[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Joa wenn du msaa aus hattest ist klar das du mehr fps hattest :)
Logischerweise hatte ich MSAA aus da ich DLSS Qualität anhatte ... DLSS + MSAA is doch auch Blödsinn da DLSS schon die Kanten Glätet da brauch man kein MSAA mehr
DLSS macht auch nen besseren Job als TAA .. und mit DLSS Schärfung sieht DLSS auch nich mehr so unscharf aus
Ich war 20 Sekunden ingame und hatte vorher im Menü msaa angeschaltet da ich damit gerechnet hatte, dass das Spiel mit 300 fps nativ läuft 😅
Jo 4K Path Traicing mit 300 FPS :ROFLMAO: ... in 10 jahren vielleicht .. Ohne Path Traicing ok da läuft das Sicher mit 300 FPS aber du scheinst wohl bisher echt nich gewusst zu haben was Path Traicing is
und bist da deswegen so leicht sinnig rangegangen dabei gibts doch die Quake 2 Path Traiced Demo schon einige Jahre .. wir sind bei Ray immernoch in den Kinderschuhen und Path Traicing is das Erwachsen werden aber da sind wir noch ein paar Jahre von weg
Und wie gesagt Portal RTX Remix basiert auf Path Traicing und nich auf Ray Traicing wie wir es zb aus Cyberpunk kennen
man man man. ohne passende cpu ist das echt zum heulen :d
Da kann was nicht stimmen , wenn ich mit meinem 10900K keine Probleme habe und auch 120 FPS haben kann , wenn ich DLSS von Qualität auf Performance setze.
Ein 12700K muss eigentlich damit besser laufen. Habe auch Menschenmenge auf max.
Ansonsten aktuell Dying Light 2 am zocken . Habe bisher gut 8 Stunden gespielt und eben 3 Stunden am Stück.
Rennt echt sauber mit der 4090 mit meistens 100 FPS + in 4K max. @ RT und DLSS Qualität.
Wenn ich da damals die Benches angeschaut habe mit der 3090 ist das echt gut was die 4090 da leistet.
Game macht auch ziemlich bock. Hatte damals 2015 Dying Light 1 Story gezockt und dann dieses Jahr erst den DLC The Following .
Dyling Light 1 sieht für sein Alter ziemlich nice aus vorallem mit Auto HDR . Macht wirklich einen deutlichen Unterschied.
Dyling Light 2 sieht zwar besser aus von den Texturen her und dem Raytracing Effekte , aber weit von einem Quantensprung entfernt, wenn man direkt die beiden
hintereinander zockt.^^
Hast du auch eine Quelle dafür das Cyberpunk Path Tracing nutzt im angekündigten Overdrive Mode?
Nope zumindest keine Offizielle Quelle ... ich nehme es aber sehr stark an .. und wenn es nicht drinn is dann hab ich mich halt geirrt und wenn dem so sein sollte isses eh egal. :ROFLMAO:
Bin auch nich alleine auf der Welt der diese Vermutung hatte :
Auf der GDC gabs wohl was dazu :
Aber Justice ( Online MMO ) nutzt es zb schon in einer Internen Version bzw kamm wohl am 12 Oktober das Path Traicig Update raus
Und dann haben wir ja noch Quake 2 RTX , Minecraft RTX und Portal RTX und ich auch glaub auch die Quake 1 Mod
( https://overclock3d.net/news/software/a_fully_path_traced_version_of_quake_has_been_launched/1 )
die auf Path Traicing setzten .. genug also um das mal auszuprobieren und zu merken dass das noch ne weile dauert und eben noch keine 300 FPS bei 4K möglich sind mit den 4000er Karten :d
Die Nvidia Marbles Demo is auch Path Traicing die hatte ich noch vergessen die kann man ja auch schon seit ner Weile im Nvidias Omniverse Downloaden
Und seit der 4000er kennen wir ja Nvidias Racer RTX was auch auf Path Traicing setzt zumindest nehme ich das dort auch sehr stark an auch wenn ich dazu auf die Schnelle eben nix gefunden hab
Quake 1 , Quake 2 , Minecraft , Portal , Justice , Marbles und Racer X* bzw Racer RTX* haben Path Traicing. ( * = dazu hab ich noch keine Offizelle Quelle gefunden )
Da is also schon genug drausen ( und das nich erst seit 2022 ) um zu schauen wie gut das auf dem eigenen Rechner läuft oder eben wie gut es nicht läuft und merkt das man eben noch weit weg
von 4K Path Traicing mit 400 FPS is die der user "Scrush" ja bei Portal RTX Remix erwartet hatte :d
Da werden noch 1 - 3 Gens ins Land ziehen bis Path Traicing vernünftig Spielbar is besonders bezogen auf neuere Games und dann auch ohne DLSS hilfe
Die Strixx von der8auer ist auch wieder gefixed:
Top Mann, wenn mit meiner mal was sein sollte, versuch ich mein Glück dort. Sind nicht so weit weg von mir.
