[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Rüste ja nicht jedes Jahr auf. Habe eher Angst die ganze Bude unter Wasser zu setzen.
Davor hab ich auch Angst, deswegen auch bis heute noch keine Wakü drin. Und das Teil muss ja auch regelmäßig gepflegt werden, wassertausch etc.. Zu Faul für solche Geschichten :d
Ordentlich verschlaucht/verrohrt und abgedrückt, wird da nichts passieren
In 17 Jahren Wakü ist mir noch nie HW oder sonstwas kaputtgegangen
Aber zugegeben gab es schon mal Riesen-Sauerei mit einer zu starken Pumpe, trotz doppelt gesicherten Schläuchen :d
Das Aufrüsten ist halt gleich mal deutlich teurer, wenn man ne WaKü im System hat :d
Neue Graka? Pah, erstmal nen Block kaufen.. Neue CPU?.... usw.
Neuer-CPU-Block ist seltener nötig mit neuer oder geänderter Halterung
Hatte beim letzten System nur nachgefüllt - und das 10 Jahre lang :fresse:
Das Wasser ist so stark mit Kuper-Ionen durchseucht, dass da nichts mehr wachsen kann :d
(hab ich lediglich mal gefiltert)
Ist halb so wild! Wartung ist bei klarer Flüssigkeit auch nicht so oft nötig. Bringt Boost, schönere Temps, etwas Sparsamkeit und sieht meiner Meinung nach viel geiler und vor allem eleganter als die großen Backsteine aus
Ich weiß immer gar nicht was alle haben mit geil aussehen und so. Das olle Güllefass und die ganzen Strohhalme im Rechner brauch ich nicht, ganz zu schweigen eben vom erhöhten Aufwand in allen Belangen. Aufbau, Wartung, beim Wechsel von Komponenten... ne gute Luftkühlung leistet genug fürs Gaming und kann auch absolut leise sein.
Also soll jeder machen was er will, aber diese ständigen Überredungsversuche der Wakü Sekte sind ja schon fast illegal. :fresse:
Wie hieß nochmal der versandumleitungsservice von frankreich nach deutschland?
Ich lese immer was von Lautstärke.. Wenn ich zocke hab ichn Headset auf.. Oder meine Anlage so laut, dass der PC fast vom Tisch segelt.. Was für Lautstärke? :hmm:
Und wenn ich nicht zocke stehen alle Lüfter komplett still -> lautlos..
Schön für dich. Andere sind halt schon erwachsen und drehen die Anlage nicht ganz so laut auf. Frauchen und die Kids müssen ja nicht jeden Headshot mitkriegen. ;)
Selbst dann ist eine Luftkühlung nicht lauter als das Spielgeschehen ;)
WaKü ist schon was feines, aber es war jedes mal viel Arbeit, dann musste bei jeder neuen GPU nach Block suche, warten etc.
Am Schlimmsten fand ich immer die Arbeit. Mit Luft dreh ich zwei Schrauben raus und hab die GPU in der Hand. Done! CPUs testen mit Luft auch deutlich einfacher.
Heute kann man Luft schon relativ leise betreiben, WaKü nicht mehr zwingend nötig. Früher, zu 2080TI Zeiten, der Düsenjet einer GPU, ohne Wasser unerträglich!
Ich bin froh, heute keine WaKü mehr betreiben zu MÜSSEN. Klar, wenn dein System unter Load so leise bleibt wie Idle, ist das sehr sehr nett, aber es ist eben nicht mehr zwingend nötig, so wie früher.
Wenn ich dran denke, Tripple SLI mit WaKü. Ich habe damals 330€ nur für GPU Blocks im System gehabt bei drei Titans.. Das war ne kranke Zeit.
Meine Wakü lief damals mit 300 RPM, fixed. Nen Mora und die gleiche Fläche intern. Alles Noctuas, fast 1000€ nur für Nussecken. DAS gekommst du auch mit deiner Lüfterkurve nicht so leise, niemals.
Wer behauptet eine Luftkühlung kommt bei Systemen die deutlich >500Watt verbraten auch nur annähernd an eine gute Custom Wasserkühlung in Sachen Lautstärke, hat einfach keine Ahnung.
Dazu noch die ganzen positiven Effekte aufs OC mal komplett ausgeklammert. Davon ab, auch ich mag beim Zocken ein Silent PC, egal ob eine laute Soundkulisse vom Game ausgeht oder nicht.
Vom Aspekt Optik fangen wir besser gar nicht erst an.
