[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Sogar mit installiertem WaKü-Block unter 2K. Das lässt tief blicken.
Eigentlich richtig so . Ref. Karten kosten derzeit 1800€ ca. und der Block ca. 160€ .
Daher mal ganz ok so .
Kennt jemand hier einen guten Performance Vergleich der verschiedenen RTX 4090 Partner Modellen?
Willst du oc machen?
Wenn nein wprd ich auf Effizienz gehen ubd die Karte auf 70% pt laufen lassen. Besser geht's nicht.
Hast Du auch schon ein anderes Kabel probiert? Scheint ja manchmal Auslöser zu sein:
Hab ich gemacht, bringt auch nichts.
Gerade von der Arbeit gekommen, Kiste eingeschaltet und nun, Kiste rennt wieder wie wenn nichts gewesen wäre.
Benchmarks laufen wieder Spiele genauso :stupid::hmm:
Versteckte Kamera oder was??
Wenn man auf einer Strix das Asus Soc Bios drauf hat, wird die Karte dann noch unter Arnory Crate erkannt, bzgl. der RGB Steuerung?
So ähnlich gings mir mit dem delided 13900K...
Delid durchgeführt, danach stundenlang gebencht. Am nächsten Tag Sys. eingeschaltet und immer Error 55 bekommen (Sys. lief nur noch mit einem RAM-Modul)
Am darauf folgenden wollte ich das Sys. nochmal zerlegen und den EKWB-DD-Block nachziehen. Hab einen letzten Versuch vor dem Zerlegen gestartet und Sys. lief, wie wenn nie was gewesen wäre
Evtl. musste sie der extrem bucklige 13900K erst richtig im Sockel setzen :fresse:
Bild vom buckligen Die...
Dagegen ist der leicht bucklige GPU-Die meiner TUF quasi "plan"
CPU-PCB war 1:1, wie der CPU-Die gebogen. Da hat man echt Schiss den Block festzuziehen :rolleyes2:
Nvidia CEO Jensen Huang bereitet sich auf weitere 30-40 Jahre im Amt vor:
Frostbite für 1.999,90 Euro:
Hat bei dem Shop schonmal jemand was bestellt? Firmensitz in Dänemark...
Dito. Keine Probleme. Auch eine Retoure ging problemlos, sie ziehen Dir aber das Porto von der erstatteten Summe ab (für mich ok)
jupp, machen sie.
Probleme ansonsten keine, Anfragen und ähnliches via Email lief in Deutsch falls das wichtig sein sollte.
Bei mir gab es damals Lieferschwierigkeiten mit einem Artikel, da kam auch fix ne Email um über Probleme aufzuklären
Alles klar Danke.
Dann werde ich mal schauen ob die nochmal ne Frostbite reinbekommen.
Da ist er nun also, der Cablemod Adapter
wie lange hast Du gewartet?
Aber so ist der Anschluss doch auch wieder belastet 🤔
recommended by Jensen :fresse:
or by Hornbach :haha:
Ich war mit der B-Ware bei Mindfactory bisher immer zufrieden.
Kann sich halt auch um verpackte refurbished Ware vom Hersteller handeln. Mindfactory zahlt ja auch gerne mal den Zeitwert aus und macht die RMA selber.
Bezüglich MSI hab ich mit meiner Vega 64 damals zwei mal Ausälle gehabt und die kam aus der RMA mit verbogener Slotblende und WLP auf den PCIe Kontakten zurück. Seither möchte ich keine MSI mehr. :)
Edit: Jetzt kostet sie 1799.-
ach komm schon, da gehört ganz klar ne weiße strix rein :hust:
Zu teuer, für meine krieg ich aktuell noch was.. 1600 vielleicht? Und dann 700 Aufpreis fast auf die weiße Strix? Lohnt nicht
NV-Treiber bzw. das OS können manchmal so nervig sein...
Wollte zum Testen einen älteren Treiber installieren, den ich übers Netzlaufwerk von einem anderne PC geladen hab
Ich konnte garnicht so schnell installieren, wie WIN11 im Hintergrund einen neueren Treiber installiert hat :fire:
Nach 3 erfolglosen Versuchen hab ich den gewünschten Treiber rüberkopiert und das LAN-Kabel gezogen, bevor ich DDU laufen ließ :rolleyes2:
Genau bei der anfänglichen Installationsroutine wurde der neue (nicht gewünschte) Treiber installiert. Sowas hab ich noch nicht erlebt :fresse:
B-Ware steht für das englische Wort "beware" und bedeutet "in acht nehmen" :haha:
Ähnliche Themen
