[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Kann Jemand bitte mal genau erklären wie man was wo einstellt? Nach meiner Kenntnis ist low latency via NVCP nur in DX9-11 Spielen nutzbar. In DX12 Games wenn, dann nur ingame bzw. automatisch ein.
Nein, das Controlpanel wirkt auch auf DX12 Spiele. Allerdings gibt es viele Einstellungen, die für DX12 keinen Sinn machen oder schlicht keine Wirkung haben.
Und wenn Du das für einzelne Spiele getrennt einstellen willst, geht das auch im Controlpanel oder weitaus bequemer im Inspector.
Hogwarts läuft bei mir stabil zwischen 120 und 140 fps, hab die neuste dlss dll eingebaut und noch die Raytracing Effekte verbessert mit dem .ini tweak
Welchen Ini Tweak?
Dieses hier ?
[SystemSettings]
r.RayTracing.Reflections.ScreenPercentage=100
r.RayTracing.Reflections.SamplesPerPixel=1
r.RayTracing.Reflections.MaxRoughness=0.7
r.RayTracing.AmbientOcclusion.Intensity=1
Das gilt aber nicht generell. Wie gesagt bringt ultra low latency via CP nichts bei DX12 Games. Auch der inspector funzt leider nicht mehr so wie früher, gerade was max prerendered frames anbelangt.
Ich schrieb ja, nicht alle Einstellungen funktionieren unter DX12. Das hat nix mit dem Inspector zu run. Prerender hat z.B. keinen Effekt in DX12.
Sieht eher bisschen aus wie Domokun
Ja ich weiß aber auch in DX9 Games oder z.B. ESO etc. funzt prerendered frames nicht mit dem inspector. Orbmu2k hat ja geschrieben, dass da nVidia einiges beschnitten hat. Mal abgesehen vom inspector meine ich halt nur weil hier einige geschrieben haben, dass sie Hogwarts via CP low latency spielen und das bringt halt null weil das Game eine ingame Einstellung hat sprich ein DX12 Game ist.
Naja im Endeffekt benötigt es ja nicht mal FG bei Hogwarts, laut CB (neue Benchmarks von Heute Nachmittag) schafft unsere 4090 + Raytracing Ultra ohne jegliches DLSS 60FPS in 4K:
PS: Es ist ganz schön komplex geworden mit den ganzen Grafik-Einstellungen wie man hier im Forum sieht, überall gibt’s inzwischen Stolpersteine 😏
60fps sind mitlerweile für mich unspielbar geworden. 90fps sind da quasi das minimum :d
zumindest mit maus und tastatur.
wobei sich das beim oled eventuell auch ändern kann. bisher schafft ich aber 90fps überall, wenn auch in HP nur mit FG
Bei meinen Benches vor paar Tagen musste ich die Corsair-12VHPWR-Kabelpeitsche gegen den mitgelieferten 4-Zack tauschen, weil der Spannungsabfall mit 0,5-0,6V viel zu hoch war bei sehr hoher Last
VGPU-Minimum war 11,47V. Mit dem 4-Zack kam ich bei gleicher Last nicht unter 12,06V. Die Benches waren damit stabiler...
Im Zimmer war es recht kalt, aber die Corsair-Kabelpeitsche war gut warm (viel wärmer als Körpertemp)
Wassertemp war nahe dem Nullpunkt. Und die GPU-Temp mit 1,25V im Schnitt bei 38°C (800-850W GPU bzw. 1.150-1.200W gesamtes System)
Zweimal war die Druckseite komplett mit Eiskristallen verstopft (Schlauch zur GPU und der komplette AB) :fresse:
Und das alles für ne Handvoll Frames mehr in Hogwarts :fresse2:
@BlueFireXD
Gibt noch andere, nette Games, wie dieses hier aus 2018
Hat erst mit der 4090 richtig Bock gemacht. Ist aber auch sehr CPU-gefräßig bei Schatten)
Also mit der neuen DLSS 3.1.1 Version die ich drüber gebügelt hab schaut das Bild noch mal etwas sauberer aus würde ich sagen.
Zu Nativ nur ein kleiner unterschied bei der schärfe der Vegetation bei Hogworts .
Das Originale DLSS ist deutlich unschärfer gewesen bin ich der Meinung.
In Dead Space 2 Remake verursacht (bei mir) 3.1.1 extremes ghosting beim Wechsel des Plasma Cutters von horizontal auf vertikal. Original ist dort 2.5.0 ohne ghosting.
Bei den derzeitigen Energiekosten kann man schon mal das Eine oder Andere an "Andere" (uns) abdrücken
Hardware und Stromkosten gespart :d
@kmwteam hat glaube ich nen Job, um Sachen von Anderen zuhause zu Rendern. Nur ist das auf freiwilliger Basis :d
Zu den Kosten des Games von zb 70€ kämen noch "versteckte" Stromkosten für Compling zum Tragen. Klingt verrückt, aber nicht abwegig. Vielleicht mal nachgucken, was die CPU anfangs so treibt
Wenn es um´s Geld geht, haben Manche irre Ideen... :fresse: "Hm - das Spiel lädt aber lange. Ach nee, muss ja erst compild werden" :haha:
Wäre ich eine Software-Schmiede, würde ich euch nur Source-Codes verkaufen. Dann wäre ich reich... :fresse:
Wird zur "Normalität", dass die Software-Schmieden bei uns zu hause fertig compilieren lassen :d
So viel Last braucht der 5950X nicht mal während Hogwarts :fresse:
"Schattierungen werden vorbereitet" klingt diplomatischer, als "Schattierungen werden bei DIR compiled" :d
Also bei mir löst ein Shader Compile eher positive Gefühle aus, auch wenn die CPU kurz hart arbeiten muss und es etwas dauert :ROFLMAO: Dafür kann ich zumindest auf weniger Ruckler hoffen.
Das ist schon krass, was es hier bei den Kabeln und Steckern für Qualitätsmängel gibt. Der Übergangswiderstand des Corsair Kabel wandelt den Spannungsfall direkt in Wärme um.
Nahe unter 0 oder über 0 ?
Wenn über 0, wie können sich da Eiskristalle in einer Flüssigkeit bilden die extrem verwirbelt wird und in Bewegung ist Oo? Ich habe schon häufig bei 0Grad Wassertemp gebenched, aber Eiskristalle sind da nie entstanden, was meiner Meinung nach bei fliesendem Wasser in einem so kleine Kreislauf auch unmöglich ist, es sei denn du gehst unter 0.
Mir fällt gerade auf, dass einige 4090er mit einem Adapter auf 4x PCIe kommen und manche mit 3x? Wenn man die Karte eh mit etwas UV betreibt, brauchts doch eh nicht mehr als 3x, oder?
Rein rechnerisch müssten im Spielebetrieb sogar 2x reichen, oder nicht?
Ähnliche Themen
Antworten
6K
Aufrufe
392K