Wenn ich mir heute wieder eine Wakü holen würde, dann nur um wieder unter Load auf die Lautstärke zu kommen, die ich jetzt Idle habe. War schon geil, unter Fullload lief der Hobel damals mit 300RPM. Hast nur die Karten zirpen gehört ;)
Hier ist erst einmal dicht, bis ich oder andere Mods richtig wach sind und mein zweiter oder dritter Kaffee drin ist. Vorher habe ich nicht die Muße, mir die zig Meldungen und die letzten Seiten hier durchzulesen…
Edit:
Aufgeräumt, temporäre Antwortsperren verteilt, Thread wieder auf.
@Nelen Danke!
Es gibt ja auch ein paar Leute die haben eine Wasserkühlung extern und führen die Abwärme auch woanders hin ab. Ist aber eher für den Sommer interessant.
Heute könnte echt Mal wieder ne FE dropen.
Zum Thema Wasserkühlung nutze ich nun seit über 20 Jahren .
17 Jahre davon extern da hat ich dann Mal Lust auf einen internen Einbau .
Mit Trennkupplungen ist der Hardware Tausch eine große Erleichterung.
Noch nie so lange die Strix verfügbar gesehen vor allem zu dem Preis.
ich hab mich letztes Jahr von meinen Moras getrennt...
die neuen Karten sind mit UV und guter Curve auch schon extrem leise, das was vor ein paar Jahren unmöglich zu realisieren
dazu nen NH-D15 für die CPU und schon ist es leise genug
Frage mich derzeit welche CPU in Verbindung mit meiner 4090 bei vollem Raytracing in 4k bis 120FPS (117cap) sinnvoller wäre als derzeit ein guter 5800X.
Ich lese immer wieder, dass Raytracing extrem CPU lastig sein soll.
Spiele derzeit The Callisto Protocol und verstehe nicht, warum bei maximalen Raytracing Settings die FPS dermaßen einbrechen zb von 60 FPS auf nur 42 FPS...
Liegt es am schlecht optimierten Spiel oder an der CPU? Ich meine diese Frameeinbrüche kommen auch beim 5800X3D oder 5900X vor... Dann wäre das ja ein rein spielseitiges Problem. Cyberpunk performt alles maxed out eigentlich sehr gut, ich bin zufrieden also müsste das nicht an der CPU liegen.
Wenn sich jemand damit gut auskennt und Spaß daran hat, darf mir da gerne Nachhilfe geben.
Beachtet nur, ich möchte gar nicht über 120 FPS hinaus gehen bei 120Hz LG OLED C1, das reicht mir dicke. Bin auch in den meisten Fällen mit 80-100 FPS in 4k überglücklich mit dem Blick auf den Verbrauch bei Undervolting)) 👍
@Nelen
ich bedanke mich.
nun ich fahre mit einer 4090 FE.
dieses brummen ist für mich normal.
denke ich.. das hatte meine 3080 FE und meine 3090 FE auch.
die 3090 FE war aber erst so am 1400rpm zu hören, also sprich die luftbewegung.
meine 4090 FE hört sich mit 1450rpm genauso an. heißt das nun ich hab ein brummen?
ich denke nicht. würde meine karte auch nicht auseinandernehmen wollen.
Mal eine Frage an die founders Edition User der 4090. Bekomme ich mit dem originalen Nvidia 12 PIN Adapter ein Fraktal Define 4 noch geschlossen oder kann man das Gehäuse nicht mehr schließen weil der Adapter bzw das Kabel nicht so stark gebogen werden darf?
Und an diejenigen die auch bei notebooksbilliger bestellt haben im Dezember beim letzten drop da war doch was gestanden dass man die Karte zurückgeben kann bis 31 Januar? Gilt das nur für ungeöffnete Karten oder auch wenn man die Karte geöffnet und verbaut hatte?
Schau mal in den AGBs. Ich meine mich zu erinnern nur ungeöffnet. Geöffnet die normalen 14 Tage. Oder verwechsel ich das mit Alternate? :d
FAQs von nbb zum Thema "verlängerte Rückgabefrist": Link
Es gelten folgende Bedingungen für die verlängerte Rückgabefrist:
- Dies gilt nur für gekaufte Produkte im Zeitraum 08.11.2022 – 31.12.2022 (hier gilt das Datum der Bestätigung des Bestelleingangs „Ihre Bestellung bei NBB ist eingegangen…“ oder das Rechnungsdatum bei Kauf im Ladengeschäft)
- Die Ware darf nur zu Testzwecken ausgepackt worden sein. Die Ware muss sorgfältig behandelt werden und darf keine Gebrauchsspuren oder Beschädigungen aufweisen.
- Die Ware muss vollständig und in unbeschädigter Originalverpackung bei uns eintreffen. Bei Versand an uns: Bitte nutze für den Versand die Umverpackung, die du von uns erhalten hast.
Für mich klingt das wie für den "normalen" Widerrufszeitraum...
Testzwecke erlaubt
Ähnliche Themen
Antworten
6K
Aufrufe
392K
