[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Er müsste ihn fragen, ob er die 4.600€ in Bar bekommt, um sich was Feines zu kaufen
Warum sollte er? Wenn das Teil neu für 6,3 K drin steht bekommt er doch sicher genug Kohle wenn er ihn gebraucht weiter vk.=) Er muss halt nur das selbe Gehäuse kaufen......Wer das verschenkt hat, hat bestimmt weniger Ahnung als er (sonst hätte die Person das z.B. bei MF zusammenbauen lassen, mit besseren high Speed Teilen.
War ein richtiges, überhyptes Müll-Game… Hauptquest war okay. Aber der Rest nahezu einfallslos.
Am Anfang wird man von der Inszenierung, dem Kampfsystem und den HDR-Effekten geblendet, anschließend merkt man, was man für einen langweiligen Woke-Brei spielt. Gerade die langweiligen Nebenquests, 100 Merlin-Trials und das ständige Schlösserknacken sind absolutes Pfui.
Ich habe das Spiel zusammmen mit meinen Kindern auf der PS5 durchgespielt und wir hatte eine Menge Spaß, gerade in der dunklen Jahreszeit wo man am WE eh nichts mit sich anzufangen weiss.
Eigentlich wollte ich das Spiel nach der Hauptquest verkaufen, aber das lassen die Kids nicht zu. Erst wird die Hauptquest mit allen vier Häusern gemacht und die Nebenquests wollen auch noch erledigt werden.
Die 60€ haben sich mal so richtig gelohnt.
Wahrscheinlich weniger als 4,6...
Aber ich kenne die Omen-Gebrauchtpreise auf EKA leider nicht :d
Wireview gibt es ja leider noch nicht für 16-Pin :/
Wurden schon Preise dafür genannt und war da auch was mit Software zum Auslesen?
Das Teil ist eig. nett, aber auch nicht so flexibel einsetzbar
Mein "PMD" war quasi "umsonst" (100% Erstattung), weil er nicht so einsetzbar war, wie vorgesehen. Nach paar Lötarbeiten jedoch schon.
Ein Austausch machte leider keinen Sinn wegen den hohen Versandkosten
das ist leider richtig, kommt aber hoffentlich bald, dauert wohl länger, da es auch länger halten soll :d
70 teuronen bei Caseking, und mir war auch so mit software aber momentan wohl nur ein interner speicher und aktuelle Anzeige von Werten, wie ich es verstehe
Hm, schade...
Ich betreibe die Software des PMD an einem kleinen Netbook, also völlig autark getrennt vom PC
Aber teilweise offene PCBs mag auch nicht Jeder. Ist aber auch nicht dafür gedacht, dass man es 24/7 so betreibt
Ich finde das Video gerade nicht, aber Roman hat irgendwo erzählt, dass das ein ganzes System werden soll und man die Dinger auch irgendwann mit einer Art Zentrale verbinden können soll.
Wobei ich mich aber ehrlich gesagt nur wegen des optischen Effekts dafür interessiere, das Auslesen des Verbrauchs über Hwinfo ist im Alltag völlig ausreichend.
Joh, HWinfo reicht, wenn es kein Custom-BIOS ist, das worst case extreme Abweichungen zum realen Verbrauch anzeigen kann
kleine conclusion meinerseits:
gpu
-die nvidia systemsteuerung war wohl buggy. nach einer neuinstallation sind alle fps probleme verschwunden (y)
-speedway benchmark misst jetzt tatsächlich gute werte. easy in den top 10 mit den stock clocks. oc weiterhin möglich.
cpu
-zufriedenstellende scores im bench
-limitiert durch HP settings, konkret das current/edp limit
dieses kann DOCH im uefi overclockt werden, allerdings muss die freischaltung mit code im uefi und im gaming hub bestätigt werden und wird an HP übermittelt-> warranty gone :censored:
ram
die 64g 7200mhz xmp 38/44/44 anstatt der 64g 5200mhz xmp bzw stock 4400mhz non xmp bemerke ich gefühlt nicht wirklich im gebrauch. -> werden aber tatsächlich vom stock setting akzeptiert und unterstützt.
ich bedanke mich für den klasse support hier :bigok:
famous last words:
rechner geht jetzt an meine kleine schwester.
ich werde mir ein custom zusammenstellen.
