[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Habe mir gerade das Video vom KrisFix-Germany angeschaut. Super Typ, warum heißt der eigentlich "Germany"?
Das Video sollte man verlinken:
Das nenne ich mal einen Content.
Weil er ein deutschen Reparatur Shop betreibt -> https://krisfix.de/
Warum sind bei dir sowenig GB/sec?
Gute Frage, habe ich mich auch schon gefragt. Mir ist da nur aufgefallen, dass auch die Watt niedrig waren, weiß aber nicht mehr welcher Wert, irgendwas um die 170W?. oO
Aktuell passt es wieder, Leistung bei ca 370-390W:
Ich lasse jetzt mal nen 2h run laufen bei +1600MHz mit Folienmod.
Temp VRAM aktuell 60°C, Wasser 22,3°C.
direkt mal auf 1400 runter, 1500 dicke Fehler
Alles qool, einen Schritt näher zum stabilen System. (y)
Bei mir sind es 360W hab memory nur auf +1000 und GPU läuft mit 2.925 Mhz bei 1.05V
Mir ist die Tage auch aufgefallen das die 4090er irgend ein Bug haben im Treiber. Ich mache viel mit CUDA und es gibt immer mal den Fall das die GPU nicht in den höchsten Performance mode geht die verbraucht dann auch nur so 170W und ist dann richtig langsam. GPU nutzung steht dann bei 99% aber die taktet nur bei 790Mhz rum Temperaturen und alles ist völlig in ordnung und Performance cap wird idle gemeldet.
Einziger Workaround war dann immer irgendwas anderes zu starten damit die wieder auf vollast geht. Alternativ hilft im Treiber max performance zu setzen aber das kann doch auch nicht die Lösung sein.
Oder PC neustarten dann läuft wieder alles ne zeit lang wie es soll.
Weiße Strix? Aber fix!
ich dachte erst, der8auer hätte seine 4090 zu techmagnet geschickt :d
kannte ihn (krisfix) bis jetzt auch nicht, aber respekt was er so macht :)
ich hatte so meine probleme, ihn zu verstehen im video
Zum VRAM oc: Wer auf die Schnelle herausfinden möchte, ob der octe VRAM stabil ist: memtest_vulkan
Schnelltest für 5min.
Langzeittest max 2h.
Kann nebenbei laufen (desktop), keine Parameter zum Einstellen.
Meine Erkenntnisse bisher:
- Bevor nen Spiel abstürzt, zB nach 20min Spielzeit, schlägt der Test viel schneller zu.
- Eignet sich gut für grobes Ocing in 100MHz Schritten: Wenn nen Error nach max. 5min rausgeballert wird, dann 100MHz zurückschrauben. Das sollte dann stabil sein. GGf vortasten in 50MHz Schritten möglich.
Beispiel eines aktuellen runs, +1600MHz:
ist das bei 1600 schon eine Fehler Korrektur weil da immer um die 111GB/s lesen stehen?
Oder was ist der Grund dafür weist du das zufällig.
Weil so sieht es bei mir aus mit +1000 auf dem Ram.
Das habe ich mich auch schon oft gefragt. Der Typ ist ein stinknormaler Peer-Influenzer, der mit infantilen Sprüchen ("Asus, wir müssen reden...") die Aufmerksamkeit einer bestimmten Klientel erheischen will.
Hier im Forum (und Igor) hat man ihn auch schon verstärkt inhaltlich unter Beschuss genommen. Seine Reaktion war die Löschung aller seiner Postings.
Noch Fragen?
Immerhin war er der einzige deutsche yter der die lautstärke der 4090 fe angesprochen hat. Neben dem einzigen englischsprachigen kitguru. Alle anderen finden sie leise. Der bauer hat auch gute videos wenns um köpfen, tweaken o.ä. geht. Aber viele videos sind quark. Pc unter wasser usw.
mhm also ich hatte meinen RAM bisher bei +1499 überall stabil, aber das Tool sagt mir selbst bei +999 Fehler :LOL: Weiß nicht ob man da so viel drauf geben sollte
aller posting, oder nur die zu einem bestimmten thema, weil der account der8auer ist doch noch aktiv hier, oder wurde der auch gewechsel?
