Darkchylde24
Go back to the old cpu temp
Fisrt off all, sorry about my english. Yesterday I could go back to my cpu low temp. Try to do this:
1) Uninstall completely Abit EQ. After uninstall, use regdelete to make sure that is completely uninstalled.
2) Go back to bios 14. Disable beep monitoring, save your new configs in that bios and do not enter to windows. Push dell and go back to bios. Verify your temp after you save. Probabilly it is high again. Save bios again and do not enter to windows. Enter to bios. Verify your temp again probably it is low. I know, it is completely crazy but it is true. It’s a BIG BUG!!! Each time you save bios 14 the cpu temp changes (up and down). So you have to save your configs preparing to upgrade to bios 17 (floppy) and certified yourself entering the bios that the temp is low and at this time DO NOT SAVE the bios. Choose exit without saving. Upgrade to bios 17. After this upgrade, the temp doesn’t change anymore. Verify cpu temp and probabilly it is fixed at the low marks. After this you can install AbitEQ (can be the lastest version).
My CPU temps now: 35 idle (bios)/45 full (abit eq). BTW, abit eq is really wrong. At the moment I start my abit eq, the cpu temp shows 34~35 and a fem seconds later 25ºC…
Before I did, my CPU temps are 51(idle)/69(full).
Good luck and post if it works.
Könnte mir das mal einer kurz übersetzen von wegen Schritt 1-x, so ganz steig ich da nämlich nicht durch!