Wundert mich das 7200 @ Vollbestückung läuft.
famous last words:
Nur so aus reiner Neugier:
Welche Preisklasse schwebt dir da so vor? Ab 5-10k? Das wird bestimmt ein wahres Monster, nenn mal die Specs sobald du dich entschieden hast.
PS:
Am Anfang hast du dich selber als Voll Noob bezeichnet, deine Posts haben dann aber doch sehr fundiertes Wissen aufgezeigt.
Warum hast du dich selber so überaus schlecht dargestellt im ersten Post hier?
Denke mal er hat sich vertippt und meinte 5200Mhz, denn das soll laut der HP Seite verbaut sein.
Denn 7200Mhz mit Vollbestückung (4x 16GB) sind mit sehr hoher Wahrscheinlichkeit nicht möglich. Und ein solches Kit (egal ob 2x 32GB oder 4x 16GB) gibt es eh nicht am Markt.
Warum sollte der 7900x3D unter den Preis des 7800x3D fallen, um interessant zu sein? Versteh ich nicht.
Den 7900x3D gibt es sogar ab und zu gebraucht unter der UVP des 7800x3D. Finde den interessant.
wer zockt greift zum günstigern und leicht besseren 8kerner
wer die kerne braucht weil er professionell damit arbeitet, dem sind die 150€ aufpreis zum 16kerner völlig egal
@Scrush
mag alles sein, macht aber die ursprüngliche Aussage nicht besser. Dass ein 7900x3d preislich unter einen 7800x3d fallen soll, um interessant zu sein, verstehe ich immer noch nicht.
weil er weder fisch noch fleisch ist.
ein 7600x3d für 300€ wäre nice
aber kein 12kerner bei dem die hälfte der kerne däumchen dreht, der 3d cache nur auf einem ccd sitzt und teurer ist als der 7800x3d. für professionelle uninteressant und für den zocker im vergleich zum 7800x3d komplett unattraktiv da der 7800x3d ja günstiger ist.
die cpu ist damit überflüssig^^
an sich ist die cpu gar nicht schlecht. 6 kerne mit 3d cache top und nochmal 6 fürs streamen? ja das wäre passend aber das wars dann auch schon.
war mir auch so, nur momentan schaut es danach noch nicht so aus :(
Das ist so Schubladendenken. Alles muss irgendwie einer Kategorie entsprechen. Nicht so mein Ding.
Kurze Frage: Habe ein Bequiet! 850W Straight Power 11 Platinum Netzteil. Dieses verfügt über 3 PCIe-Lanes. Ist es ok an den Adapter 2 Einzelkabel (jeweils eine Schiene) und für den Rest ein geteiltes Kabel über eine Schiene anzuschließen?
Grundsätzlich ja, ist ok.
Im schlimmsten Fall geht der PC einfach aus, weil die Sicherung des NTs triggert.
Neuere Netzteile sind da oftmals im Vorteil (neu = ab ungefähr 2018).
Ansonsten kannst du die Karte noch undervolten oder Powertarget absenken.
Aber rechne erst einmal damit, dass es problemlos funktioniert.
Ok dann werde ich das so erstmal probieren. Netzteil ist von 2020 und wäre doof jetzt schon wieder zu tauschen zumal ja 850W mit einer 4090 und einem 5900x reichen sollten. War mir nur nicht sicher, ob ich problemlos zwei Einzelschienen und und eine geteilte Schiene anschließen kann.
2 kabel ins nt. und dann ab in die gpu
müsste auch auf der website stehen, aber ich glaube, dein 850er ist das erste aus der sp serie für welches das kabel funktioniert. hab das 1200er und das läuft dort einwandfrei.
lies dich auf der website mal ein :)
kompatibilität:
rtx 4090 ≥ 850W
rtx 4080 ≥ 750W
mit dem kabel machst nix falsch :wink:
btw: ob der post das spezifische kabel meinte, weiß ich gar nicht :shot:
kompatibilität:
rtx 4090 ≥ 850W
rtx 4080 ≥ 750W
Hört sich gut an, aber da muss ich mal mit der Höhe gucken ^^Das darf ja nicht gebogen werden.
Ähnliche Themen
Antworten
6K
Aufrufe
392K
