[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Warum brennen die Cable Mod Adapter ?
Was haben die falsch gemacht ?
Ich glaube das Problem ist halt einfach immer noch, dass die Stecker zu 100% korrekt sitzen müssen. Wenn ich nun ein normales Kabel dranstecke, kann ich das einfach überprüfen. Bei den Adaptern ist zum einen die Sicht versperrt, zum anderen sind sie halt sehr groß und verrutschen bzw. bewegen sich leichter, gerade in kleinen Gehäusen (wofür sie ja oft gekauft werden).
Also meiner persönlichen Meinung nach (ja, ist wirklich nur meine) kommen viele einfach nicht mit diesem Stecker klar. Sie sind einfach zu dämlich bzw. schaffen nicht die richtigen Voraussetzungen (zu kleines Gehäuse), um diesen Stecker richtig nutzen zu können. Ja, das Ding ist nun mal nicht mehr so einfach bzw. für die DAUs da draußen konzipiert. Und nein, m.M.n. muss das auch nicht sein. Man könnte wohl von jedem, der einen PC zusammenschrauben kann erwarten, dass er einfach prüft ob das Ding fest sitzt. Bzw. das Gehäuse so dimensioniert, dass alles genügend Platz hat ohne zu verrutschen.
Aber nein, es müssen ja irgendwelche schwachsinnigen SFF/4090 Combos genutzt werden weil irgend ein Techtube Honk das so schön bei sich zum blinken gebracht hat. Oder man muss einen tollen grünen riesen Adapter für 60€ :ROFLMAO: aus den USA bestellen anstatt ein 20€ Kabel zu nehmen weil... keine Ahnung... weil einem jemand ins Hirn geschissen hat.
Und dann wundern sich die Leute wenn ne Karte die bis zu 500W zieht abraucht.
Also ich kann über die ganze Steckerthematik weiterhin nur lachen und habe Null Mitleid mit denen, denen eine Karte über den Jordan gegangen ist. Schafft einfach die richtigen Voraussetzungen, prüft ob das Teil richtig drin ist (und das nach jeder größeren Bewegung des Gehäuses) und dann habt Ihr Ruhe. Sollte Euch bei 100% fest sitzendem Adapter ein Stecker schmelzen, dann könnt Ihr die Garantie in Anspruch nehmen.
Habe auch kein Mitleid mit Cablemod, aber auch hier kann ich nur sagen: einige haben einfach den 12hvpwr Führerschein nicht geschafft und machen jetzt das Auto für den Unfall verantwortlich. Die Bremsen waren aber ok auch wenn man n bisschen fester hätte drauflatschen müssen. In den USA hätten evtl. Klagen wahrscheinlich leider wirklich eine Chance, hierzulande würde jeder halbwegs vernünftige Anwalt den Boden damit wischen.
It just burns wohl eher.
wenn dann schon "it just melts". Mir ist wirklich bis heute kein echter Brand bekannt. Rauchen, stinken und schmelzen ist bekannt.
Die originale Peitsche war auch echt knorpelig beim einstecken. Aber das Seasonic/Asus Kabel fühlt sich richtig gut an beim Einstecken. Nicht wabbelig und auch nicht knorpelig. Und es sitzt gut. Ich habe nach fast anderthalb Jahren und zich Steckvorgängen wirklich keine Angst mehr. Den sauberen Sitz kontrolliere ich natürlich jedesmal. Klar, leichtsinnig muss man nicht sein. Aber die ganzen Brand, Feurio und so weiter Meldungen finde ich persönlich mittlerweile übertrieben. Solange ein ordentlicher Stecker ordentlich eingesteckt ist.
Also ich hab jedenfalls meinen Adapter zerstört und hol mir die 60 Dollar von Cablemod retour, bei mir hat das Teil problemlos funktioniert bis ich mir aus ästhetischen Gründen ein 90 Grad Kabel geholt hatte. Glaube echt dass hier bei den meisten ein Usererror dahintersteckt, auch wenn ich Cablemod nicht gutreden möchte
cablemod will ja ein Bild haben - hast Du mit dem Hammer drauf gekloppt und das fotografiert und bei cablemod im Formular hochgeladen?
Was für'n Bild wollen die haben? Rechnung reicht nicht? Offizieller Rückruf bedeutet sie müssen jeden zurück rufen, auch die funktionierenden.
Auf deren "Recall" Seite steht:
"Please upload a photo of your disabled angled adapter(s) here:"
Zumindest bei deren Kabeln ist es so, dass wenn du ein Problem damit hast und du ein neues forderst, sollst du das alte Kabel zerschneiden und denen davon ein Bild senden. So gehen die sicher, dass du nicht einfach so ein gratis Kabel abstaubst obwohl das bestehende Kabel keine Probleme macht oder wenn du tatsächlich ein defektes Kabel hast, dass es nicht weiter verwendet werden kann.
Ah ok, ätzend aber verständlich. Nur sieht die Sache hier halt etwas anders aus, da eben offizieller Rückruf. Weiß jetzt nicht ob sie den Rückversand verlangen (international müssten sie zumindest die Versandkosten übernehmen), aber sie müssen Euch in jedem Fall den Kaufpreis erstatten oder funktionierenden Ersatz liefern.
Dazu steht in der News:
"Die Verbraucher werden gebeten, den Adapter zu zerstören und ein Foto des zerstörten Produkts auf https://cablemod.com/adapterrecall/ hochzuladen."
