[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
30 MHz für so einen riesigen Aufwand. Naja. Sieht auf jedenfall schöner aus am Ende^^
NVIDIA, Intel und AMD haben dadurch, dass quasi alle Chips heutzutage an der Kotzgrenze laufen, Overclocking und den Sinn von Wasserkühlung etwas zunichte gemacht. Früher hat man da locker 15% mehr Leistung rausholen können, oder mehr. Heute? Vielleicht 1/5^^
Mit der 980Ti waren es noch gute 40-50% Mehrleistung. Ab Pascal wars das mit Overclocking. (y)
Anscheinend hat Asus das offizielle V1 Bios Update der Strix von ihrer Seite genommen, was da wohl los ist ?!
30% ist meistens die untere Grenze aktuell bei den Karten, darunter schlägt es in zRPM um. Ist selbst 30% denn zu laut bei der Gigabyte? Meine Karten und aktuell 3090 Suprim sind auf 30% quasi nicht hörbar.
Ne. Man muss das nur richtig einstellen. Im Desktop auf Fan1 46%, Fan2 49%. Im Game hab ich dann eine Kurve die bei 55% startet. Das ist super leise / nicht hörbar und wunderbar "kühl". Die 55% fahre ich bis 60°. Erst danach gehen die Lüfter weiter hoch.
Die leute, die jetzt eine Karte abbekommen haben. Nutzt ihr den mitgelieferten Adapter oder habt ihr vielleicht schon ein custom-12VHPWR?
Grundsätzlicher Funktionstest mit dem Adapter. Danach geht sie eh erstmal wieder in die Schachtel zurück, weil ich erst das neue Case haben möchte. Und je nach Verfügbarkeit liebäugle ich dann mit einem neuen Netzteil.
Gut wenigstens gab's dieses mal die Auflösung von Amazon selbst.
"Alle weiteren mit der Zahlungsweise "Bankeinzug" aufgegebenen Bestellungen werden storniert, weil wir zurzeit keine Bankeinzugstransaktionen verarbeiten können"
Also Info wer mit Amazon pay zahlen möchte
Ich nutze den mitgelieferten Adapter. Er macht ja das was er machen soll und ist auch nach einem Belastungstest zuverlässig.
Custom Stecker wird bestellt, wenn breit verfügbar (Corsair), vermutlich nicht vor März 2023. Einfach nur um etwas weniger Salat im Gehäuse zu haben, habs aber damit auch nicht so eilig. (y)
Die Leute die heute eine fe bestellt haben, werden um den Adapter nicht rumkommen.
Mittwoch 12.10 15:01 Uhr
Dienstag 18.10 13:00 Uhr
Mittwoch 02.11 10:04 Uhr
Finde das Muster🔍
Die werden einfach direkt die Produkte einstellen, sobald die per Post/Paketdienstleister angekommen und eingescanned sind.
Das heißt, am Ende haben wir hier puren Zufall.
Ich hab das Asus Thor PII und da ist das passende Kabel dabei. Adaptiert auf 2x8 Pin am PSU.
Puh…. Was hast du denn für eine Karte, dass du 55% als super leise oder nicht hörbar wahrnimmst? Wieviel rpm sind das bei dir?
Bei den karten die ich so kenne empfinde ich das schon als relativ laut.
Kaufabwicklung Ebay Käuferschutz meint der wohl. Würde ich sein lassen. Da kann der behaupten das da nix im Karton war und dann hat man nur Probleme. Würde nur Barzahlung oder Überweisung akzeptieren...
Jop, genau deswegen biete ich auch nur noch Überweisung, Barzahlung oder PP Friends an, alles andere bringt nur Kopfschmerzen
Also Saturn macht einen auch verrückt wenn man die Karte kaufen will
oder der hier :)
Eine 7900XTX kann ja maximal 375 Watt ziehen oder? 2x 8 Pin = 2x150 + 75 Watt über PCI-E
Eine 6950XT war bei 335 Watt.
Laut CB liegt die 4090 FE bei Faktor 1,82 zu 6900XT Black (=6950XT?) bei normalem Rasterizer ohne RT
  • Wenn wir hilfsweise von linearer Leistungssteigerung ausgehen, dann würde eine 6950XT mit 375 Watt ca. 11,9% mehr Leistung bieten als mit 335 Watt. Realsistisch wären eher 6%.
  • Ferner verspricht AMD 50% mehr Leistung pro Watte (Faktor 1,5)
  • Leistungsfaktor von der 6950XT (335 Watt) zur 7900XTX (375 Watt) Rasterizer
Realistisch: 1 x 1,06 (6% Watt) x 1,50 (50% per Watt) = 1,591 = 59% Mehrleistung zur 6950XT
Optimalfall: 1 x 1,12 x 1,51 = 1,691 = 69% Mehrleistung zur 6950XT
Damit würde die 7900XTX bei Rasterizer bei ca. 87% bis 93% der Performance einer 3090 liegen.
Aber nur wenn 50% per Watt immer eingehalten werden und die Karte Ihr 375Watt Powerlimit voll ausnutzt.
8-Pin kann bei modernen PSUs ohne Probleme 300W++ liefern:
Ach so?
Habs gerade nochmal gegoogelt und lese immer was von 150 Watt
Deswegen verweigert 4090 doch auch 600 Watt, wenn nur 3x8 Pin angeschlossen werden.
Die Ports am NT können (je nach NT) 300W liefern ja... aber auf der andere Seite sind laut Spec pro 2+6 Pin 150W vorgesehen, daher wird das auf einer Grafikkarte bei 2 x 8 Pin auch auf 300W hinauslaufen (+maximal 75W über den Slot) :)
Log dich vorher schon ein. Hat bei mir geholfen. Den Warenkorb auch gerne mal Neu-Laden. Aber natürlich nicht spammen. Hatte vorher auch die Cookies gelöscht, da mich das ständige Captcha aufgeregt hat.
Dran bleiben. Ist eine gute Karte, mit extrem guten Lüftern (laufen bei nicht so anspruchsvollen Spielen wie Wow, Phasmophobia usw gar nicht erst an). Nur Spulenrasseln hat sie bei mir.
Es gab genug 6900XT/6950XT mit 3x 8PIN, also ist da auch deutlich mehr an Watt möglich.
Beste Grüße
Also ich würde mich da an die Hersteller von NTs und GPUs halten und nicht an Cablemod^^
Corsair z.B. sagt selber 300 Watt je Anschluss am NT.
Beste Grüße
Wenn dem so sei und die 7090XTX nur bei ca. 1500 Euro liegt, werden hier einige Leute sich wenigstens wieder die 4090 holen können.
Allerdings ist bei Raytracing der Vorsprung vermutlich deutlich höher.
Also 150 Watt ist der PCI-SIG Standard. Dieser wird aber schon lange nicht mehr eingehalten. Du kannst safe von 300W+ ausgehen
Beste Grüße
Beste Grüße
Und waren die dann schneller als die 6950XT mit 2x8 Pin?
50% sind es. Hatte mich vertan. Macht auf FanController 1 850RPM und auf 2 730. GA Gaming OC.
Echt schade das man keine 2 Kurven / je eine pro Controller basteln kann.
Ich glaube nicht das die wirklichen Enthusiasten auf AMD schauen und warten was passiert. Die meisten haben ihre Entscheidung schon getroffen. Ob AMD oder Nvidia wird entschieden von allen anderen Käufern. Aber selbst das bleibt erstmal abzuwarten ob und was Anfang Dezember lieferbar ist.
Ähnliche Themen
Antworten
6K
Aufrufe
311K
