[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
mal reinschauen ...
€: Also in 4K ist das nur mit DLSS3.0 im Performance Mode! und mit Frame Generation flüssig spielbar. RTX 5090 incoming!
Naja was heißt "nur mit". Dafür ist DLSS ja da. Entscheidend ist ob Dich die damit verbundenen Nachteile stören oder nicht. Ist ja von Spiel zu Spiel unterschiedlich.
Oh boy, ich hab die 4090 FE eingebaut... nachdem ich 6mal überlegt hatte :bigok:
4090 FE -> Boost auf 2805 MHz
Hinterer Lüfter macht eigenartige Geräusche, aber nicht so laut.
Spulen selbst bei 1.05v nahezu lautlos. Man hört was, aber absolut kein Vergleich zur TUF OC.
Ganz interessant: Idle Verbrauch mit einem Monitor
TUF: 22 bis 23w
FE: unter 7w
(laut HWinfo)
Wenn man mich jetzt fragt, was mich mehr stört, die Spulen der TUF OC oder der hintere Lüfter der FE... dann die Spulen der TUF OC!
Wobei die andere TUF dazwischen war.
Mal gucken, was OC mäßig bei Warhammer Darktide mit FrameGen so geht.
Ist das die neue von der Nvidia RMA?
mal reinschauen ...
haben die das game absichtlich mies optimiert und 10x RT reflections übereinander gestapelt? das kann doch net sein...
Die Anzahl an Reflections kannst sogar einstellen. Zwischen 1 und 10 glaube. Stock sind 4 oder 5?
LDLC.fr (wichtig Frankreich) hat aktuell die Gigabyte OC Gaming für ~2100€ inkl Versand und die Windforce für ~1850€ mit Rabattcode "GOODGAME". Für diejenigen die die 1790€ Phantom nicht wollen. Liefert nach Deutschland.
So da isse nun meine kfa2 4090 😍
Sieht geil aus. Und Leo grüßt auch im Hintergrund :LOL:
Erste Eindrücke?
Danke :). Joa bin zufrieden, bisher +1600 mem und + 220 core getestet, lief mir in Port Royal, Timespy Extreme durch. Port Royal war dann so im Peak bei 3045 mhz durchschnitt 3008 mhz Score um die 28k, Karte ist super Kühl und leise, bin zufrieden
Ich habe auch eine Strix. Allerdings ist der Block schon drauf. Ich habe inzwischen das Seasonic Kabel angeschlossen. Ich finde, dass es einigermaßen clean ist. Mit Adapter würde es vermutlich anders ausschauen :poop:
Ok das is aber nich der Adapter du nutzt ja ein Nativ Kabel
mir gings nun darum wie die Leute den Adapter von nvidia verlegt haben beim Vertical einbau um zu schauen obs noch bessere Lösugen geben könnte bei der Verlegung des Nvidia Adapters.
Aber wie ich sehe hast du schon den EK Block drauf .. der wird nun auch von Unten beleuchtet so wie ich das auf deinem Bild sehen kann beim 3080 Strix Kühler kamm das RGB Licht ja nur von Rechts.
Auf den EK warte ich nun auch bis der wieder lieferbar is für die 4090 Strix
Das ist mir bei der Strix auch aufgefallen, der Stecker ist bescheiden Positioniert wenn man vertical mount möchte. Da ist die MSI angenehmer, da deutlich weiter hinten angebracht.
Gut soviel mehr platz für den Stromanschluss is bei der Strix ja rechts auch nich mehr. Der Stromanschluss is schon recht weit hinten .. vielleicht noch 1cm oder so platz rechts.
Vielleicht is dann eher das PCB der MSI länger als das der Strix und daher is der Stromanschluss weiter hinten kein plan aber viel platz is da auf dem PCB der Strix rechts nun auch nich mehr
Hab noch eins der Strix, da sieht man ganz gut die Position Ist halt direkt über dem Ram
jup das war auh der Punkt den ich halt angesprochen hab das mein Strom Kabel nun direkt den RAM berührt der um die 42 Grad und mehr warm wird ( Bilder hatte ich ja schon Gestern gepostet wo man das sieht )
Aber hier nochmal :
und das Stromkabel erzeugt ja auch wärme und wenn das dann nochmal zusätzlich durch den RAM erwärmt wird is das nich die beste sache
Und genau deswegen hatte ich danach gefragt wie ihr so den Nvidia Adapter bei Verticalem einbau so verlegt habt.
Was denkst du? Passt die auch ins normale O11? Sieht bei dir vom Platz her ja recht gemütlich aus. Bei mir müsste man nochmal ca. 1,5cm abziehen.
Ohne DLSS ist 4K einfach schärfer, mit etwas weich und verwaschen. Also ja, "nur"..
Redest du jetzt nur von dlss oder frame generation? Fg ist genau so scharf wie nativ.
Jetzt kam die 4080 fe wieder von nbb an mich zurück. Ich dreh mit denen durch... ich wollte nur die 4090 zurück. 🤪
Bei Ebay liegen noch 2 nagelneue KFA rum, Verkauf von Mediamarkt Klick mich
Nachdem die FE auf unter 1.900€ gefallen ist, sind das keine guten Preise mehr. Die "Dacia" Karten könnten gerne auch mal die 2.000er Marke knacken.
Mein cable mod Kabel ist da...Wie scheisse sieht das denn bitte aus?!
Lass dich nicht irritieren. Inzwischen nimmt das Thema jeder auf die Goldwaage. Die Sockets zentrieren sich automatisch.
Meine 4090 ist inzwischen auch eingebaut. Bin allerdings mit dem Vertical Einbau sehr unzufrieden:
A) Die FE sieht so eingebaut einfach nicht schön aus..
B) Die Karte kommt mit der Länge immer weiter nach vorne an die Scheibe und ist nicht 100% gerade. Das Riser Kabel dahinter wirkt wie eine Feder gegen die Halterung.
Mich nervt es unglaublich das die Karte nicht in das "alte" Lian Li O11 passt. Bin kurz davor mir das Lian Li O11 Evo zu kaufen.. was aber eigentlich totale Geldverschwendung wäre. Habe die böse Vermutung das selbst der 90° Adapter von Cablemod nicht zwischen Karte und Scheibe passen wird.
Bei so viel Geld für eine Grafikkarte, will man am Ende einfach ein perfektes Ergebnis, auch wenn es da nur um die Optik geht.
Noch ein paar Worte zur Karte: Bin sehr zufrieden, insgesamt sehr leise und wenig bis kein Spulenfiepen. Auch der Lüfter eiert nicht.
Das die nagelneu sind würde ich meine Hand nicht für ins Feuer legen. Ich habe das Gefühl, dass die bei Media Markt/Saturn herumgereicht werden, wie...ach egal. :fresse:
Bei der Retour von meiner (Welche ganz klar schon mindestens einmal ordentlich durchgenudelt wurde) gab es auch so eine Klausel bzgl. Weiterverkauf, was mir dann wenig später auch direkt bestätigt wurde.
Ähnliche Themen
Antworten
6K
Aufrufe
392K