Hab ich was überhört oder wie kommt es zu den korrodierten Kontakten beim RAM?
Ob die Reballing-Matrize von NV stammt oder Eigen-Produktion ist? Auf die Schnelle hab ich nichts im www gefunden
Oder gegen viel Geld direkt von NV? Eine Matrize für 3080/3090 ist aber für 20€ bei Ali zu haben
Zum VRAM oc: Wer auf die Schnelle herausfinden möchte, ob der octe VRAM stabil ist: memtest_vulkan
Schnelltest für 5min.
Langzeittest max 2h.
Kann nebenbei laufen (desktop), keine Parameter zum Einstellen.
Meine Erkenntnisse bisher:
- Bevor nen Spiel abstürzt, zB nach 20min Spielzeit, schlägt der Test viel schneller zu.
- Eignet sich gut für grobes Ocing in 100MHz Schritten: Wenn nen Error nach max. 5min rausgeballert wird, dann 100MHz zurückschrauben. Das sollte dann stabil sein. GGf vortasten in 50MHz Schritten möglich.
Beispiel eines aktuellen runs, +1600MHz:
So, habe mich dafür entschieden, die Folie auf die VRAM pads zu legen. Also Aufbau: VRAM-Chip -> Folie -> pad -> Block
(Luftblasen zwischen pad und Folie rausdrücken)
Die VRAM temps gehen nun hoch von 36-40°C auf bis zu 58°C, selbe Stelle in Diablo 2R, wo die Graka 540W braucht, 10min getestet.
Laut den Berichten im overclockers scheint 50-60°C nen sweetspot zu sein. Zufällig treffe ich mit einer Folielage diesen Bereich.
Das hab ich auch vor. Preisfrage, wie viel höher ist die Temperatur im Leerlauf? Unter Last ists eh warm genug, nützts ja aber nichts, wenn der Crash beim Switch in P0 kommt.
Memtest Vulkan ist daher auch nutzlos, weil es dem Speicher einheizt. Schön wenn es mir den Max. OC bei 80 Grad VRAM ermittelt. Bei 30 Grad crasht mir damit jede 3D Anwendung beim Start.
@Slipknot
Beim Test - wie sieht man dann, wieviel der Speicher grob ab kann?
Du stellst im MSI AB den MHz-Wert auf VRAM ein, den du testen möchtest.
Wenn du errors in 5min bekommst, dann geh 100MHz runter. Teste erneut. Wenn 5min stable sind, dann lass 2h laufen.
Das tool ist relativ streng. Wenn du in 2h 1-2 errors bekommst, dann kannst du trotzdem davon ausgehen, dass Spiele, Benchmarks usw. ziemlich sicher stable sein werden.
Wenn dich die 1-2 errors aber stören, dann nimmst du noch 50MHz runter.
Für alle Gehäuse geplagten. Ich lasse mir jetzt folgende Spacer drucken, ich hoffe damit bekomme ich die die Scheibe zu (Lian Li O11 Dynamic). Ich werde berichten sobald die Spacer fertig sind und ein paar Fotos machen.
Die war doch wieder im A als er sie Testen wollte.
Das beqiet Adapterkabel ist ja mal deutlich besser als das Gelumpe von Nvidia, passt perfekt in mein O11 Gehäuse.
Sind 27.500 Punkte im 3D Mark ok für eine 4090 + 5900x Kombi @ Stock oder zu wenig?
direkt mal auf 1400 runter, 1500 dicke Fehler
Darktide ist 100% ein absolut mieser Indikator für Stabilität. Kann ich bestätigen.
Timepsy normal kommt man schnell ins CPU limit .
Extreme ist da schon besser.
Mit einem 10900K 5,3 GHZ und 13700K habe ich schon öfter 38K Grafikscore gesehen bei ähnlichen Takt.
Meine CPU ist leider nicht so geil , aber reicht noch aus zum gamen.
Kann auch das neue Galax 666W Bios empfehlen damit konnte ich die 11K in Speedway knacken :)
Info: Gigabyte Gaming OC 4090 für 1999€ gerade bei Computeruniverse im Tagesangebot
Das können dann aber anscheinend nicht viele gewesen sein. Von 20% Verfügbarkeit auf jetzt nur noch 8% in nicht mal zwei Minuten...
Edit: Jetzt steht die Stückzahl bei 8% dran.
Ähnliche Themen
Antworten
6K
Aufrufe
353K
