[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Und wer zu wenig Kontrolle über DLSS und Co im Spiel hat, der wird hier mit Einstellungen erschlagen, fügt ein Ingame Menü ähnlich wie Reshade ein mit zahlreichen Einstellungen zu DLSS, FG etc.
Die Version vom NvidiaProfileInspector hat bereits für DLSS ein Profile K statt J, aber noch keine Ahnung wo der Unterschied ist. :d
D.h. damit DLSS4 ohne den Käse funktioniert müssten die Hersteller das nativ implementieren? Ist mir glaub zu nervig das über den Treiber zu machen, hoffe das ist einfach nur buggy und wird noch gefixt.
Also erstmal werden 75 Spiele offiziell unterstützt. Nehme an das hat damit zu tun, dass die Nvidia App die Speicherorte der Spiele kennt. Im Endeffekt macht es nichts anderes als das was manuell auch manche gemacht haben. Überschreibt einfach die DLSS Dateien der Spiele. Vorteil ist wenn der Entwickler das nicht macht und ein Patch kommt werden die DLSS Dateien wieder überschrieben, aber hier überschreibt dann wieder der Nvidia Treiber die DLSS Dateien.
Will man wieder die alten DLSS Dateien, dann geht man hin deaktiviert die Option und prüft die Integrität des Spiels bei Steam und die DLSS Dateien sollten wieder überschrieben werden. Für mich ist das mit der Nvidia App etwas Kompfort welches man vorher nicht hatte.
Ansonsten eine Sache die ich viel interessanter finde ist das man bei den Games die kein DLAA hinterlegt haben hier dann über die App DLAA aktivieren kann.
So zumindest mal die Theorie. Mal sehen wie das alles läuft. Bin noch bis 22 Uhr auf der Arbeit und werde nachher selber mal testen.
Habe auch RTX HDR getestet und das läuft auch alles nicht 100% so wie ich mir das vorgestellt hab. Deshalb mal schauen. Werde mal es bei einem meiner Steam Games dann probieren.
Ja im Prinzip geht man mit der Nvidia App einen guten Weg. Es bedarf noch paar Verbesserungen und ansonsten der Curve Editor für das UV/OC direkt integriert in der Nvidia App wäre schon fein und halt die Clock Einstellungen für den RAM. Ein paar Sachen sind schon integriert. Mal sehen ob das auch irgendwann mal kommt. Dann braucht man auch kein AB mehr.
  • As of January 30th, 2025, the “Latest” model for DLSS Super Resolution has been updated to Transformer "Preset K", a minor refinement to Transformer Preset J, which showcases improved temporal stability, reduced ghosting, and enhanced detail in motion. Let us know what you think!
  • The “Latest” model for Ray Reconstruction continues to use Preset J
quelle: https://www.nvidia.com/en-us/geforce/news/nvidia-app-update-dlss-overrides-and-more/
Ja, das mit automatisch optimieren hab ich noch nie genutzt und mag ich auch nicht. XD
Vielleicht findet ja noch Jemand über den NVidiaInspector einen Weg das freizuschalten ohne automatisch optimieren aktivieren zu müssen?
Bei mir war, mit dem neuen Treiber und der App, die Optimierung für alle Spiele an. Das habe ich komplett deaktiviert.
Danach soll man die Spieleliste in der App aktualisieren (die 3 Punkte oben). Danach läuft die DLSS-Überschreibung wie sie soll.
Man kann auch die Profile bis J auswählen.
Sykrim VR mit DLSS 4 ist mega!
F1 24 auch viel viel besser in VR mit DLSS 4
Witcher 3 auch besser
Nö, nichts bei mir. Gerade die neusten Treiber installiert per neue Installation statt Update. Immer noch nicht verfügbar.
ich hatte ein App Update, habe den Treiber aktualisiert... dann die App geschlossen nochmal geöffnet, dann wurde noch ein App Update installiert, jetzt sind die Settings da.
Ja bei mir ist das DLSS override da aber es funktioniert sehr eingeschränkt und mit Inspector geht es ja Global muss man halt nur in die Spiel das DLSS 3.1.1 reinkopieren um auf nummer sicher zu gehen
Habe es nun mal probiert und das sogar mit einem Windows Store Game.
Das Game ist Warhammer 40k Darktide. Da war ich immer mit der Texturqualität etwas unzufrieden und auch die Schärfe war so ein Thema.