Du sollst auch nicht Tetris spielen, sondern mal Warhammer Darktide oder speed way anwerfen. Division 2 wurde auch genannt? :o
:ROFLMAO: Darktide habe ich nicht. Speedway läuft durch mit +1499 und sonst zocke ich derzeit MW2, Hunt Showdown und Plague Tale. War aber mein Fehler bei +999 mit den Fehlern. Hatte nicht auf bestätigen gedrückt im AB. Bin jetzt bei +1199 ohne Fehler
Darktide Spakt immer noch ab bei mir Stock.
Klar, wenn es stock upkackt, dann natürlich den Shice nicht verwenden.
Ich glaube, du bis schneller wenn du von oben beginnst? zB 1800MHz. Bei error auf 1700MHz usw.
Macht jetzt keinen Unterschied mehr. Hatte 1499 Fehler, 1399 auch. Jetzt teste ich grade schon 1299
DLSS DLL 2.5 ist raus, soll angeblich Ghosting beseitigen.
Natürlich kannst du da was drauf geben, allerdings ist das ganze auch abhängig von Takt der GPU und ob die Volt dazu passen. Man kann sich selbst bescheißen und mit einer im Grunde ständig instabilen Karte glücklich sein oder aber Werte ermitteln, die in allen Lebenslagen stabil sind, inklusive max. Raytracinglast stundenlang. Portal RTX ist ebenfalls ein sehr guter Stabitest.
Bei mir ist bei +1150MHz Schluss auf dem Vram, also mit z. B. GPU Werten von 2730MHz bei 0.975V - 2730MHz mit +1250 Vram laufen aber auch mit nur 0.940V durch einen Time Spy Run, aber nicht bei max Raytracinglast oder Speicherempfindlichen Games. Du kannst davon ausgehen, dass der Vram bei 1600 oder sogar darüber heftig in der Fehlerkorrektur läuft, also wenn sich die Karte nicht komplett aufhängt, so viel OC Spielraum, ist da meist nicht beim Vram - viel mehr als +1250 sehe ich da nicht im Schnitt, also dass der Vram nicht in die Fehlerkorrektur läuft, natürlich gibt es aber auch wieder die Ausnahmen, die doch höher schaffen - macht die Karte dann natürlich auch langsamer, wenn der Vram ständig die Fehler ausbügeln muss - manchmal ist eben weniger mehr.
Meine Bestellung ist noch für 2130€ im System vermerkt und bezahlt anstatt wie kurz danach bzw. jetzt wieder 2300€. Von daher hab ich gedacht ich warte mal ab...in der Zwischenzeit gabs ja quasi alle möglichen Karten von allen möglichen Herstellern wieder mal im Verkauf, auch die TUF OC...aber halt dann bei Saturn und nich bei Asus im Shop.
Wider sämtlicher Erwartung wurde meine Bestellung einer 4090 TUF OC vom 22.11. heute verschickt. Hab ja echt mit ner Storno gerechnet. Mal sehr gespannt ob das so ein Fiepkonzert wird wie alle berichten. Vielleicht ist die neue Charge ja besser (wer's glaubt :d).
Und unterm Strich zufrieden mit dem Case? Sieht gut aus
Jup, habe Mesh Version mit zwei 140er Noctuas vorm RAM und GPU. Hat nur mit dem Seasonic 12Pin Adapter überhaupt gepasst, mit dem Original Nvidia keine Chance neben die GPU die Lüfter zu installieren.
Passt wirklich nur weil das Seasonic Kabel sehr dünne Strippen hat die man um 90 Grad biegen kann direkt am Stecker.
Genau ein Finger Platz zwischen dem Panel und der Karte.
Ähnliche Themen
Antworten
6K
Aufrufe
353K
