[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Die Lovelace Karten sind echt riesig. Die 3090 vorher sieht aus wie eine GT 1030 :d
Äpfel und Birnen und so? :fresse:
Leg mal ne Frostbite neben die 3090.
Gute Idee für deinen nächsten oc record :) besonders im Winter wenn dein Teich zugefroren ist.
Nix Teich. Ich seh schon die ersten den Waschzuber ins Gaming Zimmer schieben, Gartenschlauch und Eiswürfel stehen parat. :fresse:
Ja, das ging mir genau so, musste echt zweimal hinschauen wie gut das alles lief plötzlich.
Falls jemand Hitman 3 und eine Zotac, PNY oder andere 450W Limit Karte hat, könnt ihr mal 4k mit RT laufen lassen und sagen wie viel sich die Karte zieht? Gerne auch den Benchmark laufen lassen und Werte posten.
PNY 4090
89.75 FPS
Benchmark Dubai
Karte zog im Schnitt so 415 Watt
Hier die Settings
Da hätte ich schon längst DLSS eingeschaltet.
Sinkt dann eigentlich auch gleichzeitig der Stromverbrauch?
@Gurkengraeber
Warum geht deine Karte bis 500 Watt?
Meine PNY ging nur bis 420Watt und fing dann an runter zu takten
Hitman3 belastet die Karte aber auch nicht sehr stark im Verhältnis z.b zu Quake2 RTX :)
Für die Neuankömmlinge, auch ein FPS Limit sorgt für einen niedrigeren Stromverbrauch, bringt teilweise sogar mehr als Undervolt. Eine Mischung aus beiden ist wohl das Optimum.
Weil die Strix standardmäßig 500W PL hat und bis 600W hochgedreht werden kann, die PNY hat nur 450W und kannste nix dran drehen.
Ah Sorry. Dachte er hätte auch eine PNY 👍🏻
FPS Cap bei der Refreshrate vom Monitor setzen.
Glättet zusätzlich noch die Frametime 👍🏻
bis jetzt nur ein Gerücht: "Wie der bekannte YouTube-Kanal "Moore's Law is Dead" in seinem vor wenigen Stunden erschienen Video berichtet hat, soll Nvidia die Produktion seiner aktuellen Gaming-Grafikkarten aus der Serie Geforce RTX 4000 zugunsten seiner weitaus profitableren KI-Beschleuniger mit Hopper-GPU zurückgefahren und so beinahe vollständig eingestellt haben. "
Vermutlich gilt das für die FE. Die Boardpartner werden sicher wie sehr sicher vertraglich vereinbart ihre Chips bekommen…
Heute meine 4090 bekommen.
Palit GameRock -> 1.07V Lock also wohl die neue Revision der Karte.
Leider kann ich darauf auch keine neuen Bios flashen für ein größeres Powerlimit, bzw finde ich keins.
Leistung mega, frage ist jetzt nur behalten oder eine andere kaufen für die 1,1V
Wie schon vorher viele gesagt haben, wenn du einfach nur Gamen willst, dann behalten. Die MSI vom Kollegen machte mit 1,07V 2985Mhz, meine Beste MSI machte mit 1,1V 3175Mhz hat dafür über 2 Räume hinweg die Spulen jaulen lassen. Für 6% im Benchmark würde ich das nicht ertragen wollen und würde mich immer für die schlechtere mit leiseren Spulen entscheiden. Darum werkelt hier im Hauptrechner auch noch ne Gamerock non OC.
Beste Grüße
Vor allem wenn man nur gamen will und an OC nicht wirklich derart interessiert ist, macht es wirklich keinen Sinn, zumal die 4090 auch noch easy zu untertakten ist ohne nennenswert an Leistung zu verlieren.
Man muss sich nur mal die Ergebnisse hier im ersten Beitrag anschauen und irgendwo sind auch 3D Mark Ergebnisse: https://www.hardwareluxx.de/community/threads/nvidia-rtx4000-undervolting-sammler.1325830/
Wenn man also nicht wirklich jedes bisschen Leistung braucht muss man sich darum echt keine Gedanken machen.
Richtig vorwärts wird es erst wieder mit der Matrix gehen und dem Voltmaster :LOL:
Auf die Matrix freue ich mich auch aber wer mit der Grafikkarte nur zocken will, dem reicht wirklich die günstigste und leiseste Karte, da die Leistungsunterschiede im max. einstelligen Prozentbereich liegen. Die 4090 ist in den meisten Fällen derart schnell, dass es wirklich kaum einen Unterschied macht, da die Leistung oft gar nicht ausgereizt wird/werden kann. Bin auch dieses mal echt nicht sonderlich auf die Ti/Titan gespannt aber mal abwarten, wenn der Release näher rückt, wie das Interesse bei mir steigt xD.
Ähnliche Themen
