[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Hat jemand eine 4090 FE die nur maximal 2715 MHZ taktet? Ist bei mir was defekt oder hab ich einfach mega Pech beim Chip gehabt?
Ich würde sagen, dass das Durchschnitt ist, meine TUF und Gainward haben beide auch "nur" 2715MHz Stock gemacht und die FE ist bei 2740MHz, von daher alles gut :d
Sagt auch nicht soviel aus der Stock Wert, also keinen Kopf machen!
An die Computeruniverse Besteller:
Hat sich Euer Status geändert?
Wie konnte ich auch nur als Gast bestellen?
Hatte Angst, das wenn ich mich groß registriere, die Karte weg ist. :d
ok, welche hat das hochwertigere PCB/Bauteile? :xmas:
Naja also in Punkto Spulenfiepen scheinen ja die Karten mit den billigeren Bauteilen Vorteile zu haben... muss man wissen. :d
Meine taktete exakt genau so hoch. Warum soll das "Pech" sein?
Ja war lagernd aber recht schnell weg.
Danke für die Info, ausgerechnet genau dann wenn ich mir einen Kaffee mache kommt der Drop😅
Nächstes mal dann.
Ihr könnt ja mal schauen ob die verfügbar wird (bei CU). Wenn nicht, dann hatten die sowieso nichts ...
So endlich Bastelstunde
Apropo Kohlen erstattet
Wisst ihr wie lang das bei NBB dauert wenn man eine Karte zurück schickt?
Hab letzte Woche Dienstag retourniert und heute die Bestätigung der Gutschrift erhalten.
Normal. Meine boostet stock sogar nur bis 2700Mhz. Ganz selten mal auf 2715.
Bei TopCashback gibts gerade für Galaxus 10% Cashback und 20€ Bonus ab 399 € MBW
Das wären dann z.B. 1772 EUR für die Manli. Das ist ja fast human. Ist TopCashback vertrauenswürdig?
Scheinbar kann es klappen, oder eben auch nicht :d
Was man so liest funktioniert es bei einigen tadellos, bei anderen wird der Kauf nicht erfasst, bei anderen verschwindet das offene Cashback einfach oder wird storniert....
Scheint etwas Lotterie zu sein :)
Ähnliche Themen
Antworten
6K
Aufrufe
389K