"Die Verbraucher sollten sofort aufhören, die zurückgerufenen Winkeladapter zu verwenden und sich direkt an CableMod wenden, um Anweisungen zur sicheren Entfernung ihres Adapters und eine vollständige Rückerstattung, einschließlich der Versandkosten, oder eine Gutschrift für nicht angepasste Produkte in Höhe von 60 US-Dollar zu erhalten."
interessantes neues tool, was hoffentlich bald online gestellt wird ;)
Nabend zusammen, hab mal ne kurze Frage zu meiner MSI 4090 Suprim Liquid X: laut einiger Test die ich gelesen habe, kann man das Powertarget auf bis zu 530W erhöhen. Ich kann bei mir zB. im Afterburner nur 100% also 450W einstellen. OC-BIOS ist aktiv. Hat jemand n Tipp? Ist die neue Version mit SN Aufkleber unten in der Ecke.
Die sollte 520W haben. Bist du sicher, dass der BIOS Switch korrekt eingestellt ist und du den aktuellen Afterburner installiert hast?
Dump mal nvidia-smi.exe -q -d power
Sollte so aussehen:
Weird. Lies doch mal die BIOS Version aus, ist es ein neueres als die hier aufgeführten Varianten?
Oha, ja das ist tatsächlich ein neues BIOS, wobei auch das laut hier eigentlich 530W haben soll. Sehr verwirrend.
Ich denke du könntest eine der älteren Versionen flashen, angesichts des Dual BIOS ist das auch recht gefahrlos. Allerdings stellt sich die Sinnfrage, nur für den Gamingbetrieb würde ich es nicht machen, da man mit höherem Powerlimit gar nicht viel gewinnt, außer man hat eine goldene GPU die wahnsinnig Takt macht.
Mit was für einem 12VHPWR Kabel ist die MSI 4090 Suprim Liquid X angeschlossen? Was für ein Netzteil?
Beste Grüße
Ja finde ich auch. Also richtig wichtig ist es mir nicht, aber ich hab mich einfach gewundert. Da kauft man schon ne teure Karte, haut ne Costum Block drauf und dann kann man den Regler nicht schieben :( :d Über einen Flash hab ich auch schon nachgedacht, natürlich nicht fürs Gaming aber für den ein oder anderen 3D Mark run halt. Danke schonmal für deine Hilfe :)
Beste Grüße
Mit dem Adapter aus der MSI Verpackung. Netzteil ist ein Enermax Revo D.F. 1050W
Und es sind auch alle 4 Anschlüsse bestückt? Kenne das Verhalten eigentlich nur wenn der Adapter nicht vollständig Bestückt ist.
Beste Grüße
Guter Hinweis, das kann es sein. Nicht daran gedacht, dass manche diese Kabelpeitsche echt verwenden :d
Ne tatsächlich nicht, sind nur 3/4 angeschlossen. Dachte nicht, dass das einen Unterschied macht, da die ganzen Zubehör Adapter auch nur meist 3 Kabel haben. Werd ich nachher mal ausprobieren.
Hab leider noch keine Alternative gefunden. Für mein Netzteil gibt es leider kein natives Kabel und bei den Adaptern bin ich skeptisch :d
Wollte eigentlich so einen hier holen
Naja das ist auch eine Besonderheit die allein dieser offizielle Nvidia Adapter hat, um auf Gedeih und Verderb die PCIe Spezifikation für jedes denkbare Gurken-NT einzuhalten. Die Drittanbieter Adapter setzen einfach den Sensepin auf 600W und gut ist :fresse:
Immerhin, Fehler gefunden :d
Wo ist der rolleyes Smiley? Ich würd mich gar nicht trauen das Teil zu betreiben ohne alle Anschlüsse anzustecken.
Und Enermax hat doch Kabel?
Naja für 450W reichen die 3x 8Pin Stecker ja locker, von daher drei ran und gut. Und wenn man andere Adapter anschaut, haben die auch nur 3x8 Pin Anschlüsse.
Habe beim Enermax nachgefragt und das Kabel ist offiziell nicht mit meinem Netzteil kompatibel und in DE kann man es nicht kaufen.
Eben nicht. Roman hatte es in einem Video gezeigt und ich habe es selber mit dem Corsair Kabel erlebt: es steckt wunderbar, aber wenn du minimal dran wackelst. Dann siehst du anhand der Status Led am Stecke, das sie sich auch nur bei minimaler Bewegung vom.status "alles gut" zu "keine Verbindung" wechselt. Der Stecker ist dabei bombenfest und korrekt drinnen. Man sieht es definitiv nicht.
mal ne Frage in die Runde, gibt ja sicher den ein oder anderen der das Game schon gezockt hat, möchte die Tage mal mit Alan Wake 2 beginnen, schafft die 4090 das alles auf Anschlag in 4K ? falls nicht, was wären optimale Settings für ne 4090 bei Alan Wake 2 um die bestmöglich Qualtität bei 60 FPS in 4K rauszuholen ?
Ja mit DLSS und Framegen kann man das Game auf Anschlag spielen mit Pathtracing und alles. Sehr geiles Game, ist in meinen Top 3 letztes Jahr. Ich habe DLSS Performance gewählt und hatte so in den Saga Abschnitten 80-100fps und in den Alan Abschnitten fast immer 116fps (Habe die FPS hier gelockt).
Ähnliche Themen
Antworten
6K
Aufrufe
392K