Also den Unterschied sah ich definitv. Bei Superresolution hätte ich noch DLAA oder DLSS Ultra Leistung wählen können, aber habe das ingame DLSS Qualität gelassen.
Also es funktioniert und hat die Bildqualität bei diesem Spiel spürbar gesteigert. Auch in Verbindung mit Auto HDR. Also DLSS 4 ist schon gut :)
Probiert es selber mal aus.
Wo hast du DLSS4 denn eingestellt? Das wird im Screenshot irgendwie nicht ersichtlich. Da, wo ich es vermutet habe, steht bei dir nämlich "Für jede DLSS-Technologie unterschiedliche Ein(Stellungen?)..."
Siehe Bild. Voreinstelle Modelle @ Neueste. Bilderzeugung ist MFG und das geht wenn nur über RTX 5000er. Strahlenrekonstruktion geht dann zb. bei CP 2077, weil das halt RR drinne hat.
Ansonsten noch diese Option ist auch noch möglich.
Überschreibt dann, wenn du DLSS Qualität im Spiel eingestellt hast zb. dieses durch zb. DLAA, weil das Spiel selber DLAA ggf. nicht zu Auswahl hat.
Dafür ist es dann halt nützlich.
Bei mir geht das nicht in der APP steht überall Nicht unterstützt drin. Mit NV Inspector geht es aber
Also bei mir gehts immer noch nicht. Egal welches Spiel.
Habe noch ein bisschen rum getestet.
Forza Motorsport habe ich @ max und 4k DLAA mit DLSS 3.1.1 100 FPS im Benchmark und mit DLSS 4 96 FPS im Benchmark.
Im Benchmark ist mir optisch kein Unterschied aufgefallen.
Ready or Not @ max. 4K DLAA sieht mit DLSS 4 spürbar besser aus, aber FG funktioniert mit DLSS nicht richtig.
Wo DLSS 3.1.1 mit FG Framelimit erreicht und die GPU mit paar Watt rumdümpelt und es sich gut anfühlt habe ich mit DLSS 4 und ingame FG massiv weniger Frames als ohne FG und mega Input Lag.
Also DLSS 4 scheint mit FG probleme zu haben in Ready or Not. Habe DLSS 4 an gelassen in Ready or Not und FG abgeschaltet. Komme trotzdem auf 138 FPS, aber halt wird die GPU mehr gefordert, aber sieht halt lecker aus.
Bei CP 2077 wo es im Game implementiert ist und man nicht via Treiber es erzwingen muss gibt es aber keine Probleme mit FG. Da ist alles top.
Bei Indiana Jones zb. zeigt mir an das es geht
Leider bei Indy dasselbe bei mir.
Naja, erstmal schlafen gehen und am WE schauen was da los ist.
Ich geb es jetzt auch erst mal auf. Mit DDU Treiber deinstalliert und alles noch mal frisch installiert: kein Unterschied. Nicht ein Game supported es. Was sind denn so Titel wo es auf jeden Fall funktionieren müsste?
Hm habe den Treiber über die App aktualisiert. Ausgewählt ist Game Ready Treiber bei mir.
Geht bei mir auch nicht und auch im MRTV Discord geht es nicht bei den Leuten.
NV Inspector und Global eingeschaltet und das wars. kein gefummel mehr und es geht bei allen Spielen!
Woran erkennt man denn, dass es geht?
ohne entspr. overlay eigtl. nur an der qualität. ansonsten ist eine seite vorher im anhang einer meiner posts das regfile für das dlss overlay zu finden, damit prüf ich das gern mal kurz. reg file zum ausschalten auch mit drin, im startmenu eine verknüpfung dafür angelegt macht's auf dauer ein wenig einfacher finde ich.
bei witcher 3 gibt's allerdings mit den neuen dll files problemchen: nach vier fünf stunden fängt das bild an zu flattern / flimmern, doppel- und dreifach-abbildung seitlich verschoben, kA wie ich das erklären soll :d kam jetzt zwei mal vor, trotzdem aber bis dahin mit dlss4 einfach nur sexy, wirklich gute bildquali und sonst keine anderen probleme 👍
Bezüglich Slotblende Zotac 4090:
Ich habe mal auf Verdacht zwei verschiedene Blenden bei AliE bestellt um entweder was zu basteln und/oder zu hoffen, dass so etwas passt.
