich nicht!
Diese zickige MSI Karte geht mir total auf den Senkel.
Es war nicht der Chipsatztreiber, aber mittlerweile weiß ich zu 100% woran es liegt - der Temperatur der GPU.
Als ich dachte der Chipsatztreiber wars war die GPU schlicht nicht warm genug um Probleme zu machen.
Jedenfalls: Die Karte sitzt ist im Idle immer so im Bereich 50-60°C, da ich im Idle keine Lüfter laufen habe, außer den 2 CPU-Lüftern @ 5V.
Die Lüfter der Karte selbst fangen ja erst bei 61°C an sich zu drehen. Wenn ich also in diesem Temperaturbereich versuche den Rechner herunterzufahren, egal ob ich davor ein Spiel gespielt habe oder 1h gesurft habe kommt stattdessen ein Neustart. Sieht dann so aus:
Wenn ich die Karte aber vor dem Herunterfahren runterkühle, wieder egal ob ich grade gespielt hatte oder gesurft, dann fährt der Rechner auch wirkich runter.
Warum genau die Suprim in meinem Rechner so rumzickt weiß ich nicht. In dem exakt selben Rechner Setup hatte ich ne EVGA 1080Ti, ne MSI 3080 Gaming X Trio, Zotac 3080Ti Trinity und ein paar Stunden ne Gainward 4090 Phantom am laufen, auch imer so 50-60°C Idle und keine dieser Karten hatte damit auch nur das geringste Problem.
Hatte jemand von euch auch schon mal so ein Problem und wenn ja, wie habt ihr es gelöst?
Keine Probleme mit der Suprim X im Gegenteil.
Ja sowas ist echt lächerlich und dumm gelöst. Wieso fängt die nicht schon eher und leise an zu kühlen... Sowas verstehe ich auch nicht!
Wäre nur dann wünschenswert, wenn man individuell nach Spiel die RPM anpassen kann wie bei AMD Adrenalin, was ich bis dato noch nutze. Echt gut gelöst.
Der Kühler ist so Potent da hätten 900RPM gereicht zum anlaufen und die wären auch nicht zu hören gewesen!
Der beiliegende Adapter 2x8-Pin auf 12+4-Pin kann bestimmt 600W, aber das Netzteil ist nur für 450W, also maximal 225W pro 8-Pin (am Netzteil) ausgelegt.
Das große 1600W Netzteil hat dafür 11x8-Pin Anschlüsse...Seasonic hätte demnach einen 3x8-Pin oder 4x8-Pin auf 12+4-Pin Kabel beilegen müssen.
Deswegen hat das Netzteil auch keine 1x8-Pin auf 2x8-Pin Daisychain PCI-E Kabel!!!
Genau an dem Daisychain Kabel erkennt man auch, wieviel ein Netzteil pro Kabel liefern kann. Schließlich ist so ein Kabel auf biszu 300W ausgelegt.
Tl;dr Hat nichts mit einem Adapter zu tun, sondern mit dem Output des Netzteils.
Der Adapter zieht mehr Strom als das Netzteil kann, weil der falsche Sensorpin geerdet ist.
Die GPU brennt nicht ab, sondern das Netzteil schaltet ab >_>
Lösung:
Man schneidet beim Adapter das richtige Sensor-Kabel (Sense0) durch und man hat nur noch 450W statt 600W...
Trotz Single Rail geschaltet?
Theoretisch soll das bestellen des Adapter ab heute 0 Uhr losgehen....
Ich ahne schlimmes
@CasekingMike
Werdet ihr den Adapter bei euch aufnehmen irgendwann?
@Ronin513
Habe ein Thermaltake ToughPower GF3 1650W konnte leider nicht viel testen da mein 4090 Probleme macht.
Zur Lautstärke kann ich nur sagen ist last abhängig je mehr last desto lauter der Lüfter im offen Test auf bau ist doch schon recht laut in einem Gehäuse wirds nicht lauter sein als die gpu selber.
Bin aber von der Verarbeitung sehr zufrieden nur die Kabel sind halt nicht die schönsten.
Wenn du was sehr leise suchst kann ich es dir nicht empfehlen.
Wie kann ein 1600w nt bei massiver unterforderung hörbar werden 😄
Good Job tt
Adapter sind generell mist. Einer der Gründe warum ich mir das ATX 3.0 Netzteil geordert habe.
Wieso denn das? Ich betreibe meine 4090 sogar mit einem 750W Netzteil. Ich habe "nur" das 850W ATX 3.0 genommen. Habe sogar überlegt das Silverstone zu nehmen, weil ich das garantiert zum Wochenende habe. Aber dann kam ein Funke Vernunft durch :d
Hatte vor nen 13900K und etwas Puffer für die nächsten Jahre :)
Jep! Bei den Karten ist aber auch so ein performance und silent Switch dabei. Ob das groß hilft, ich weiß es noch nicht. Meine wird erst eingebaut mit einem Winkeladapter und das könnte noch dauern 😆
@Ronin513
Steht hier komplett anders:
Ich weiß auch nicht, was ich mir mit dem Seasonic 1300 Watt gedacht habe... Habe halt schlimmeres befürchtet und der Preis war mit 255€ für ein 1300 Watt Platinum Netzteil schon verlockend.
Ich ahne schlimmes
@CasekingMike
Ja werden sie, hat mir cablemod schon bestätigt auf Reddit
ist halt manchmal so. Das 1650W Netzteil wurde sicher auch nur gekauft weil es lagernd war. Ich habe auch überlegt ob ich das nehme weil ich es halt garantiert demnächst erhalte. Aber ich hoffe weiterhin das Alternate recht behält mit dem Lieferdatum :)
Wobei mir ein Kabel von bequiet lieber wäre, weil ich da schon das NT besitze. Aber da siehts ja noch schlechter aus.
@Ronin513
Dieser Test sieht es auch etwas anders...
Ja dann bleib doch beim BeQuiet Netzteil und besorge dir das Kabel oder wo ist das Problem bei dir 🤔
Ähnliche Themen
