[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Also 150 Watt ist der PCI-SIG Standard. Dieser wird aber schon lange nicht mehr eingehalten. Du kannst safe von 300W+ ausgehen
Ich hoffe du stehst dann auch für eventuelle Schäden parat wenn es welche gibt. Es gibt auch viele Netzteile die Marke und höherwertiger sind bei denen davon abgeraten wird.
DIe 8 Pin Ports an den Karten sind ziemlich sicher für 150W vorgesehen und nix anderes, nur weil (manche) Netzteile 300W ausm 8 Pin pressen können, heißt das nicht, dass die Karten auch 300W aus einem 8 Pin auf der Karte ziehen
Ich glaube nicht das die wirklichen Enthusiasten auf AMD schauen und warten was passiert.
Denke schon das die das tun werden, als echter Enthusiast macht man sich eher nicht von einem Hersteller abhängig.
Es wird das gekauft was grade am schnellsten Ist. Heute 4090, Morgen 7950XT, Übermorgen 4090Ti. So ist das zumindest bei mir :ROFLMAO:
Asus zB:
"Jedes ROG Thor 1200W Platinum II Netzteil wird mit einem 16-poligen PCIe-Kabel geliefert, das PCIe Gen 5.0 Grafikkarten mit bis zu 600W Leistung versorgen kann. Mach dich bereit für die Zukunft der Stromversorgung."
aber:
"Jedes ROG Thor 1000W Platinum II Netzteil wird mit einem 12-Pin-PCIe-Kabel geliefert, das bis zu 450W Leistung an PCIe Gen 5.0 Grafikkarten liefern kann. Mach dich bereit für die Zukunft der Stromversorgung."
Man muss also da auch noch aufpassen.
konnte heute eine 4090 FE bekommen.
Was ist die aktuelle META? Undervolting und PL limitieren?
Falls ja, gibt es einen Leitfaden zum Thema UV oder bereits gut funktionierende Anhaltspunkte?
Afterburner nach- wie vor das Tool der Wahl - oder direkt ein BIOS flashen?
genau, deshalb hast du dir auch direkt eine 4090 gekauft.
Da streiten sich die Geister. Influencer sagen PL verkleinern. Erfahrungen mit UV sind besser.
nein, würde aber stark darauf ankommen was du willst. Einfacher ist PT senken natürlich, aber je nach UV haste mal 1 bis 3 FPS mehr eventuell. Was man so liest sind viele bei 900 - 910mv bei 2650 bis 2670 Mhz.
50% sind es. Hatte mich vertan. Macht auf FanController 1 850RPM und auf 2 730. GA Gaming OC.
Echt schade das man keine 2 Kurven / je eine pro Controller basteln kann.
Muss ich mir nachher mal anschauen, bei der Gigabyte hab ich mir die Steuerung noch nicht so genau angeschaut. Gigabyte scheint die Steuerung dann aber besser umgesetzte zu haben.
-25% PT +150 Mhz Core Clock + 900 Mhz Mem Clock. Sollte ein guter Ansatz sein. Damit liefen meine 4090er schneller als Stock bei min 80 Watt weniger max Leistungsaufnahme.
Na ja. Ich mach alles mit AB. Da sind 46% aktuell mit Bios V2 Minimum auf Controller 1. Sonst laufen die beiden linken Fans nicht rund. 2 hat dann 49% um die RPM zu matchen.
Was geht denn so am OC bei der FE? Ich hoffe, dass ich unter WaKü da stressfreie OCen kann.
Hast du was anderes erwartet? Es war doch klar das viele die hier mit ihrer FE geprahlt haben die nur weiterverkaufen möchten. Das werden sowieso die Karten sein die von den letzten Scalpern jetzt zurückgeschickt wurden. Untern Strich hat man damit halt immer das Gefühl das die Karten begehrt sind.
Kommt drauf an was du willst. So geile Ergebnisse gibts hier bisher nicht :d Die Karte ist mit UV oder co viel interssanter. 250W verbrauch auf 4k mit fast 100 FPS. In RDR2 habe ich sogar 120 FPS bei 280W verbrauch.
Laut meinen Tests ja. Und was machen wir jetzt ? Wir belassen es dabei das beides gut ist und man keine pauschale Antwort geben kann oder ?
Uff.... ich schrieb "ein Anhaltspunkt" da er erstmal etwas sucht mit dem er anfangen kann. Schreib doch einfach deine uv Werte rein mit denen du bei allen deinen Modellen die beste Effizients und Performance erreicht wurde und gut ist. Mein Anhaltspunkt ist denke ich für jeden der nicht viel tweaken will einfach umzusetzen bei gleicherbleibender Leistung und trotzdem großer Leistungseinsparung.
PT begrenzen ist wenn man nicht viel Stabilität testen mag sicher einfacher ja :) aber dann ohne Core OC, wenn man wie du PT senkt und Takt erhöht, darf man wieder fleißig testen.
Modellen? Du wirst lachen, es wurde eine Karte bestellt und eingebaut weil dafür direkt der Wasserblock da war. Mehr brauche ich nicht. Ich habe bereits über dir Anhaltspunkte geschrieben. Passt alles.
+2% sind Dir so gut wie sicher (y)
Ich dreh voll auf und hoffe auf 3% :-))))
nein mal im Ernst unter Wasser laufen die Dinger deutlich besser.
Jedenfalls hat meine 3090 bei LuKü, 60% PT und offenem Gehäuse deutlich weniger FPS produziert als bei WaKü mit 60% Powertarget
Bei 114% und OC lag GPU bei ca. 40 Grad, Hotspot bei +12-14 zu GPU, und VRam bei 44 Grad und es lagen immer 2-2,1GHz an der GPU unter Vollast
Jetzt bin ich doch schwach geworden beim 5800x3D...aber die 1% lows sind halt schon verlockend...
Das ist absolut richtig. Die Werte sind aber recht konservativ und sollten bei vielen laufen. Ich kenne keinen (gut sind nur 5 Karten) bei denen das nicht lief.
  • Danke
Reaktionen: hwk
Mit Spucke kannste auf 2,5% hoffen. Mehr is nicht. Hier gibt es fast keine OC Werte. Out of Box oftmals 2700 Mhz round about. 3000 mit OC. Macht den Kohl aber nicht Fett. Die 4090 ist tatsächlich weniger das OC Wunder als das UV Wunder. Aber du darfst gerne testen was mit der FE geht.
Ich glaube das ganze gilt eher für LuKü. Die Unterschiede bei der 3090 zwischen LuKü und WaKü waren brutal. Deutlich mehr Takt bei gleichem PT.
Aber ist natürlich nur subjektive Erfahrung - Stichprobengröße 1, andere Karte und der Ram wurde unter LuKü nicht sauber gekühlt.
Ist aber auch ein Spitzen-Preis für die Leistung auf AM4.
Also ich habe die 4090 unter Wasser. Hatte die erste. Und bei mir war der Takt unter Wasser fast genau gleich wie unter Luft. Bei weniger Temperatur natürlich. Ich habe aber nie OC getestet, da ich es viel besser finde wenn ich fast die dreifache Leistung zu früher habe, bei sogar noch deutlich weniger Verbrauch.
Aber dafür ist der Beitrag ja da, darfst gerne das letzte rausholen.
:cry:
Welcher Block? Ich denke an Alphacool.
Ähnliche Themen
