[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Also glauben wir am besten einfach dem Test der uns zusagt oder ? Immerhin sagen 2 Tests was ganz anderes.
Naja, aber das ist doch oft so bei Hardware Reviews :d, für die einen sind die Lüfter auf einer Karte lautlos, für die anderen unfassbar laut :d
Ja dann bleib doch beim BeQuiet Netzteil und besorge dir das Kabel oder wo ist das Problem bei dir 🤔
Kein Problem. Ich möchte nur eine Direktverbindung haben. Ich war noch nie ein Adapterfan. Und da suche ich einfach den schnellsten Weg. Und der ist halt das ATX 3.0 Netzteil. Das Kabel von bequiet ist nicht lieferbar und steht überall auch in nächste Zeit nicht auf verfügbar lt. Anzeige.
Bzgl. der Thermaltake-Netzteile hatte ich hier schonmal die Cybenetics-Datenbank gepostet. Die Werte für die ATX 3.0-konforme GF3-Reihe sehen da echt nicht prickelnd aus.
Average noise output beim 1650W-Modell: 45.70 dB(A)
Beim 1300W-Modell 40.83 dB(A).
Geht auf jeden Fall besser.
Moment mal... Du bist aber nicht zufällig der Kämpfer Goscha?? 🤯
Den kenne ich nämlich persönlich man!!
Ist so, aber das ist ja das Thema wenn etwas z.b. 20 db hat wie man damit selbst klarkommt. Aber hier geht es ja eher darum das manche im Test einfach eine komplett andere Lautstärke messen als andere. Wahrscheinlich ist es wie immer. Kaufen und testen und ggf. zurücksenden.
Theoretisch soll das bestellen des Adapter ab heute 0 Uhr losgehen....
Ich ahne schlimmes
@CasekingMike
Werdet ihr den Adapter bei euch aufnehmen irgendwann?
Nein! Nicht 0Uhr sondern Dienstag 2 Uhr!
Jetzt sagt der Timer noch 12 1/2 Stunden -> Di 02:00 Uhr
Ich befürchte ein Zusammenbruch der Cablemod Webseite; praktisch wie ein DDoS-Angriff ala "Mydealz Preisfehler" :d
Cybenetics testet Netzteile nicht einfach stumpf, sondern zertifiziert diese schon seit Jahren für Hersteller. Den detaillieren Report kannst du dir gerne auf der Seite anschauen. Wenn der Hersteller selbst schon diese Testergebnisse annimmt und den Bericht so freigibt, wird das wohl auch der Wahrheit entsprechen. Wüsste zumindest nicht was Gamezoom.net da noch weiter aufdecken könnte.
Leider nicht. Die Muckis hätt ich aber gern. :d
Bis dahin waren die Bots schneller. Aber stell ruhig den Wecker. Die Bots wissen auch das die Adapter gutes Geld bringen werden.
Vielleicht möchte ich ja auch einen Bot nutzen 😏✌️
Würde auch mit Bot den Wecker stellen bzw werde sowieso heute länger aufbleiben, da ich Corona habe und in Quarantäne bin. Bei mir läuft außer dem Kühlschrank Nachts nie etwas unter Strom, selbst der Router wird ausgeknipst, wenn ich das nicht vergesse :)
Bevor die Kabel nicht ordentlich von unabhängigen Reviewers getestet wurden, sollte man Cablemod auf jeden fall nicht als Heilsbringer verehren. Keiner weiß, ob die Teile nicht auch einen Hang zum Abrauchen haben^^
@****** Ne, wollte damit sagen, dass es keine US Firma ist. :)
Nur weil etwas aus China kommt, ist es ja nicht automatisch schlecht.
zumal die stecker ja die gleichen sind. wird im falle eines abrauchens halt nur schwieriger dem grakahersteller garantie aus der tasche zu leihern, wenn man nichtmal den originalen adapter verwendet hat.
tobi
wenn man Originalkabel vom Netzteil Hersteller verwendet, wird es auf jeden Fall Garantie geben.
tobi
Da kann man ja zur Not selbst Hand anlegen und mit nem Feuerzeug am NV Adapter rumkokeln ^^
haste schon erlebt und es gibt einen präzedenzfall.. ??? na dann ist ja gut.. wäre ärgerlich wenn PSU hersteller und IHV sich den schwarzen peter gegenseitig zuspielen und man am ende gar nichts hat.
tobi
  • Danke
Reaktionen: THK
Welches genau?
Aber ich warte lieber auf das Corsair dann kann man Notfalls jemanden die schuld geben :fresse:
Es ist noch im Versand, also kann ich noch nicht über die Qualität reden...es sollte aber vom Aubau genauso wie der von Corsair sein. Aber man kann bei ModDIY auch das sleeving aussuchen.
Was soll denn im schlimmsten Fall bei einem Dritthersteller-Kabel passieren? Was anderes, als dass das Teil durchschmort, kann ja nicht wirklich etwas passieren 🤔 die Grafikkarte geht deshalb nicht drauf und das Netzteil auch nicht. Das Kabel ist nur eine Verbindung von Grafikkarte und Netzteil. Entweder es fördert so viel Strom, wie die GPU benötigt oder eben nicht.
Bei so einem Durchschmoren kann der Grafikkarte oder dem Netzteil an sich nichts passieren.
Bei so einem Durchschmoren kann der Grafikkarte an sich nichts passieren.
Naja wenn der Stecker an der Karte mit an schmort ist die Karte aber auch hin, also im schlimmsten Falle aber gut man soll positiv denken.
Der GPU Stecker war zwar angeschmort aber war nicht weiter beschädigt, falls ich mich nicht täusche. So eine 4090 hält schon was aus 💪 😆
Ja auf jeden Fall 👍😁
Ähnliche Themen
