[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
habe 6Tb SSD + 22TB Externe HDD . Deinstalliere daher wenig :LOL:
Hallo in die Runde.
Da ich in ein Paar Tagen auch eine RTX 4090 @ WaKü haben werde (gebraucht gekauft, umgestiegen von einer RTX 3090 unter Wasser) wollte ich mal nachfragen wie ihr alle ihre RTX 4090 unter Wasser laufen habt.
Wie genau habt ihr die U/Power Kurve im Afterburner eingestellt. Habe mich schon sehr lange damit nicht beschäftigt.
Danke für euren Input!
Bisher 0,95V bei 2730MHz. Dafür hab ich +255MHz im Afterburner eingestellt und dann alle Punkte der Kurve danach runtergezogen.
Mittlerweile bei 1,1V und 3045MHz. Selbe Vorgehensweise.
Die meisten Karten dürften so um den Dreh mitmachen.
Ob Wasser oder nicht hat bei mir keinen Unterschied gemacht. Der FE Kühler macht einen guten Job.
was bekommt man zZ für eine fast neue 4090 Aorus? (wenig Spulenfiepen)
2300-2500 in der Bucht
Gestern wurde ne 4090 TUF OC für 2300 verkauft. Werde meine TUF non OC auch für 2300 rein setzen mit Preisvorschlag.
Kingdom come Deliverance 2 ist heute erstmal angesagt.
Gold Edition ist schonmal geordert und vorgeladen.
Tja ich glaube ich bin bald einsam hier im 4090 Thread. :d
Die 4090 hat das potential ein tolles Sammlerstück zu werden.
Irgendwie zu schade zum verkaufen, aber klar gibt anscheinend genug die richtig Geld dafür hinlegen.
So schnell wird das mit der Einsamkeit nichts bei dieser extrem miserablen Verfügbarkeit der 5090…
Ich rechne eher mit März das ich an eine 5090 TUF (non-OC) zur UVP komme.. wenn überhaupt. Könnte auch locker April werden.
Habe pünktlich heute D4 VoH durchgehockt und bin nun auch bereit für KCD2 🥳
Bin eigentlich irgendwo bei Stalker 2 dran, aber das Spiel lasse ich noch reifen.
Daher bin ich jetzt fleißig KCD2 am spielen.
Macht einen Sau Guten Eindruck und die Grafik 😍 und wie gut es läuft 🤩
Stalker 2 ist evtl nach KCD2 und Avowed dran, will das so weit nach hinten schieben wie es geht.
So lange ich Games habe die ich dazwischen schieben kann umso besser.
Hey zusammen,
ich habe noch eine 4090 Founders Edition in einem Gaming PC der aktuell kaum genutzt wird.
Würdet Ihr versuchen diese in der Bucht abzustoßen und dann dort eine 5080 einbauen?
Der PC dient eher als PC für die Dame / Besuch.
Von der 4090 auf eine 5080 wechseln? Keine gute idee, wieso sich freiwillig verschlechtern?
Und einen Gaming PC mit 4090 hast du für die Frauen? WTF? Hört sich irgendwie lustig an. 🤣
Ich habe die Jahre immer meine alte Hardware bei meine Freundin eingebaut. 1080ti, 2080ti, 3090 FE, usw. :-)
Der PC wurde dann teilweise von Ihr aber oft von Freunden genutzt :-)
Aber wenn du sagst, die 4090 FE ist besser als eine 5080, dann lass ich das so.
es gibt eine neue orbmu2k nvpi version 2.4.0.9. find ich gut, dass das nochmal aktualisiert wird👍
dort sind nun überarbeitete DLSS, HDR und auch für die 50 series nutzer smooth motion settings eingefügt worden, ist nun recht übersichtlich find ich.
Die 4090 ist allein schon durch die 24GB VRAM besser. Aber ist eh die Frage ob du so viel VRAM auch ausnutzt. Spielst du in 4K und legst wert auch hoch Grafik Qualität, dann sind 24GB VRAM schon nicht schlecht.
Wenn mal gespielt wird, dann auf einem Asus PG32UQ.
Dann lass ich es einfach so, hab nur gesehen das man die 4090 aktuell für absurde Preise verkaufen kann.
Dachte das die 5080 wegen der neuen Generation dann auch besser ist.
Danke euch.
Seit gestern auch drin, läuft ganz gut auf einer 5080, einige Sachen wie Texturen auf "experimental", sieht super aus und ist anders als Stalker auch mit weniger FPS ziemlich smooth :bigok:
Die 16GB der 5080 sind in 4K DLSS Q kein Problem btw (y)
Ich bleibe meiner 4090 auch treu :-)
Die 5080 ist für mich kein Upgrade im klassischen Sinne (MFG reizt mich nicht) und der Leistungssprung der 5090 preislich uninteressant.
Außerdem zocke ich eher selten leistungshungrige AAA-Titel und wenn, dann gerne auf meinem Sony W900 in 1280x800@85Hz. Da kann ich in Cyberpunk trotz Pathtracing DLAA nutzen, dementsprechend sollte die Leistung 4090 noch locker bis zur nächsten Generation reichen 😁
Als nächstes wird KCD nachgeholt und anschließend Teil 2 gezockt.
Neue Karte wird erst ab 100% Leistungszuwachs (ohne Spielereien wie MFG) in Betracht gezogen.
Dieses Jahr stelle ich mir dann lieber einen der demnächst erscheinenden 500Hz OLEDs hin.
Aber viel gibt es zu so einer "alten" Karte halt nicht mehr zu bereden 🤪
Das Spiel ist aber wirklich sehr gut entwickelt worden. Das ich sowas bei einem Open World Spiel in dieser Form erleben darf freut mich. Ein rundes Paket.
Ja 4K DLSS4 Q und alles Ultra und Texturen experimental und bleibt größtenteils sogar in 3 stelligen FPS Bereich. Minimum waren 80 FPS wo man mit Hans verletzt durch den Wald ist zur alten Frau und diverse Szenen kamen. Und ja fühlt sich sehr gut an. Auto HDR sieht auch gut aus. Habe nicht einmal mehr mit RTX HDR probiert, weil bin mit dem Ergebnis zufrieden.
Ansonsten ja nach über 4 Stunden Spielzeit war ich auch unter 16GB Vram geblieben.
Tolles Spiel bisher und was für eine KI.
Falls einer was sagt wie Blätter und Blumen aussehen. Ja habe ich auch schon besser gesehen, aber der Gesamtbild Eindruck ist umwerfend und wie auch Gesichter aussehen und die Haut. Also das ist stellenweise so detailliert . Genial 🤩
Ansonsten bei Spacemarine 2 mit dem 4K Texturpaket dürfte 16 GB Vram eng werden.
Die 4080er hatten da schon mikroruckler wo es hingegen mit der 4090 sauber lief.
Das sind dann halt extrem Beispiele.
Fande halt Spacemarine 2 mit 4K Texturpaket auch sehr schön.
Gibt es mittlerweile eigentlich ein vernünftiges 90 Grad 12V 2x6 Kabel in Weiß gesleevt?
Hab meine auch für 3000 drin, will aber keiner. Bekomme nur ständig fragen was denn mein Mindestpreis sei. Ja 3000 Eier, steht doch da.
Ich stelle immer wieder fest, das Problem sind nicht die Verkäufer :bigok:
Wenn Trump morgen noch ausruft, dass er gerne ein Stück Land in Taiwan hätte um dort nen tollen Golfplatz zu bauen, könnte das ein realistischer Preis werden :d
Ähnliche Themen
Antworten
6K
Aufrufe
350K
