digitalbath
Mr. Oldschool-Bios
- Ort
- Moers
- AMD R7 5800X
- ASRock B550 Steel Legend
- Scythe Fuma 2 + Noctua
- Crucial Ballistix DDR4 3600 32GB
- AMD XFX RX6600
- BenQ 24" XL2410t
- 2x500GB; 1x1000GB
- HDD
- Ja, für Datengrab
- Soundkarte
- O2 + AKG K702 / K340
- Deepcool Matrexx 55 V3 RGB
- BeQuiet! SystemPower11 Platinum 550W
- Keyboard
- Corsair K90
- Mouse
- Kingston Plastikmüll-X
- Win11
- Webbrowser
- der rote Fuchs
I used same Voltage for the tree tests. Max Clock was here ~2660MHz on all three tests.
A7N8X-E has only 4-FID Multiplier change, that means I can only use Multi 5-12,5 for my XP-M. I can retest with ~10x260, but I have to rebin my AT-6 Dimms on my ASUS board first. AT-6 Dimms that like the ASRock board, don't like ASUS and vice versa.
edit:
edit:
understood. I will retest that on my ASRock board sometime in the future. It has a 5-bit Multi change for all Multi.What I think is that you can go higher in cpu frequency if you do for example 15x <200 and try 2650 with the same voltage.