Ich berichte...
Finde ich komisch, weil bei mir gehts, aber zb. geht bei mir kein RTX HDR, wenn ich dieses für das Spiel einschalte. Er übernimmt das einfach im Spiel nicht.
Es funktioniert nur, wenn ich das über den Filter mache bzw das Overlay aktiviere mit Filter. Problem ist aber mache ich das über den Filter, dann macht der das bei mir Global und das beißt sich dann mit nativ HDR Games und mit Games wo Auto HDR aktiv ist. Ist wohl noch optimierungsbedarf bei der Nvidia App.
Mache es dann nun so, wenn ich RTX HDR verwenden will für ein Spiel aktiviere ich gerade das Overlay.
Sobald ich dieses Spiel dann beende mache ich dieses dann wieder aus, damit ich mit anderen Games keine Probleme bekomme.
Wie kann ich denn im Inspector das K Preset wählen? Das ist bei mir nicht hinterlegt. Auch nicht mit der neuen XML Datei.
Und im Guru3D Forum hat hier einer ne neuere Version vom Nvidia Inspector 2.4.2.3. Kann die aber nirgends zum Download finden.
Hier findest du alles!
ja, nice :) sind wirklich angenehme zeiten für generations-überspringer: es kamen ja doch so einige neue sachen, aber es geht scheinbar noch weiter! über treiber einschaltbares "framegen":
UPDATE #2:
NVIDIA told us that support for the RTX40 series GPUs will be coming in a future update.
“NVIDIA Smooth Motion is a brand-new driver technology and requires time for validation and QA across multiple products. Support for GeForce RTX 40 Series GPUs will be coming in a future update.”
hört sich wie ich finde ganz gut an, mal sehen wie das wird :bigok: :banana:
Joa man scheint diesmal als 4090 Käufer nicht in die Röhre zu schauen.
MFG ist eh für die meisten unbrauchbar und normales FG ausreichend, wenn man es überhaupt nutzen will.
Sind bei mir sehr wenige Spiele. CP2077 ist da auch so ein Ausnahmetitel wo es sehr gut funktioniert.
Gerade nun auch nach dem DLSS 4 Update.
Glaube viele die ihre 4090 verkauft haben im Vorfeld ärgern sich sehr, weil selbst eine 5080 ist langsamer als eine 4090.
Etwas wehmütig bin ich schon, aber meine 4090 FE habe ich gerade für 2400€ verkauft, nach über 2 Jahren Nutzung :fresse2:
Kumpel hat paar 5080 für MSRP (1169€) bekommen und gibt mir übergangsweise eine ab
Komisches Gefühl die 4090 FE verkauft zu haben jetzt wo die 5090 Verfügbarkeit und Preise eher unterirdisch ist, aber der Erlös war gut 🤷‍♂️
Das ist echt krank! 2.400 Euro für eine gebrauchte RTX 4090 FE! Ich kann nicht mehr :lol::wall:
Dont hate the Player, hate the Game!
5090 3.500€ nicht verfügbar
4090 2.400€ verfügbar
Das kann man keinem übelnehmen, nur NVIDIA.
Wären gestern 5090 FE gedroppt und dann zwar auch gleich genug, damit jeder eine bekommt, zum MSRP, kannst bei den Preisen überall 1.000€ abziehen und wir hätten nicht diese absurde Situation. Stattdessen würden wir uns alle freuen können mit den neuen Karten bereits spielen zu können.
Ich verfluche NVIDIA für das was sie abziehen, 150-300x 5090 oder was es gab weltweit. Die wissen genau wie hoch der Bedarf bei uns Gamern ist, mit ausreichender Verfügbarkeit hört sich das Gescalpe auch auf. Ursache (nicht Schuld) ist NVIDIA, wenn sie quasi mit 10x Karten auf den Markt gehen. Hätten sie in 3 Monaten released mit 50.000-100.000 Karten, wäre die Welt (auch bei GPUs) so wie wir sie von früher kannten. Leider läuft die letzten Jahre alles aus dem Ruder und das ist alles selbstgemacht!
In dieser Version des Inspectors ist das K Model schon enthalten, wurde Gestern geupdatet.
Am Ende war es noch Jemand, der seine 4090 verkauft hatte für die 5090 und keine bekam. :d
Ähnliche Themen
